Old 10-18-2013, 11:55 AM   #1
In10city
Member#: 363489
2006 Subaru WRX STi
Default 06 STi spearkers! What do you got?
Trying to get some idea for some car audio, plan on replacing all 4 speakers with something with more punch!
Just curious to what set up other owners are succesfully running.
Looking for something more "plug n play" I dont really want to worry about spacers, depth, etc etc... Trying to take the guess work out of this next project!
Thanks!
*These will accent my Pioneer BT3300P AVH and a SO undeseat sub
In10city is offline   Reply With Quote
Old 10-19-2013, 05:53 PM   #2
802-303
Member#: 283194
Nothing speaker wise will be "plug and play" besides OEM in that car. You have less then two inches of clearance between door and window up front. And the rears are 4 inch and an odd layout.
You'll need to make spacers up front. I'd also recommend a 5.25 inch speaker for depth issues. (With spacers you still have less then 2.80 inches of depth)
Everyone cuts the rear doors to fit 5.25 inch speakers. It's very simple with an air saw, and depth is no issue.
My current set up ('05 wrx, same door cards as yours) has 5.25 Alpine type X pro components up front. (High quality w/o depth issues or shallow-mount design) And Focal 5.25 in the rear. Plus all the other amps, sub, exc. bits.
802-303 is offline   Reply With Quote
Old 10-21-2013, 08:29 PM   #3
ViperThreat
Member#: 351915
2006 Wrx Wagon
I picked up a set of 1" spacers from a local shop, they took a few minutes to install, and I put a bead of silicon around the edge to get a good seal, but otherwise not difficult to install.
My setup is:
Alpine SPS-610C 6.5" In the front
Alpine SPS-510 5.25" in the back
Speakers are powered by an Alpine MRP-F300 amp in the trunk
ViperThreat is offline   Reply With Quote
Old 10-22-2013, 04:12 AM   #4
Chicago77
Member#: 214488
2013 Impreza WRX
Dark Gray Metallic
Have; it's "what do you have" *sigh*
Chicago77 is offline   Reply With Quote
Old 10-26-2013, 11:26 AM   #5
Box This
Member#: 50149
15 Legacy
Looking for Baja Turbo
All of the modifications necessary to install upgraded speakers in the doors are fairly simple.
If you don't want to install spacers, or soldier wires together, honestly your best bet is to save money and pay an audio installer to do it for you because almost nothing fits in this car without modification.
The only thing plug n play you can do with aftermarket speakers, is mount some new speaker adaptors to the doors (as easy as using a drill and or self tapping screws) and cut the factory plug off the oem speakers. Soldier it onto the new speakers, and then the cars speaker harness will connect "plug-n-play" style to your new speakers.
Box This is offline   Reply With Quote
Old 10-27-2013, 11:02 AM   #6
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Do it right...please. if you don't get custom adapters (subaruaudio.net) at least get Subaru-specific ones from one of the other options. And pay the $14 for 2 pairs of Metra wiring adapters.
The simple fact is that you can't just pull out the stock speakers and cram aftermarket ones on the same spot. Even if the bbasket fits in the hole in the inner door skin and the magnet clears the window, you still have a poor seal.
phenryiv1 is offline   Reply With Quote
Old 10-29-2013, 09:50 AM   #7
hudsonvalleybugeye
Member#: 295068
2001 forester
As all say, do it right, If you don't, you'll eventually want to tear it all apart again because you'll wonder why you spent money on speakers that don't REALLY do their job.
As far as speakers go, I really like what memphis audio has been doing, I run them in my jeep tj and the quality is amazing, not to mention the sound of these things, I have them running off of a 4 channel rockford fosgate amplifier, but I did run them off of the head unit for a couple months while I waited to get off of work and for the weather to warm up. top down, doors off, still clear as anything. just amazing speakers and more than worthy to go into the sti.
hudsonvalleybugeye is offline   Reply With Quote
Old 10-31-2013, 02:56 AM   #8
vwbeaner
Member#: 257959
2008 STI
Do this^. Do it right the first time, check crutchfield.com they usually include all of the necessary hardware.
vwbeaner is offline   Reply With Quote
Old 10-31-2013, 11:24 AM   #9
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
I hate to disagree with someone who is saying that they agree with me, but...Crutchfield is NOT the best resource in this case.
The adapters that they sell are cheap plasic and really don't fit our cars (I have bought speakers form them and the adapters for Subarus are terrible). On top of that, Crutchfield only lists a speaker if they sell the mounting adapters to fit but the truth is that nearly any speaker will fit with custom mounting adapters. And speakers are typically cheaper somewhere like amazon or sonic anyway.
Wiring from Crutchfield is usually spot-on, but their "fit" guide is off if they don't sell/offer the right adapters. Heck, not a single speaker in my car (or the Legacy that I had before the WRX) "fits" according to Crutchfield.
www.subaruaudio.net for info on wiring, adapters/spacers, deadening, and a list of what speakers will fit in your car.
