Old 10-07-2013, 04:24 PM   #1
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Default Turbo Spec Comparison Table (Wheel Sizes, Max Airflow, Bearings, Etc.)
This list has been created to help compare turbo's more easily. As I looked at different turbo options it became clear that it was not a straightforward task, mainly due to inconsistent methods of listing turbo specifications by different manufacturers. Because of this it was difficult to even compare the physical wheel sizes of different turbo's.
I began compiling the information that I could find by looking online and in the product catalog's of various manufacturers. Along the way I asked manitou for help and he did a lot of the work calling around to try and fill in the blanks that I could not easily find, and also adding info for other brands and models. Thanks to him we have a pretty good list together at this time.
We chose common turbo's on the Subaru platform. Both stock location and rotated turbo's are included.We decided to keep this table as simple as possible and only include some of the most basic specifications. This includes the inducer and exducer measurements for both the compressor and turbine, and also the max flow rate of the turbo.
This post is NOT meant to be a lesson on turbo basics. If you need that there are many resources on this site and elsewhere online. Here are a few links to get you started.
http://forums.nasioc.com/forums/show....php?t=1218459
http://www.turbobygarrett.com/turbob...rbo_tech_basic
http://www.turbobygarrett.com/turbob..._tech_advanced
http://www.turbobygarrett.com/turbob...bo_tech_expert
Here is the list that we have compiled so far. Please let me know if there are any errors. All of this information should have come straight from the manufacturer, but there could still be errors, and I would be happy to correct any that are found. We are open to suggestions for more turbo's to be added to the list. If you have the specifications available that would make it much easier to get it added.
xluben is offline   Reply With Quote
Old 10-07-2013, 04:25 PM   #2
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
To help clean up the look of the table, some abbreviations were used in the headers. Here are the descriptions (with units):
Code:
CmpInd	Compressor Inducer [mm]
CmpExd	Compressor Exducer [mm]
TrbInd	Turbine Inducer [mm]
TrbExd	Turbine Exducer [mm]
Flow	Max Air Flow Rate [lb/min]
Code:
Brand		Turbo		CmpInd	CmpExd	TrbInd	TrbExd	Flow	CHRA Bearings	Mounting
Blouch		16G XT		48.30	64.30	55.50	49.00	41.0	Journal Bearing	Stock
Blouch		18G XT		49.80	68.00	55.50	49.00	43.0	Journal Bearing	Stock
Blouch		20G XT		52.00	68.00	63.00	54.00	47.0	Journal Bearing	Stock
Blouch		16G XT-R	48.30	64.30	54.00	49.40	38.0	Ball Bearing	Stock
Blouch		18G XT-R	49.80	68.00	56.50	51.70	43.0	Ball Bearing	Stock
Blouch		20G XT-R	52.00	68.00	56.50	51.70	47.0	Ball Bearing	Stock
Blouch		Dom 1.5 XT-R	53.00	71.00	56.50	51.70	49.0	Ball Bearing	Stock
Blouch		Dom 2.5 XT-R	53.00	71.00	60.00	54.90	49.0	Ball Bearing	Stock
Blouch		Dom 3.0 XT-R	57.00	76.00	60.00	54.90	55.0	Ball Bearing	Stock
Blouch		Dom 3.5 XT-R	57.00	76.00	64.00	58.60	58.0	Ball Bearing	Stock
Blouch		Dom 4.0 XT-R	60.00	82.00	64.00	58.60	60.0	Ball Bearing	Stock
Blouch		Dom 5.0 XT-R	62.00	84.00	68.00	62.20	65.0	Ball Bearing	Stock
BorgWarner	BW 7670		56.00	76.00	70.00	61.00	58.0	Journal Bearing	Rotated
BorgWarner	BW 8375		60.00	83.00	75.90	68.00	68.0	Journal Bearing	Rotated
BorgWarner	BW 8875		63.00	88.00	75.90	68.00	75.0	Journal Bearing	Rotated
BorgWarner	BW 9180		66.00	91.00	80.00	73.00	82.0	Journal Bearing	Rotated
BorgWarner	EFR 6258	49.60	62.00	58.00	51.00	44.0	Ball Bearing	Rotated
BorgWarner	EFR 6758	53.90	67.00	58.00	51.00	49.0	Ball Bearing	Rotated
BorgWarner	EFR 7064	52.20	70.00	64.00	56.00	56.0	Ball Bearing	Rotated
BorgWarner	EFR 7163	57.00	71.00	63.00	N/A	60.0	Ball Bearing	Rotated
