Old 10-17-2013, 10:25 PM   #1
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
Default Swapping from 7cm to 8cm on 68hta
I have a Baja Turbo with a FP 68hta and supporting mods. Motor is coming out tomorrow for either valve or rings (will find out when its out). I figured might as well do some minor mods while everything is out because I'm going to need a new tune regardless. So the FP 68hta that I have been running has a 7cm hotside and I'm looking to swap it to an 8cm.
FP wants $295 for theirs. I found them on Kinugawa for $135. They are both TD05H 8cm housings...
Will theirs work?
JungleFevre is offline   Reply With Quote
Old 10-18-2013, 10:24 AM   #2
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
looking to order soon bump
Old 10-18-2013, 10:52 AM   #3
wrxlaunch
Member#: 181298
Buy the fp... you may end up needing a new snail if u mix brands...
wrxlaunch is online now   Reply With Quote
Old 10-18-2013, 11:02 AM   #4
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
I purchased an FP 8cm housing before from someone here on nasioc. Paid $150 for it slightly used. Here's some additional info on the 7cm vs 8cm. http://www.mainelysubarus.com/forums...68-8cm-on-25l/
Subian is offline   Reply With Quote
Old 10-18-2013, 12:08 PM   #5
boostkreeep
Member#: 209880
2006 STI
white
Did it before when I had a 68HTA, any TD05H 8cm housing should work, I bought mine off ebay
boostkreeep is offline   Reply With Quote
Old 10-18-2013, 04:17 PM   #6
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
If your going larger, why not go ahead and do the 10cm?
bswilmington is offline   Reply With Quote
Old 10-18-2013, 05:19 PM   #7
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
I feel like 10cm would be way too lopsided for the 68hta. I was just wondering why one would cost twice as much as the other...
Old 10-21-2013, 02:16 PM   #8
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Dave D. had pretty good luck with his, from what i've read/saw 8cm might be a bit small on 2.5L cars with avcs. http://forums.nasioc.com/forums/show...ght=hta68+10cm
Old 10-22-2013, 04:24 PM   #9
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Yes, my tuner, Dom recommended the 10cm and the build has been very strong as hta68's go.
Eventually I am going to go to a 1.5xtr as the '68 is more sensitive to heatsoak from what I gather from Dom and examination of many dyno charts.
That's why this is such a good E-85 turbo. For example, my best dyno #'s were at 50 degrees. Dom did some fine-tuning last summer at 80 degrees and the same setup was up in relative hp when he was done, but still down almost 30hp on the dyno.
I did a few 60-90 4th gear pulls in the heat and got about 3.9 seconds consistently. The other day when it was 47 degrees I was getting 3.2 over several pulls (this is right in there with my 6.0 second 50-100 time in winter). The 10cm does help with the heat soak, especially on pump. If you run pump, 10cm is a no-brainer.
(By the way, I managed 5.4 sec 50-100 all in 4th without my cargo rack, but all I had was a stopwatch at the time. )
Dave D. is offline   Reply With Quote
Old 10-22-2013, 06:05 PM   #10
Leafy
Member#: 330625
2006 WRX
The kinugawa and FP housings are most likely both made by kinugawa.
Leafy is offline   Reply With Quote
Old 10-22-2013, 07:39 PM   #11
alexandern05
Member#: 266954
04 wrx v7 sti swap
agile tuned 389hp 342ftlb
If anyone has dyno charts of their hta 68 or one with each exhaust housing I'd be interested to see I have a hta68 on my ej207 it holds out good till around 7600 it starts dying pretty bad I was considering doing the 10 cm exhausting housing for better top end
alexandern05 is offline   Reply With Quote
Old 10-23-2013, 12:34 AM   #12
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Old 10-23-2013, 07:23 AM   #13
alexandern05
Member#: 266954
04 wrx v7 sti swap
Thanks I may try the 10cm housing on mine if I do ill post results over my current hta68 setup
