Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2024
Old 10-17-2013, 10:19 PM   #1
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Default Blingstrom's 05 Sti STU build and lifted 06 Fxt
Welcome to my 05 STi build thread. This has been my dream car since the days of Sport Compact Car and Subaru's great days of rally in the early 2000s. Previous to this car I had a turbocharged 99 Civic Si which was a great car until I decided I wanted something else.
Then came my 04 WRB WRX which was a great car I drove and maintained for three years. Showed my friends and family what Subaru awd was all about and yet how reliable it could also be. Then a job change gave me a chance to put some money back and finally get what I had always wanted... The 05 STi.
04 WRX:
http://imgur.com/78YP9P2
1st day home 05 STi:
http://imgur.com/MRKNDSM
http://imgur.com/pkK0vw9
Purchased in June 2012 I found her in LIncoln, NE after searching for about 5 months trying to find a unmolested lower mileage car. She had 79k on her and what appeared to be a mostly clean and untouched under hood area. Only mod was invidia cat back. Sadly traded in the WRX that had been so good to me but instantly reminded after the test drive why I wanted the STi.
Current photo.
Morning view by Blingstrom, on Flickr
Mod list:
Exterior/interior:
OEM black carpet
Wingless trunk
Project Kics R40 lug nuts
06-07 diffuser
Pillerless STi grill
06-07 STi roof vane spoiler
Recaro sport seat
V-limited styled lip
STi floor mats
Carbon fiber wrapped stereo trim
Kartboy short shifter and bushing set
Grimmspeed Hood struts
Polk component speakers front/ JL rear
WRX interior swap
Suspension/Brakes:
Vorshlag high caster plates front
Feal 441 rear camber plates
Super Pro outrigger bushings
Cusco rear lower subframe bar
Whiteline 24 mm f/r swaybars
Whiteline upgraded rear mounts
Kartboy endlinks f/r
Feal 441s 7k/5k(Removed and upgraded to Feal 442s 9k/8k)
Super Pro steering rack bushings
Perrin rear differential bushings
TiC FCAR bushings
TiC fender cowl braces
TiC super sexy suspension kit
TiC tranny bushings
ATE Super Blue Brake fluid
Front KNS 4K brakes by DBA w/ EBC yellowstuff
Rear Centric rotors w/ EBC yellow stuff
Engine:
New Subaru short block with refreshed heads @103k
Group-N motor mounts
IAG turbo oil feed line
AEM air filter
Killer B oil pickup
Perrin V2 turbo inlet
Invidia catback
GrimmSpeed Ceramic coated and catted downpipe
Grimmspeed PNP ceramic coated manifold/uppipe
Mishimoto Radiator
Cobb v3 stage Protuned.
Odyssey lightweight battery and STM mount kit
Grimmspeed AOS - No longer on car.
Wheels:
SSR GTV02 17x9 et 45 w/ Bridgestone Re-71r 255/40R17
WInters Stock BBS w/ Bridgestone Blizzak Lm-32 225/45R17
Blingstrom is offline   Reply With Quote
Old 10-17-2013, 10:20 PM   #2
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Then in January after dealing with what I thought was a caster pull from a slightly unequal caster offset I bought some whiteline alks to correct it. Since then realigned the car to 1.6 degree of camber to help with turn in..One of the best mods.
http://imgur.com/2GhnKyW
Noticing a slight amount of oil from the passenger side of the head... Posssibly from swapping to synthetic. Went ahead and swapped out the old spark plugs and valve cover gaskets. Slight p/s leak as well and decided to get new orings and rebuild that. Swapped out the tranny fluid.
V-limited lip installed and a foam noodle cut down to fill in the side bolster the previous owner had worn down to the iron bar.Carbon fiber wrapped the stereo surround to round out the interior touches.
http://imgur.com/2ZM3Ki5
http://imgur.com/jobNkwa
Shortly afterwards I noticed a slight exhaust leak at full throttle. Looking underneath the car noticed that the downpipe to exhaust gasket was basic ally missing. So waited patiently for a good deal on an invidia catted downpipe and the first weekend we moved in I installed it. Stage II here I come.. Sadly the exhaust whistle was still there as I searched frantically to find it... Only to find a large crack in the stock manifold near the O2 sensor. Made the call to get Grimmspeed ceramic coated up pipe and exhaust manifold.
http://imgur.com/dlM5EQa
Cracked!
http://imgur.com/FmjIRDR
http://imgur.com/cA46Ghu
http://imgur.com/TSsb2aH
http://imgur.com/hIczZfS
Finally the car back on her feet.. No leaks everything running well I decided to go test her out on the highway. First third gear pull resulted in a smoked smelly clutch... Well time for a new clutch. At 89k and no idea how the previous owner had been on it... Exedy 15803 was attained and we were back to it.
http://imgur.com/C1Iiqpi
http://imgur.com/t8NT3Hu
Next up the exterior. Just before the clutch I got a moderate cleaning kit gathered around and the car got some major attention it had been missing. Then off to PDR to remove all the previous owners dents and get her back to shape. On the plate is some help from a friend on some slight paint correction and cleaning the headlights.
Looking forward to Feals 441 coilovers in the spring time and many more mods to come.
Old 10-17-2013, 10:23 PM   #3
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Old 10-17-2013, 10:27 PM   #4
Ryan25i
Member#: 241176
2007 WRX Limited
UGM
Nice STi man, 89k is pretty low miles for that old of a car. How are you liking the Grimmspeed exhaust parts? I'm thinking of getting their UP, DP, cross-pipe, and an Invidia cat-back this summer, basically your whole set up. Any sound clips?
