Old 10-12-2013, 12:15 PM   #1
wrprojex
Member#: 251677
Default mod advice
I just bought a 14 wrx, I want to make good numbers but also maintain a low profile, that being said I planned on doing perrin headers, invidia catless dp, cobb intake, cobb ap, intercooler, custom tune ( I have these parts sitting in my garage). Ive done a bunch of research and called several shops but I cant get a straight answer. I don't want to do a cbe unless I absolutely have to because I want the car to be extremely quiet, some shops say its fine but i'm leaving some power on the table, and some say the car wont be happy and run right. How important is the cbe for reliability, will I be choking it badly, how much power am I going to lose? As for the intercooler, will the stock one handle 300 whp reliably ( 100k miles) or should I just upgrade, and if im spending the money anyways, would a tmic do what I need or would a fmic be the best route....also, how close am I to maxing out my injectors at 21psi? as you can tell I'm extremely worried about reliability first, and sound second, all of these questions have been answered, but I keep getting different opinions from different people and I just want a solid answer before I get tuned. Thanks in advance and sorry for the newbie question
wrprojex is offline   Reply With Quote
Old 10-12-2013, 12:22 PM   #2
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
I've been under the impression that cat-back exhausts are just for noise.
As far as the IC, it's a worthwhile upgrade as the stock core is crimped to the endtanks and many users have reported failures, even on stock cars.
SlimJim8804 is offline   Reply With Quote
Old 10-12-2013, 01:25 PM   #3
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
For 300whp just a dp and stock top mount will be fine. Your injectors will be pretty much maxed at 21psi. The stock cbe won't be much of a restriction at all at that power level. The stock tmic may or may not last at those levels but I'd run it till it went. A front mount would be overkill on the stock turbo.
jerbull88 is offline   Reply With Quote
Old 10-12-2013, 01:35 PM   #4
wrprojex
Member#: 251677
You guys are awesome that's exactly what I wanted to hear lol, last questions(for now)... What injectors are the first step up from stock, can I buy anything to make an Sti intercooler work?, if I do get bigger injectors and I drive very carefully and responsibly, will my gas mileage change? Will my stock fuel pump handle the job? Thanks again, I have researched but it's hard to pinpoint the exact answers to these questions
Old 10-12-2013, 01:53 PM   #5
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Down pipe for power, tmic so the stocker doesn't split, injectors and pump just to be safe and give you headroom. Problem with running the stock injectors maxed out is the high duty cycle isn't good for them and if they start to have a problem you can have a big problem before you notice it. Catback and intake are both just noisemakers at that power level.
cowboy_Rob is offline   Reply With Quote
Old 10-12-2013, 01:54 PM   #6
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Gas mileage will only suffer when your beating on it. Low throttle driving nicely your mileage may even improve from the less restrictive down pipe
Old 10-12-2013, 02:54 PM   #7
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
Sti intercooler will never fit. Bigger injectors will only give more headroom with no change with normal driving. A fuel pump is kind of a "why not" because of the ease and low cost. Your stock injectors will handle your turbo unless you choose to go e85.
Old 10-12-2013, 06:09 PM   #8
wrprojex
Member#: 251677
ok great thank you all very much, so I asked my buddy what size injectors to go with and he said 1000cc because injectors are all around the same price so why not.... what do you guys think? also, what brand do you recommend?
Old 10-12-2013, 06:23 PM   #9
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Do you plan to go big at any point? If you plan to stay on a stock turbo you don't need much bigger then stock so if just look for a deal on some used ones from somebody going bigger.
Old 10-12-2013, 07:28 PM   #10
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Huh!!! Lol an STI ic would fit fine as long as the op gets the STI splitter also/.
Op first and up most talk to a reputable tuner that would be doing the tuning as they're the ones that would be doing the tuning.
trev762 is offline   Reply With Quote
Old 10-12-2013, 07:34 PM   #11
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Not positive if they changed anything for 14 but the 13s use a completely different intercooler between wrx and sti. The wrx cooler bolts directly to the turbo outlet the sti one uses a y pipe and coupler like the GDs
Old 10-12-2013, 07:58 PM   #12
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Oops!!! Ya my bad I guess I had gd in my head lol. Thx for the correction:/.
Old 10-12-2013, 08:14 PM   #13
point78
Member#: 344329
2008 Wrx, 6mt
Id1000 injectors, processwest tmic, Dw65c fuel pump-it drops right in no mods required. (id's are really nice injectors-don't worry about the big size, they idled my 1.6l better than the stock injectors...). MAC 3port ebs, or whatever brand. Forge bpv.
Don't get a FMIC, it adds like 10' of charge tubing(seriously), kills your spool (and blocks the radiator)
point78 is offline   Reply With Quote
Old 10-12-2013, 08:19 PM   #14
point78
Member#: 344329
2008 Wrx, 6mt
A catted downpipe won't hurt your max hp(at these levels), it will cause your turbo to spool a little later vs a non catted. But the vf52 spools fast anyways.
The cat acts as a really good muffler, you take it out it's gonna be louder/raspy er...
You didn't ask, but you should also get:
Whiteline front and rear sway bars. 22mm both, or (24mm front, 22 rear)
Kart boy endlinks-front & rear
After that you'll want the whiteline bushing inserts for the rear end, that way the rear diff won't move when you hammer it(the stock bushings have some open slots in them, you can feel the diff move/clunk when you get on it)
Old 10-12-2013, 10:30 PM   #15
wrprojex
Member#: 251677
Awesome guys, thanks for all the info, ill keep u posted with charts... Why is it taking so long for Cobb to release everything, if the '14 is the same as the '13, then what's going on I'm getting impatient haha
Old 10-13-2013, 01:53 AM   #16
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Because the 14 is still a month or two old. It takes time to make the necessary map and adjustments.
Why didn't you read the Manifesto or search? Zing!
Old 10-13-2013, 04:09 PM   #17
wrprojex
Member#: 251677
I searched a good amount about mods but assumed the 14 was the same as the 13, and you know what they same about assumptions.... Made an As$ out of me