BorgWarner	EFR 7670	57.20	76.00	70.00	62.00	64.0	Ball Bearing	Rotated
BorgWarner	EFR 8374	62.60	83.00	74.00	64.00	79.0	Ball Bearing	Rotated
BorgWarner	EFR 9180	67.70	91.00	80.00	74.00	94.0	Ball Bearing	Rotated
Forced Perf	FP 68HTA		68.00	65.00		47.0	Journal Bearing	Stock
Forced Perf	FP 71HTA	51.20	71.00	65.00	55.00	51.0	Journal Bearing	Stock
Forced Perf	FP Green HTA	54.80	76.00	67.00	59.00	59.0	Journal Bearing	Stock
Forced Perf	FP Red 		61.21	81.79	67.00	59.00	65.0	Journal Bearing	Stock
Forced Perf	FP Red 76HTA	58.00	76.00	60.00	54.90	60.0	Ball Bearing	Stock
Forced Perf	FP Black HTA	59.10	82.00	67.30	58.80	68.0	Journal Bearing	Stock
Forced Perf	FP Black 82HTA	62.00	82.00	68.00	62.23	68.0	Ball Bearing	Stock
Forced Perf	FP HTA 3076R	54.80	76.00	60.00	54.90	59.0	Ball Bearing	Rotated
Forced Perf	FP HTA 3582R	62.00	82.00	68.00	62.20	68.0	Ball Bearing	Rotated
Forced Perf	FP HTA 3586R	62.10	86.20	68.00	62.20	75.0	Ball Bearing	Rotated
Forced Perf	FP HTA 3786R	62.10	86.20	72.50	66.50	78.0	Ball Bearing	Rotated
Forced Perf	FP HTA 3794R	67.50	94.00	72.50	66.50	93.0	Ball Bearing	Rotated
Forced Perf	FP HTA 4294R	67.70	94.00	82.00	77.00	96.0	Ball Bearing	Rotated
Forced Perf	6466TZ		64.00	88.00	72.60	66.30	92.5	Ball Bearing	Rotated
Forced Perf	HTZ Super 94	67.70	94.00	76.00	67.00	95.0	Ball Bearing	Rotated
Forced Perf	HTZ Super 99	72.00	99.00	76.00	67.00	103.0	Ball Bearing	Rotated
Garrett		GT 2871R	51.20	71.00	54.00	49.40	46.0	Ball Bearing	Both
Garrett		GT 3071R	53.10	71.00	60.00	54.90	46.0	Ball Bearing	Both
Garrett		GT 3076R	57.00	76.20	60.00	54.90	52.5	Ball Bearing	Both
Garrett		GT 3582R	61.40	82.00	68.00	62.20	60.0	Ball Bearing	Both
Garrett		GT 4088R	63.50	88.00	77.00	70.40	67.5	Ball Bearing	Both
Garrett		GT 4294R	70.30	94.00	82.00	77.00	85.0	Ball Bearing	Both
Garrett		GTX 3071R	54.10	71.40	60.00	54.90	56.0	Ball Bearing	Both
Garrett		GTX 3076R	58.00	76.60	60.00	54.90	64.0	Ball Bearing	Both
Garrett		GTX 3576R	58.00	76.60	68.00	62.20	65.0	Ball Bearing	Both
Garrett		GTX 3582R	62.50	82.50	68.00	62.20	75.0	Ball Bearing	Both
Garrett		GTX 4294R	70.30	94.00	82.00	77.00	95.0	Ball Bearing	Both
IHI		VF39/48/52	46.50	60.00	52.80	47.88	34.0	Journal Bearing	Stock
MHI		TD04L 13T-6	40.70	56.00	47.00	41.30	26.7	Journal Bearing	Stock
MHI		TD05H 16G	48.30	68.00	56.00	49.10	37.9	Journal Bearing	Stock
MHI		TD05H 18G	50.50	68.00	56.00	49.10	43.7	Journal Bearing	Stock
MHI		TD05H 20G	52.50	68.00	56.00	49.10	47.4	Journal Bearing	Stock
MHI		TD06SL2 20G	52.50	68.00	61.00	54.00	47.4	Journal Bearing	Stock
MHI		TD06H 20G	52.50	68.00	67.00	58.80	47.4	Journal Bearing	Stock
MHI		TD06H 60-1	59.50	76.00	67.00	58.80	61.0	Journal Bearing	Stock
Precision	Subaru 5530	54.90	76.20	56.50	51.78	52.5	Ball Bearing	Stock
Precision	PTE 5558	54.90	76.20	64.90	57.91	59.0	Either		Rotated
Precision	PTE 5858	58.00	76.20	64.90	57.91	62.0	Either		Rotated
Precision	PTE 5862	58.00	76.20	71.00	61.90	64.0	Either		Rotated
Precision	PTE 6262	62.23	81.99	71.00	61.90	70.5	Either		Rotated
Precision	PTE 6266	62.00	81.99	74.17	66.00	73.5	Either		Rotated
Precision	PTE 6266 G2	62.00	81.99	74.17	66.00	80.0	Ball Bearing	Rotated
Precision	PTE 6466 G2	64.39	86.61	74.17	66.00	90.0	Ball Bearing	Rotated
Precision	PTE 6766	67.44	88.32	74.17	66.00	93.5	Either		Rotated
Precision	PTE 6870 G2	68.02	92.46	78.74	70.21	110.0	Ball Bearing	Rotated
Precision	PTE 7175	70.99	93.98	82.00	75.08	98.5	Either		Rotated
Precision	PTE 7275	72.40	91.00	82.00	75.08	101.5	Either		Rotated
Steam		STX 67		49.70	67.40	55.80	49.10	48.0	Journal Bearing	Stock
Steam		STX 71		54.10	71.40	61.00	54.10	59.0	Journal Bearing	Stock
Steam		STX 20G-R	52.50	68.00	60.00	54.90	47.4	Ball Bearing	Stock
Old 10-07-2013, 04:25 PM   #3
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here is the same info sorted by max flow rate:
Code:
Old 10-07-2013, 04:46 PM   #4
207STi
Member#: 197062
1998 Swapped Impreza
black
This is AWESOME! Thanks.
