Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Old 10-16-2002, 05:24 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ257
Brilliant Red
Default ECU reset and Fuel computer
After an ECU reset via battery disconnect the values I have in my Fuel computer seem to be no longer valid. I am running an HKS AFR it it matters. What should I be doing to values of the AFR at ECU reset? Should I leave them as is and once the computer is done relearning the will once again become valid? Should I set them all to zero for the learning and then readjust? If I leave the values in does it effect the learned values of the ECU?
Joshua
yebokmj is offline   Reply With Quote
Old 10-16-2002, 05:55 PM   #2
8Complex
Member#: 922
04 FXT
Red
Not sure of the rest, but I assume that yes, it will effect the values learnt by the stock computer as long as you've changed the fueling that it uses on closed loop, not just open loop only situations.
8Complex is offline   Reply With Quote
p0031 and misfires after a brand new front o2 sensor and ecu reset 1gcrazy Newbies & FAQs 25 09-26-2008 01:17 PM
ECU reset and now I have blinking lights! luger007 Commercial ECU Reflashes 3 05-22-2007 10:27 PM
utec or unichip or boost controller and fuel computer? racewagon Engine Management & Tuning 4 05-28-2003 06:06 PM
Zex Nitrous and Resetting the Zex Computer Kevin Thomas Normally Aspirated Powertrain 5 07-27-2002 03:03 AM
The nity when it comes to ECU resets and mods, once and for all RiftsWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 33 04-26-2002 02:39 PM
