Closed Thread
Old 10-19-2013, 10:02 PM   #1
cyrustech999
Member#: 235136
2004 STI
Default turbo choice fp black hta vs. fp red hta
Ok guys I just finished my sleeved engine build need some advice on which turbo to roll with not rotated....
Mod list:
Darton sleeved 04 sti short block
Cp 9:1 pistons 99.5 std bore
Manley turbo tuff rods
2013 sti crank
Balanced with act lightweight flywheel and oem crank pulley
Heads are stock for time being
ID 1000's
Walboro 255
Tgv deletes
Pnp intake manifold
Turbo xs fmi
44mm ewg
Cobb ap
Custom 3" turbo back
Cobb 3 port e boost controller
Full 6speed with short throw
I'm trying to have that dd but at the same time a weekend warrior.
I built this sti from a rolling chassis to what it is now and if anyone can help me pick the right turbo that would be awesome....
cyrustech999 is offline
Old 10-19-2013, 10:21 PM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Both are WAY too big for stock location. While you might be able to get it/them to fit, you'd be losing out on a huge amount of power and spool by clinging to the inefficient stock location.
While I respect your commitment to stock appearance, you are absolutely wasting your time with this pursuit.
If you want to stay stock location, then stick with a <30r sized turbo. If you want anything bigger than that, then go rotated, you will be wasting your time by sticking with stock location on a turbo of FP red/black size.
the suicidal eggroll is offline
Old 10-19-2013, 11:01 PM   #3
gtasti
Member#: 152036
2004 Sti
I'd go 20g they are capable of 400whp
gtasti is offline
Old 10-19-2013, 11:07 PM   #4
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
Dom 3.5
Brother EddieJ. is offline
Old 10-24-2013, 02:44 AM   #5
cooter88
Member#: 270263
2004 STI
JBP
I just dyno'd 490hp 492tq on a Mustang dyno with a FP Black. I too wanted to keep stock location for my own reasons. This was on E85 at 27psi. Ive had nothing but good luck with FP products. Upgraded from the Green and love the Black. Your limited with your stock heads going with a Red or Black, that was my problem. Good luck with your choice bud, you'll be happy with either one.
cooter88 is offline
Old 10-24-2013, 12:51 PM   #6
TurboRex
Member#: 8635
04 STI, 07 FXT
I have the fp red. I gave it a conservative 360whp (delta dash road dyno) on pump 93 octane just wanting a quick but reliable car. So far, no problems. I have not tried to crank it up with better fuel. I have a mbc set at peak 22psi.
Good luck.
TurboRex is offline
Old 10-24-2013, 04:53 PM   #7
Shayhan27
Member#: 205906
05 WRX
CGM
Depending on fuel you may be limited with your setup. You already have the built block so get the Black and push it.
Shayhan27 is offline
Old 10-24-2013, 08:01 PM   #8
Member#: 51961
2005 STi
2012 WRX
The black is such a waste IMO unless you absolutely NEED to stay stock location. I mean 490whp on a 68 lb/min turbo on E85? Those are pump gas numbers. A turbo that big should be hitting well over 600whp on E85, but it just can't because the restrictive turbo inlet/intake and tiny hotside are holding it back. If you're looking for that kind of power, then stop *****-footing around and go rotated. The ATP 35R fits into the exact same category.
Old 10-24-2013, 08:10 PM   #9
cyrustech999
Member#: 235136
2004 STI
Il probably stick with my fp red I have already it is a journal bearing but il live until I can build my heads then go rotated
Old 10-25-2013, 04:43 PM   #10
cooter88
Member#: 270263
2004 STI
JBP
Completely true on the restrictive intake quote, not debating that at all. I wanted to still look stock appearing, not have to change downpipe and any other piping and I got a great deal on everything. Some people take different paths to get to their goals and some learn things the hard way. From what I know now Ill probably go rotated in the future once this turbo goes. For now it does what I need and I have no complaints. Good info for the OP "suicidal"
cooter88 is offline
Old 10-31-2013, 02:00 AM   #11
sexyyrex
Member#: 128022
2011 Infiniti G37x
Sedan
I love my red, but eggroll is right, if you have darton sleeves, why bother with inefficient stock location turbo's and go with a rotated GTX35R, decent spool with even better top end.
Final tune on 93 or e85? you'll need a bigger pump/injector if going e85.
good luck, cheers.
sexyyrex is offline
Old 11-07-2013, 11:10 AM   #12
cyrustech999
Member#: 235136
2004 STI
I decided to up the heads with a full gsc valvetrain cams are stock but I did that so I wouldn't beat the **** out of that new rpm range and I've considered the gtx 35 with the rotated setup when I come Into money
Old 09-22-2015, 01:33 PM   #13
The Rick
Member#: 72716
2004 WRX STi
Blue with the duals
Default FP BLACK stock internals?
Can you run the FP Black with stock internals?
The Rick is offline
Old 09-22-2015, 01:59 PM   #14
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Sure you can! However, longevity will be a concern if you decide to crank up the turbo to make more power.
RoadKillDMD is offline
Old 09-22-2015, 02:56 PM   #15
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
For about 10 minutes you can.
Unabomber is offline
Closed Thread
