Old 10-08-2002, 01:34 PM   #1
phillywrx
Member#: 19876
2014 Audi SQ5
Default wrx fuel filter replacement
is this as straight forward as it seems? i am hoping that when i go to disconnect the 2 tubes connected to the old filter that gas doesn't come flying out. is it pressurized? any other tips?
phillywrx is offline   Reply With Quote
Old 10-08-2002, 02:51 PM   #2
Rocky WRX
Member#: 9837
2002 White WRX Wagon
7800 ft
The fuel lines are left pressurized by the fuel pump long after the engine is shut down. Unless you don't mind having the engine (and yourself) sprayed with fuel, you should depressurize the fuel lines before disconnecting the fuel filter. To depressurize the fuel lines, reach under the passenger side dash and disconnect the green connector shown in this pic. That will disable the fuel pump relay. Then crank the engine for a few seconds (10-20?), to let the fuel injectors bleed off the fuel pressure.
Don't forget to reconnect the connector after you are finished replacing the fuel filter, and don't be surprised if it takes a few extra cranks the first time, before it starts up again.
Rocky WRX is offline   Reply With Quote
Old 10-08-2002, 05:04 PM   #3
shogunate83
Member#: 6006
Good job Rocky
shogunate83 is offline   Reply With Quote
Old 10-08-2002, 05:12 PM   #4
phillywrx
Member#: 19876
2014 Audi SQ5
Thumbs up
thanks very much for the post Rock. pictures and everything!
matt
Old 10-09-2002, 03:08 AM   #5
en3d
Member#: 5238
GGA Black
they're $18.xx on subaruparts.com. I would just order a couple since they are so cheap. I could have just imagined it but the car felt smoother after replacing mine, from now on I'm changing it at every 15k.
en3d is offline   Reply With Quote
Old 10-09-2002, 10:43 AM   #6
phillywrx
Member#: 19876
2014 Audi SQ5
one more question: the new filter appears different from the one i have in my car. the one i have now has a black top, and the new one is all silver. did they change the part?
Old 10-09-2002, 01:36 PM   #7
en3d
Member#: 5238
GGA Black
not sure if they changed the part but every replacement filter I've seen is silver.
Old 10-09-2002, 02:05 PM   #8
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
i just changed mine out, and i don't recall noticing the color difference. I picked up a Purolator replacement fuel filter.
I'll pop my hood and confirm that it has the black top
dave
dwmoss_68 is offline   Reply With Quote
Old 10-09-2002, 03:56 PM   #9
phillywrx
Member#: 19876
2014 Audi SQ5
my dealer finally returned my call. he said that the silver one is correct for the wrx, so they must have changed the part. the black one is almost a year old, so its definitely possible.
Old 10-10-2002, 01:12 PM   #10
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
I took a look just now at my replacement fuel filter,
the purolator replacement fuel filter
purolator part # F54668
has a black top
not that the color matters but.. for you info
2002 WRX fuel filter replacement question. Rx7TyreBurna Newbies & FAQs 11 10-07-2009 10:47 AM
Fuel Filter Replacement on 06 WRX bdon22 Newbies & FAQs 2 05-24-2009 07:23 PM
Fuel Filter replacement - where is fuel pump relay? SeenDubAYouAreEx Newbies & FAQs 4 07-11-2007 10:29 PM
Fuel filter replacement Shifter Service & Maintenance 3 08-31-2003 07:16 AM
Fuel Filter Replacement? Ryan24 Service & Maintenance 8 08-07-2002 11:59 AM