207STi is offline   Reply With Quote
Old 10-07-2013, 05:19 PM   #5
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Ben, Good job putting this up along with the diagram! The only thing from our initial list here that I need to fill in is the turbine exducer for the Borg Warner turbos.
So if anyone can help us with those BW TrbExd dimensions it will help to make our initial list complete. PM xluben or I your notes on these and we will update them.
I'll keep trying to reach Full Race but I know they're busy getting ready for SEMA.
As a general note, xluben and I made the initial list based on what we feel are to most popular turbos for our Subaru's these days. We know everyone has their favorite and it may or may not be on the list above.
We wanted to show the basic wheel dimensions as well as wheel pairing relationship from the turbine to the compressor. Hopefully it will make choosing a turbocharger an easier process!
Edit: I did get thru to Full Race today and was able to get the TrbExd dimensions for the Airwerks JB turbos we have on the list. I'm sure xluben will be updating the list soon!
BTW, the EFR's TrbExd dimensions are not published anywhere even Full Race does not have these dimensions. So I guess we are on our own with those but one could deduce these dimensions based on some assumptions or someone could actually measure them. If you do please let us know what they are!
Old 10-07-2013, 08:01 PM   #6
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Thank you for the time you both have put in making this list, makes me even more happy with my turbo of choice. (mostly posting to have a quick link)
Its amazing how different the GTX series flows in comparison to the GT series, when these all get tossed in order the way you do it makes some choices look like a sad joke that are commonly accepted for builds.
I think if people view these more in this way we will see only a few of these options even being considered.
On a side note would it be possible to have this posted in a way that is downloadable? I would love to read over this when I am not at work (no internet out where I live) For all I care it can wait until you are "done" with the list if you prefer.
Thank you
Scuby04STi is offline   Reply With Quote
Old 10-07-2013, 09:05 PM   #7
R6_rider
Member#: 138768
2013 evo x
white
any chance you can add factory turbos to see where they sit?
R6_rider is offline   Reply With Quote
Old 10-07-2013, 10:29 PM   #8
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
Awesome contribution guys. I'll definitely be analyzing this. Thanks you guys.
freddy121389 is offline   Reply With Quote
Old 10-07-2013, 10:33 PM   #9
manitou
Member#: 193757
2006 XTI Limited
Probably not! Factory VF turbos are all pretty similar size most of them are around 37 lb./min. A couple like the VF22 and Vf42 TS are a little bigger maybe 38-39 lb. There is plenty of comparison out there on these turbos but little in the way of specs.
Old 10-07-2013, 11:29 PM   #10
hummelsubaru
Member#: 220153
'05 WRX JBP WFC#207
GTX3076 ViPec V44
great thread, a lot of useful info for us. Thanks xluben
hummelsubaru is offline   Reply With Quote
Old 10-08-2013, 06:22 AM   #11
Tuned200
Member#: 127740
2015 WRX-Mine
2007 F-STI-Her's
Nice work guys.
Tuned200 is offline   Reply With Quote
Old 10-08-2013, 07:33 AM   #12
Juks
Member#: 108163
2015 WRX, 2005 STI
Very nice, thanks!
Juks is offline   Reply With Quote
Old 10-08-2013, 09:53 AM   #13
Leafy
Member#: 330625
2006 WRX
Can we get standard mitsu sizes for comparison? A Blouch 16gXT is a lot bigger than a standard 16g.
