Old 10-25-2013, 10:58 PM   #1
hoofhearted
Member#: 293554
Just wanted to share this with everyone. I plan on mounting it underneath the roof rails like in the pics.
Here is some info on the bar if anyone is curious . http://www.rigidindustries.com/SR-Se...-series-30.htm
hoofhearted is offline   Reply With Quote
Old 10-25-2013, 11:33 PM   #2
02boxer
Member#: 139853
2002 wrx....its tsxy
I've got 2 10" spots on my roof, and a 10" spectre in the air dam.....they have helped me give some deer lasik surgery quite a few times...
02boxer is offline   Reply With Quote
Old 10-26-2013, 12:30 AM   #3
4-n-zics
Member#: 228961
2016 4Runner TRDP
What camera is that behind your rear view mirror?
4-n-zics is online now   Reply With Quote
Old 10-26-2013, 12:30 AM   #4
tuanswrx
Member#: 342506
2011 WRX
Blk
that looks highly illegal, hopefully you can somehow mount it without blinding oncoming traffic.
tuanswrx is offline   Reply With Quote
Old 10-26-2013, 12:36 AM   #5
VanceRacing57
Member#: 355079
2011 Impreza WRX 5dr
LRP
^maybe you could wire it up to your hi-beams?
VanceRacing57 is offline   Reply With Quote
Old 10-26-2013, 02:09 AM   #6
hoofhearted
Member#: 293554
I don't plan on using it when I'm driving on public roads. Probably won't use it much at all to be honest. Just got the idea and wanted to do it.
Old 10-26-2013, 02:37 AM   #7
hoofhearted
Member#: 293554
It's this one http://forums.nasioc.com/forums/show....php?t=2468559.
Old 10-26-2013, 08:35 AM   #8
jojo69
Member#: 309196
2012 Hatch
wrb
sweeeet! I've been considering to do this since trs came out with their bars. I always wanted to see if it could be retrofitted lower, like if it could be hidden in the black plastic trim that goes under the license plate, upper bumper area... but not having one to testfit, i never pulled the gun on those bars! But up on roof rack is nice, I wonder if you will loose a bit of output from the front end of the car... Anyhow, can't wait for pics of install and after shots!
jojo69 is offline   Reply With Quote
Old 10-26-2013, 10:19 PM   #9
sidock
Member#: 304606
2012 STi
It can be used as driving lights allllll day (or night) long. Driving lights are intended to help and compliment high beams.
If you wired the relay to run this off the control for your high-beams, plus a switch of its own so you can use it as you please, you're in business!
sidock is offline   Reply With Quote
Old 10-27-2013, 06:48 PM   #10
hoofhearted
Member#: 293554
Originally Posted by sidock View Post
It can be used as driving lights allllll day (or night) long. Driving lights are intended to help and compliment high beams. If you wired the relay to run this off the control for your high-beams, plus a switch of its own so you can use it as you please, you're in business!
This thing is ridiculously bright. I could see it blinding oncoming traffic in the day time, night time forget about it.
Old 10-27-2013, 06:50 PM   #11
hoofhearted
Member#: 293554
This picture really doesn't do it any justice but it will give you a idea.
Old 10-27-2013, 07:37 PM   #12
02boxer
Member#: 139853
In all honesty....I wouldn't use any of these at full power in traffic ever. The beams are just too damn wide. I hooked up a cheap pwm switch to a pair of my single 10w spot lamps and even at 10% they were pretty damn intense all things considered. Hopefully in the near future the optics will sharpen up a bit
Old 01-12-2014, 06:28 PM   #13
hoofhearted
Member#: 293554
Finally got around to wiring the light bar in and it came out great, I didn't have to drill any holes which was awesome and I wired it into the rear defroster button in the car because I have had my car 2.5 years and haven't used it once.
Here is where I ran the two 16 gauge wires wrapped with tech flex wire loom. It fit in the gap perfectly and is held in by the lip of the windshield seal.
This didn't come out as clean as I would have liked. I originally planned to drill straight up into the roof rail and run the wires that way but there was just not enough room so this was the second best option.
This is the switch that turns it on. The rear defrost doesn't work anymore because I pulled the fuse.
Old 01-13-2014, 12:35 AM   #14
rkramer
Member#: 118209
2015 WRX Limitec
except it is HIGHLY illegal... Depending on the state, it may also have to be covered on any public road. 42" max height above ground for any auxiliary lights.
Old 01-13-2014, 12:41 AM   #15
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
If the lights are not on they will probably not be an issue, look at all the trucks w/ roll bar mounted lights.
The issue usually isn't that there are lights up there it's that you have them on blasting oncoming traffic with sunlight in their eyeholes. Also melting people's retina's through the rear view also is frowned upon.
Chances are cops won't really notice a light bar since it's a lot smaller profile than some 7" round light housings.
aerosaaber is offline   Reply With Quote
Old 01-14-2014, 09:53 PM   #16
hoofhearted
Member#: 293554
One last pic. The light is a lot brighter then before when I was running it off a 18v drill battery.
Old 01-14-2014, 09:59 PM   #17
lIRATIl
Member#: 136714
2012 WRX Sedan
I got one too and mounted it down here
lIRATIl is offline   Reply With Quote
Old 01-15-2014, 04:52 AM   #18
hoofhearted
Member#: 293554
Nice! What brand and model number?
Old 01-15-2014, 08:39 PM   #19
lIRATIl
Member#: 136714
2012 WRX Sedan
It's just a 22" ebay one. I'll be doing a Fuse LED 40" bar on my roof rack when I install it
Old 01-15-2014, 11:34 PM   #20
hoofhearted
Member#: 293554
What roof rack do you have? 40" might be to wide. The 2011 is about 36" or so wide if your using then stock roof rack mounting locations.
Old 02-03-2014, 07:15 PM   #21
Subie_Noob_Brian
Member#: 288037
2015 LightingRed WRX
11' WRX sold**14' XV sold
Here is my 40" bar. If you're interested in one PM me
Subie_Noob_Brian is offline   Reply With Quote
Old 02-03-2014, 07:18 PM   #22
apkarian100
Member#: 207053
2013 XV Crosstrek
No pics Brian. :/
apkarian100 is offline   Reply With Quote
Old 09-23-2014, 01:48 PM   #23
srt4Domocon
Member#: 238115
2011 StI
Blackish
Awsome i want to mount one in the lower grill
srt4Domocon is offline   Reply With Quote
Old 10-12-2014, 05:03 PM   #24
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
My buddy and I want t do these too for night rallyx.
Do you have more pics of the throw and width dispersion?
We are thinking the roof so that debris is less likely to shatter it.
chimchimm5 is offline   Reply With Quote
Old 07-20-2015, 05:03 PM   #25
wumfpirate
Member#: 179656
2010 WRX hatch
Very nice, been considering doing something similar
wumfpirate is offline   Reply With Quote
