Old 10-26-2013, 02:23 AM   #1
SynapseDynamics
Member#: 368534
05 STI
Default 2013/2014 WRX hatch and factory 10" kicker
So after about an hour of searching on this, there seems to be a lot of ambiguity on this, so I figured I'd make a post to get some direct answers. I have a 2014 hatch and was looking at getting a sub, but I'm a little confused on the wiring.
Is the factory 10" kicker a plug n play kind of deal (is the wiring already there ready to plug in), or does the head unit have to come out, etc.
Also, I had a 12" JL in my 2004 WRX in a fat box and it sounded great, and I don't expect this 10" in a tiny enclosure to sound that good, but am I better off going a different direction with this? If I get a different sub/amp, could I use whatever wiring is already there instead of getting an LOC and splicing into the speakers?
Has anyone done this?
tl;dr I need my bass.
SynapseDynamics is offline   Reply With Quote
Old 10-28-2013, 06:24 PM   #2
scoe141
Member#: 357467
2014 WRX
Check out this .pdf.... I couldn't find 2014, but hopefully this will point you in the right direction.
http://techinfo.subaru.com/proxy/724...H630SFJ100.pdf
scoe141 is offline   Reply With Quote
Old 10-29-2013, 08:27 AM   #3
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
It's a **** of a lot of wiring. If you're going to do it, you might as well get a real subwoofer because there's no prewiring. You do it all yourself.
goregasm is offline   Reply With Quote
Old 10-29-2013, 06:19 PM   #4
js0uth
Member#: 283125
2011 wrx hatch
Obsidian Black Pearl
i suggest u just get it professionally installed. i believe there was a rca converter and one more other thing needed.
i had set of components and coaxials and a 12in sub installed on my factors head unit on my 2011 hatch.
js0uth is offline   Reply With Quote
Old 10-30-2013, 10:12 PM   #5
MatthewB10
Member#: 320973
2012 WRX
Ice Silver Metallic
I'm assuming it's the same sub as a 2012, so hopefully this helps.
I installed mine as soon as I got my WRX. It's very straight forward. All you're doing is adding one wiring harness. The harness plugs into the back of the head unit, and then runs down the drivers side to the rear, and plugs into the sub/amp. It took me less than an hour.
Now, it's not going to sound like your old sub. It doesn't have that kind of air space or power. But it does add a noticeable thump. Especially in hatches. Being that the box isn't huge, it can't get way down low in the frequency range, but I still like it a lot.
MatthewB10 is offline   Reply With Quote
Old 11-06-2013, 12:31 PM   #6
MBelair79
Member#: 363805
2015 WRX Limited
Crystal White Pearl
Just an FYI in a month or so from now, OEM Audio + will have a full drop in plug and play system for both the hatch and sedan models. The only wiring will be the power for the two amps that get installed.
MBelair79 is offline   Reply With Quote