BW EFR turbine sizes
58mm is a 88 trim
64mm is a 88 trim
70mm is a 88 trim
74mm is a 87 trim
80mm is a 92 trim
So I think that means the exducers are
58 = 51
64 = 56
70 = 62
74 = 64
80 = 74
If I remember what trim means.
Leafy is offline   Reply With Quote
Old 10-08-2013, 10:04 AM   #14
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks!
Thank you
It really does help put some of these turbo's into perspective.
I will look into getting the spreadsheet hosted somewhere. I can probably put up a DropBox link.
Yeah, the issue is lack of info. If someone has taken the measurements, I would be happy to post them.
Originally Posted by Tuned200 View Post
Nice work guys.
Originally Posted by Juks View Post
Very nice, thanks!
Thanks!
BW turbine sizes
58mm is a 88 trim
64mm is a 88 trim
70mm is a 88 trim
74mm is a 87 trim
80mm is a 92 trim
58 = 51
64 = 56
70 = 62
74 = 64
80 = 74
Yes, I really wanted to add the standard Mitsubishi specs (16G, 20G, etc), but again, I had a hard time finding any of the info. If you know where to find it, I would be happy to add it.
manitou did the get BW (non EFR) specs, so I'll double check them against yours. I can also calculate them based on trim to double check your calculations. I had to do this for some of the other turbo's as well.
Old 10-08-2013, 10:45 AM   #15
URABUS07WRX
Member#: 262367
2007 WRX
awesome work
URABUS07WRX is offline   Reply With Quote
Old 10-08-2013, 11:04 AM   #16
superacerc
Member#: 317679
2009 2.5XT/20G
Metallic Black
Thanks guys. Sadly it makes my 20g seem like it's on the baby list. Lol oh well... still plenty of fun.
superacerc is offline   Reply With Quote
Old 10-08-2013, 11:11 AM   #17
rexblake
Member#: 178426
2010 S4
Gray
Nicely done. Glad to see someone did this.
rexblake is offline   Reply With Quote
Old 10-08-2013, 11:17 AM   #18
jblewis
Member#: 22768
04 2.5 XT
Nice!
jblewis is offline   Reply With Quote
Old 10-08-2013, 12:00 PM   #19
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
Thanks for taking the time to compile this info
rexworx is offline   Reply With Quote
Old 10-08-2013, 12:52 PM   #20
CatfaceType-R
Member#: 81102
Here's another list that older members will remember (has other info, different from this thread, but still a lot of good info) but spreading info is never a bad thing.
http://forums.nasioc.com/forums/show....php?t=1141476
Kudos to the guys that take time to spread info!
CatfaceType-R is offline   Reply With Quote
Old 10-08-2013, 01:33 PM   #21
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Glad everyone is liking the info!
I have seen this, and I actually had it queued up to link to in the first post of this thread, but in all the times I've looked at it I've never once gotten any use out of it. I eventually decided it was such useless and outdated info that I didn't even include the link. Maybe someone can find a use for it, but the generalized statements as well as a very outdated selection shows little value to me.
Old 10-08-2013, 03:30 PM   #22
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
58mm is a 88 trim
64mm is a 88 trim
70mm is a 88 trim
74mm is a 87 trim
80mm is a 92 trim
58 = 51
64 = 56
70 = 62
74 = 64
80 = 74
Trim is the (inducer of the wheel / exducer) *100
remember that the inducer and exducer are the opposite from turbin and compressor wheels.
fastblueufo is offline   Reply With Quote
Old 10-08-2013, 07:17 PM   #23
manitou
Member#: 193757
2006 XTI Limited
Originally Posted by URABUS07WRX View Post
awesome work
They're all good! It just depends what you want out of the car.
Originally Posted by jblewis View Post
Nice!
I've spent a lot of time looking at that thread, Thanks Carmi!
remember that the inducer and exducer are the opposite from turbine and compressor wheels.
Thanks for posting that formula. I've used it before. The manufacturers were pretty good about sharing their info.
Thanks guys! It's good to see it all in one place.
If someone wants to pass along the Mitsubishi 16, 18, 20g data we can add them to the list!
Old 10-08-2013, 07:26 PM   #24
manitou
Member#: 193757
2006 XTI Limited
58mm is a 88 trim
64mm is a 88 trim
70mm is a 88 trim
74mm is a 87 trim
80mm is a 92 trim
58 = 51
64 = 56
70 = 62
74 = 64
80 = 74
Thanks for the post! The trims for the EFR's are not exact as you listed. We could use an average of 88.5% trim for the 55-70 turbine wheels. The 74 is 87% and the 80 is 92%.
I'll work on these and get them to xluben to add to the chart!
Old 10-10-2013, 11:54 PM   #25
Hales46
Member#: 150806
2010 STI
Nice job! Any idea where the GTX 2867 comes in?
Hales46 is offline   Reply With Quote
