#1 |
Member#: 10844
Vehicle:2004 Acura TL Navi Pearl |
Anyone else out there get a CEL (missfire) with the UTEC? The car flashed the CEL last night while driving at light throttle just after a hard WOT run. I had the Subaru tech clear it this morning then got another one on the way home...
Mods are: UTEC w/Stage4 components Stock plugs/wires/etc. ScoobieSnaX ![]()
#2 |
Member#: 4980
Check your plugs and coils. You also might have an injector going bad as that will often cause a misfire.
Did the car pop and studder a bit when this happened or what? -Nathan www.turboxs.com |
#3 |
Member#: 10844
The car didn't show any signs of a missfire. Smooth acceleration, no issues other than the CEL.
The dealership has a set of plugs in stock....but I wonder if I should be going with a 'colder' plug?? I have 20K miles on this baby and this is the first time I've seen this code. It was running quite rich for the time I was running the stock ECU (waiting for UTEC to ship) which was about a month or so. Could this have fouled the plugs? Also, the Subaru tech just said the last CEL I just got might not be a missfire code since it flashed then went away. I currently don't have a CEL showing. He said the car could "work through the issue and remove the CEL". Could this be true? Thanks, ScoobieSnaX ![]() |
#4 | |
Member#: 4980
A real misfire is hard to miss when you have a car strapped to the dyno. |
#5 | |
Member#: 6124
Vehicle:2000 NFR AP1 S2000 '07 Honda FIT sport (5MT) |
OK... maybe everyone just missed this possibility..
![]() Perhaps the flash was just knock correction.... ![]() Quote:
Jorge (RiftsWRX) www.ProjectWRX.com |
#6 |
Member#: 10844
I wish....
In both cases it was just after hard driving. I'm going to replace the plugs tomorrow, cross my fingers, and see what happens... |
#7 |
Member#: 6124
Bumping this up to the top to see if changing the plugs did anything for you.
#8 |
Member#: 5994
Vehicle:2004 Impreza WRX STi Java Black |
Just thought I would throw my $0.02 in. When I was running the Link I started to have some "hesitation" issues. Since the Link gives NO CEL's whatsoever I had to figure this out without any aid. SO I pulled the plugs. They were brownish/red instead of black and suity so I cleaned them up with a dremel and everything is fine again.
BTW these plugs were one stage colder double platinum NGK's with only about 10,000 miles on them. I have another set just in case things start acting up again. But I was experiencing my problems during hard acceleration runs AND between shifts (bog badly). Just a thought. It wouldn't hurt to pull one easily accessable plug to check and see what it looks like? |
#9 | |
Member#: 18960
South East
Vehicle:02 WRX MBP It lives! ; ) |
#10 |
Member#: 10844
I swapped them out...got the same issue, then loaded the stage4 map from Phil. Have not had one since
Just came back from the race track today. Wow, I managed to get the car tuned just right...and I'm amazed at how it handles in the corners ![]() |
#11 |
Member#: 10299
Vehicle:2002 WRX Sedona Red Pearl |
I also got a flash of the CEL.....with slight hesitation when at WOT in 5th between 3-3.5k. I am running the stage 2 map....skywalker made a few changes to my map, and it seems to have gone away.....or at least the CEL doesn't flash anymore. He wasn't sure if it was being caused by fuel (91 octane here in cali) or timing....
#12 | |
Member#: 4143
Vehicle:2002 WRX Wagon WR Blue |
Remember guys, high octane gas is a friend of the turbocharged car. You should see the ignition advance and boost we can run without detonation on VP C16 Leaded Race Gas (MON 117, RON 118). Mark TurboXS |
#13 |
Member#: 10299
Mark, any chance of a 91 octane map for us people that have to live with it out here in cali?
#14 |
Member#: 5094
Vehicle:2002 11.96, 1.64, 115mph! |
We will definitely make some changes to our STG1-3 maps for the CA 91 Octane. We are just absolutely swamped getting ready for SEMA.
Will most likely pull out 1-2 degrees of ignition advance at the onset of boost and pull about 1 degree out between 4750-6000K RPM. We run the maps pretty rich overall at about 10.6-10.7-1 but we might add about 10% more fuel. If you have a UTEC and are using CA 91 you should follow these tips. We are waiting to get some reformulated "winter" gas to continue testing on in November. Thanks, Phil TurboXS |
#15 |
Member#: 4402
NESIC
Vehicle:2009 Outback XT DGM |
I heard that California will get 93 octane after the end of the year. But I got to see it to beleive it.
Cheers Nick |
| Thread Tools | |
| Display Modes | |
| CEL flash with utec? Knock? | WRX-ERROR | Engine Management & Tuning | 2 | 07-29-2005 02:26 PM |
| CEL Issue with UTEC | Inprogress | Engine Management & Tuning | 7 | 05-27-2005 05:49 PM |
| Strange CEL stuff with UTEC | dropmech | Engine Management & Tuning | 9 | 03-30-2005 11:57 PM |
| Cel on. Will utec detect knock? | dddnuts | Factory 2.0L Turbo Powertrain | 2 | 10-29-2004 07:32 PM |
| CEL day before UTEC tune. | finger123 | Factory 2.5L Turbo Powertrain | 3 | 08-25-2004 09:06 AM |
