Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Vancouver Impreza Club
Old 08-14-2015, 12:17 AM   #1
DK-1-RI
Member#: 405855
2012 Sti
Default Help: sway bar nut tread fix 08-14 Sti
Hi
I just regressing my sway bar, when to install the bolt was not line properly ( I did not notice) I force to thigthing it until is snap and the tread is damage bolt become lose so for now, I add another nut to keep it tight.
Any body has problem before how did you re tread it, to keep it the same bolt, without using larger bolt. Thank,
DK-1-RI is offline   Reply With Quote
Old 08-19-2015, 11:35 AM   #2
AtlasCC
Member#: 428267
2015 ImprezaHatch2.0
Deep Sea Blue
Get a new bolt. If you are doing more work on your car and you come across more nasty bolts use some liquid wrench first or something like that to prevent stripping or seizing.
AtlasCC is offline   Reply With Quote
Old 08-19-2015, 11:54 AM   #3
Dayglow
Member#: 211395
0000 4wfp Flintstone
Mobile made of stone+wood
I've had this happen before.
- If it's the bottom endlink bolt that can slide out, just get a new nut and bolt to fit
- If it's the top bolt fixed into the bushing, your endlink will need replacement. If there's enough thread to get a nut on there you can use epoxy to keep it from backing out but you'll have the cut the bolt to get the endlink off for replacement.
- If it's the bracket bolts just replace them with new nuts and bolts.
You get the idea.
Dayglow is online now   Reply With Quote
Old 08-21-2015, 01:35 AM   #4
DK-1-RI
Member#: 405855
2012 Sti
Thanks, I got longer bolt with same size. Problem solve. Got torque wrench now, so won't over torque anymore.))
Old 08-21-2015, 02:23 AM   #5
Sikk
Member#: 241662
2006 WRX VF48
I asked whiteline for another bolt when it sheared after 3 years they sent me a complete rear bolt kit for free.
Solid customer service
Sikk is offline   Reply With Quote
