Old 10-20-2013, 12:09 AM   #26
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Congrats Mike!
Junior2JZ is offline   Reply With Quote
Old 10-20-2013, 10:19 AM   #27
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
That is deff moving for sure
rexworx is online now   Reply With Quote
Old 10-20-2013, 02:08 PM   #28
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Congrats again man. We need more shopd like yours.
spoolinsti05 is offline   Reply With Quote
Old 10-20-2013, 08:22 PM   #29
AkumaMotorsports
Member#: 214570
Nice job Mike, keep up the good work.
John
AkumaMotorsports is offline   Reply With Quote
Old 10-21-2013, 09:43 AM   #30
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Thanks all!
It's our stage 2+ shortblock. We offer two common compression ratios on it and this is the higher of the two. This engine has big cams, but I made the same HP on a VF39 with stock cams in the 04 STI rally car I used to own so they're not helping with this turbo. The setup is compressor limited.
This is the second 10 second pass, the 10.96 at 123 MPH. On this one I must have magically found a spot with grip because it seems it would have held more power on the launch.
Video:
Innovative Tuning is offline   Reply With Quote
Old 10-21-2013, 11:01 AM   #31
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
My jaw dropped. Wow, too many records in such a short period of time. Give us some time to breath!!!
wgr73 is offline   Reply With Quote
Old 10-21-2013, 11:17 AM   #32
Drewswrx
Member#: 352498
2008 Wrx 2.5L
World Rally Blue
Thats awesome man, makes me very happy to know that our stock vf turbos are able to put out as well as handle a lot of power.
Drewswrx is offline   Reply With Quote
Old 10-21-2013, 01:05 PM   #33
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Originally Posted by Innovative Tuning View Post
Thanks all!
Wow, very nice! What cams are in this motor and do they help keep the HP band from falling off up top? Your HP holds very well for a stock turbo!
What is the CR of this motor?
Old 10-21-2013, 01:22 PM   #34
MorganJ
Member#: 203823
2009 WRX STI
2001 V7 JDM STI
Thanks all!
Video:
Subaru VF World Record (no nitrous), first in tens! - YouTube
Great run!!! I am still in awe at the torque monster this thing is. I want a big torque setup sometime soon.
MorganJ is offline   Reply With Quote
Old 10-21-2013, 02:02 PM   #35
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
The stock cam engine in my old rally STI held the same HP on the stock turbo. It's not the cams doing it. We didn't calculate the ratio, but in the 9s.
Old 10-21-2013, 02:02 PM   #36
ToneWrx02
Member#: 239095
2002 Wrx
Have to wonder how it feels to be in second or third gear at 2500rpm and out of nowhere get 500plus amount of torq.... neck breaking?
ToneWrx02 is offline   Reply With Quote
Old 10-21-2013, 02:11 PM   #37
MorganJ
Member#: 203823
2009 WRX STI
2001 V7 JDM STI
What kind of numbers would something like this put down on 91 octane?
Old 10-21-2013, 02:19 PM   #38
manitou
Member#: 193757
2006 XTI Limited
OK, Thanks! My EJ255 stock block VF48, E85 held 350WHP out to 6500-7K but you're making more HP up there. I know the higher 9.xx+ CR helps spool a ton. I'm seeing the help with spool on my 9.6:1 CR D25, cam'd build and a 58lb./min. SL turbo and I love it!
This thing is just crazy on the torque!! Where do you LC set for this beast? You look to be hooking up well and I'll bet your 60' will come down even more.
Old 10-21-2013, 02:29 PM   #39
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Without big tires it just breaks the tires loose when the torque hits all at once. Here's a video of a roll on in my old rally car and then some horsing around on a road course on Falkens. It made 400 wheel HP/ 450 wheel TQ on VF39.
I really couldn't guess accurately. I would never invest in a setup like this and then run "low" octane fuel. High compression with "low" octane is also a bad combination so results would not be great.
Old 10-21-2013, 02:35 PM   #40
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
I didn't have much time to play with it. If I can get back to the track I'll sort LC out. It actually spun worse when I launched at a lower RPM which was something new.
Old 10-21-2013, 02:41 PM   #41
manitou
Member#: 193757
2006 XTI Limited
Maybe it spun more launching at lower rpm's because the load in 1st gear was higher which would create even faster spool and more torque and spinning?
Old 10-21-2013, 02:42 PM   #42
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
There's less load in a shorter gear, but yes I needed to avoid the big torque spike at lower RPM to launch it without blowing the tires off.
Old 10-21-2013, 02:59 PM   #43
CatfaceType-R
Member#: 81102
CatfaceType-R is offline   Reply With Quote
Old 10-21-2013, 09:18 PM   #44
blk25rsti
Member#: 211942
1999 2.5RS coupe wht
01 2.5RS coupe BRP
Pics of setup?...
Please
blk25rsti is offline   Reply With Quote
Old 10-21-2013, 09:40 PM   #45
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
Originally Posted by blk25rsti View Post
Pics of setup?... Please
This^^^
SlimJim8804 is offline   Reply With Quote
Old 10-22-2013, 01:34 AM   #46
downsti
Member#: 63179
2006 Stock Turbo STi
[email protected] VF39
that is straight up a ****ing record and milestone that no one will ever break,
major props, now bring it to 10.5s hahah
downsti is offline   Reply With Quote
Old 10-22-2013, 09:35 AM   #47
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Pics of setup?...
Please
OK OK OK. Honestly it's a bit embarassing. This is not how we usually do things. I wasn't kidding when I said I decided to slap this together for the day. We really grabbed 2 pieces of steel pipe and a downpipe from our scrap piles and some random used couplers and clamps. I did use a new uppipe, but you can't see it and I didn't bother with an intake.
Thanks! You're one of the guys that really got the hunt going for a solid VF turbo record.
Someone will break this, but I'm the first to do a 10 and we really just slapped it on and did it so I'll still be happy when someone beats my time.
Old 10-22-2013, 10:19 AM   #48
CatfaceType-R
Member#: 81102
Oof, no IC. How does it run/tune compared to intercooled? Gotta love that e85.
Old 10-22-2013, 10:28 AM   #49
manitou
Member#: 193757
2006 XTI Limited
E85 FTW and the cushion!!
Old 10-22-2013, 11:24 AM   #50
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
I did run non intercooled at 33 pounds of boost on a GT35R back in 2006 for a while, but this car is intercooled. It has gold tape on it. You can see it in the shot of the haphazard charge piping.
