Welcome to the North American Subaru Impreza Owners Club Sunday September 21, 2014
Old 01-13-2014, 01:51 PM   #1
Aaron2000Subaru
Member#: 329537
Default Engine Crank pulley
Ok all, I just discovered last night that my pulley was shaking all about and so I tightened the bolt and drove home. Well this morning I decided to pull the pulley off and this is what I found. Is there a way to replace it or not? Any help and suggestion would be great! Thanks!
Aaron
Here is a couple pictures I took.
http://s1275.photobucket.com/user/Aa...tml?sort=3&o=1
Aaron2000Subaru is offline   Reply With Quote
Old 01-13-2014, 01:52 PM   #2
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
nothing to see, i'm stock
if any material is worn away, id replace it
Old 01-13-2014, 01:55 PM   #3
Fender137
Member#: 340626
2004 Impreza Wrx STi
World Rally Blue
You need to replace it. Looks like a Cobb Pulley.
Fender137 is offline   Reply With Quote
Old 01-13-2014, 01:57 PM   #4
Aaron2000Subaru
Member#: 329537
It is a cobb pulley and I am going to replace it but what can you tell me about the second picture?
Old 01-13-2014, 02:09 PM   #5
Supa LA
Member#: 344540
2005 STi
While we are on the subject...is it very beneficial to go aftermarket light weight pulley? Opinons?
Supa LA is offline   Reply With Quote
Old 01-13-2014, 02:14 PM   #6
Aaron2000Subaru
Member#: 329537
I really like my cobb pulley. Probably going to get another one. Its like 1.4 lbs and the stock on is like 4 or 5 lbs. I did notice my car revs a lot quicker and maybe a very slight power gain but not much. I also got it because it was gold in color!
Old 01-13-2014, 03:38 PM   #7
Thunderpaw
Member#: 242205
2009 wrx
blue
Unabomber much?
http://forums.nasioc.com/forums/showthread.php?t=444518
Thunderpaw is offline   Reply With Quote
Old 01-13-2014, 08:14 PM   #8
ScoobyBenny#3
Member#: 202853
1993 Impreza L
Red/Black
The crankshaft damage is the more concerning part, You're probably going to need to pull the plastic timing belt cover off and clean up the end of the crankshaft with a file (only if there is bent/damaged material in the way of the new pulley) before you can install a new pulley (yes you do need a new one). When you do install the new pulley apply loctite generously and hope that the rest of the key doesn't snap off, because that would mean a new crankshaft (aka new motor).
ScoobyBenny#3 is offline   Reply With Quote
Old 01-13-2014, 08:39 PM   #9
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
That pulley is f'd and so is your woodruff key. You need to get the key sorted first by a PROFESSIONAL. Then decide if you want the professional to install another lightweight or OEM pulley. One thing's for sure though, you need to reevaluate who works on your car as this job is literally one bolt and whoever did it, borked the install.....if it was you farm installs out from now on....if it was someone else, stop going to them.
Old 01-14-2014, 01:10 AM   #10
niko311
Member#: 291779
2003 Wrx
Wrb
I would suggest taking this to a professional. Like Unabomber said, you need a new pulley and woodruff key. If it did enough damage, I've seen it also mess up the crank where the key goes in. If this is the case you could need a new crank.
niko311 is offline   Reply With Quote
Old 01-14-2014, 09:22 AM   #11
Supa LA
Member#: 344540
2005 STi
Originally Posted by Thunderpaw View Post
Good read, however, that was very general. I guess i will do more specific research as it pertains to my needs.
Old 01-14-2014, 12:12 PM   #12
Aaron2000Subaru
Member#: 329537
Thanks guys, going to pull the timing belt cover off now and see if anything is damaged.
Old 01-14-2014, 02:52 PM   #13
Aaron2000Subaru
Member#: 329537
Ok, I got the cover off but I haven't taken the belt off yet. It looks like only the key is damaged. I checked for play but it didn't budge. Going to my local subaru dealership to see what I can get out of them and then going to the shop I use and seeing what they can do and then figure out my next move. Lol. Again I really do appreciate all the help.
Aaron
p.s. I'll definitely keep posting about my situation because I'm still a noob.