Ryan25i is offline   Reply With Quote
Old 10-17-2013, 10:37 PM   #5
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Definitely a lot louder from just having the cat back exhaust. Spool seems to hit a lot harder but its hard to tell after having a cracked manifold for a few months. I am very happy with the current mid range power delivery.. can really feel the turbo come alive.
I unfortunately do not have any videos. I will see what I can do about getting a video up and some sound up. Might try to go out this weekend and if not then I will heading to the drag strip next friday. Get a few clips out there.
Old 10-17-2013, 10:40 PM   #6
Ryan25i
Member#: 241176
2007 WRX Limited
UGM
The power and spool is definitely what I'm most interested, the rumble is obviously an unnecessary but welcomed byproduct. What Invidia cat-back exhaust is it? Q300?
Don't forget to add a time slip with those videos.
Old 10-17-2013, 10:49 PM   #7
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
I believe its the N1 system and it was on the car when I got it. Seat dyno wants to think full spool is around 2800-3000 can really feel that torque imho.
Not going for any records at the strip but having pretty much everything worked on and ready to go I will hope for a low 13. Prob just slip the clutch and not go for the all out launch.
Old 10-27-2013, 04:29 PM   #8
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Head light revival with a DA and just some Meguiars scratch X.
Before
http://imgur.com/7WKbqc3
http://imgur.com/B8EXnwg
After
http://imgur.com/b5r1Rlr
http://imgur.com/RM8V2GT
Old 10-27-2013, 04:39 PM   #9
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
At the drag strip:
60ft: 1.958
E/T: 13.848 @ 100.39
Missed the shift into 4th =/. 50F degrees temp.
First time @ the track with this car and at the drag strip in ten years. No better runs than this.
Old 05-22-2014, 10:29 PM   #10
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Your NASIOC Administrator
Some new additions from over the winter months and spring. Added kart boy shifter and bushing kit to revitalize the old tired shifter. With a new shift knob as well.
Then onto some TiC fender cowl braces. Just amazing how they transform the chassis and decrease any flexing. Installation went pretty well.
Finally picked up my new suspension and enjoyed a late night installing it. Feal 441s 7k/5k. What a excellent upgrade over the stock suspension. Even passed the dreaded gf test.
Mega low shots from first installing it and not having time to adjust it yet.
And a shot of it adjusted and corrected.
Old 05-22-2014, 10:38 PM   #11
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Then after noticing some coolant seeping through the plastic end tanks of the radiator i decided i would upgrade before it blew out. Unfortunately my coworker wasn't so lucky and his soaked his whole engine bay.
Shot from work. One of the better days. Coworker, mine and customer's rally cross car.
Obligatory random shots.
Old 05-22-2014, 10:45 PM   #12
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Now anxiously awaiting my new wheels SSR GTV02 17x9 +45 with some Project Kics lugs and a new set of Re-11s 245/40. Thanks for looking!
Old 05-30-2014, 04:42 PM   #13
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Finally got my new wheels! A few quick shots from the driveway for now.
Old 08-22-2014, 10:00 AM   #14
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Thought I should update and post some of the summer adventures my car has been on.
@ Scoobapalooza
@ Some local car meet ups
Old 08-22-2014, 10:02 AM   #15
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
And some Auto-x
With the addition of grimmspeed hood struts and Aos setup.
Old 09-12-2014, 03:32 PM   #16
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Replaced the old worn stock seat with a recaro sport. Feels great and holds me in extremely well. Can't wait for my next long drive.
Old 09-19-2014, 03:28 PM   #17
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Few shots to add.
Old 09-19-2014, 03:58 PM   #18
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
BBS's are all ready for winter.. bring on the cold. Dipped with a black base coat and blue metalizer. Glossifier for that added touch.
Old 09-21-2014, 01:13 PM   #19
Ryan25i
Member#: 241176
2007 WRX Limited
UGM
Wheels look nice, it's amazing what plasti dip can do. How much did it run ya?
Also, what snow tires are you running? I'm looking at getting a set here soon.
Old 09-21-2014, 01:21 PM   #20
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Thanks. I think a little over 50 dollars. Have few cans with some leftover.
I have blizzak lm32s and had no issues with above bumper snow and non plowed streets. Smooth sailing all winter.
Old 09-21-2014, 03:57 PM   #21
pooster.online
Member#: 120461
Chapter/Region: PRSIC
Davi WRX STi JBP
DavidAgorsAJ
nice build; I like how everything done is very tasteful and well thought out!
The Recaro seat looks real nice, what'd I'd give to get a pair of those...
pooster.online is offline   Reply With Quote
Old 09-21-2014, 07:45 PM   #22
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Thanks a lot. I have put quite a bit of effort into and it is great to share and enjoy. Currently trying to figure out if I should do a STU build or go all out and find a different class.
It has put quite spin on things I used to think had my pathway ahead of me but now I trying to figure it all out. Was very keen on doing a motor build but now that would push into a new class where I wouldnt be very competitive. But currently just enjoying the car in autocross and will figure it out when I do. Autocross has really given me a lot more respect and enjoyment in my car and it capabilities. Everyone should go at least once.
Old 01-24-2015, 08:24 PM   #23
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Some updates. New full bushings in the rear from TiC from lateral links to trailing arms and some new tranny bushings. They have really transformed the car and I cannot wait for auto-x season to get here.
11 hours of pain.
Winter shot with my dipped winter wheels.
Old 01-24-2015, 08:28 PM   #24
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Long 2 hours of pain here also. New Perrin v2 turbo inlet... Unfortunately took out my purge valve but it spools up like a champ.
Old 01-24-2015, 08:32 PM   #25
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Lastly had a few hours today to snap this on. 3 hours of measurements but it appears to be as even as could.
