Welcome to the North American Subaru Impreza Owners Club Friday July 11, 2014
Old 10-10-2013, 01:31 PM   #1
RezoClone2
Member#: 272348
2002 WRX 2.0L
SRP
Default Turbo and overreving
I've come across an issue where when I'm pushing 80%+ throttle, regardless of gear, and it comes up to 3k rpm, the boost gauge is reading close to 7lbs and all of a sudden my revs are jumping up to 4-4.3k then settling back down. I'm not sure if it's a leak in the BOV or what, so I have been babying it through the gears because I would hate to overrev and something mechanical break in the engine. Any help on this?
RezoClone2 is offline   Reply With Quote
Old 10-10-2013, 04:47 PM   #2
veritasaequitas
Member#: 333964
2005 sti
aspen white
Logs? Are you sure your clutch isnt slipping due
veritasaequitas is online now   Reply With Quote
Old 10-10-2013, 06:00 PM   #3
RezoClone2
Member#: 272348
2002 WRX 2.0L
SRP
Hmmm. No logs, but clutch could be an issue. It has 180k miles on it. I do have to double clutch for 5th gear so it doesn't grind, but last tranny check there was very minimal metal shavings in the case.
Old 10-10-2013, 06:24 PM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
your clutch is plain wore out man.
Old 10-10-2013, 10:05 PM   #5
veritasaequitas
Member#: 333964
2005 sti
aspen white
You wouldn't have metal shavings from ur clutch going unless ur driving the "if u can't find it grind it" method. Ur clutch is most likely toast. If u pull up ur e-brake put the car in first and slowly let off the clutch and the car dosnt stall out right away thats a really good indication ur clutch is done.
Old 10-23-2013, 03:11 PM   #6
RezoClone2
Member#: 272348
2002 WRX 2.0L
SRP
Is for sure the clutch. Now I need to find a reliable clutch. Any recommendations? I don't have all the money in the world, so take that into account. I do have a friend that's going to do it cheap who has a shop for import tuners.
Old 10-23-2013, 03:55 PM   #7
RezoClone2
Member#: 272348
2002 WRX 2.0L
SRP
Also, I have no mods on my 02 WRX, so looking more along the line of a stock clutch for the easy type of driving I'm doing.
Old 10-24-2013, 07:45 AM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
then get an oem clutch?
Old 05-10-2014, 07:22 PM   #9
jsteinlein
Member#: 375132
2006 Impreza WRX
Electric Blue
What if when someone lets out and it doesn't have an issue with stalling in first but seems to have the same turbo issue of jumping from max boost to half?
jsteinlein is offline   Reply With Quote
