Old 10-08-2002, 05:23 PM   #1
wackie
Member#: 14580
2004 Forester XT
www.wrxhackers.com
Question Injector size question for my application (PE1820)
I noticed most people are running the STi injectors. I was curious if the PE1820 with the proper supporting mods would be able to surpass the output of the 550cc/min injectors. I was thinking of getting RC Engineering low impedance injectors (since I'm running the UTEC) and I wasn't sure if I should get the 550's or 650's. The 650's sure are a big jump in price, but if it's going to be much safer I'd like to go that route.
Oh yeah, I plan on attending some open track days at local road tracks. Possibly a few trips to the drag strip, but that's not really my thing.
Thanks
JD
webmaster@wrxhackers.com
www.wrxhackers.com
wackie is offline   Reply With Quote
Old 10-08-2002, 06:09 PM   #2
Austin
Member#: 7089
05 Legacy GT Sedan
07 4Runner Limited
Even with the small VF29, my 550's were at 85% duty at 17psi at 5400 rpm at 43.5 psi static fuel pressure.
You can definitely max out a set of 550's with the 1820.
Another alternative to getting 650's is to upgrade to parallel fuel rails and an adjustable fuel pressure regulator.
If an injector is labeled a 550cc injector, that is at 43.5psi static pressure. If you up the pressure one more bar to 58psi, those 550cc injectors become 635cc injectors.
I wouldn't go any higher than 60psi static fuel pressure though.
Austin is offline   Reply With Quote
Old 10-08-2002, 06:41 PM   #3
wackie
Member#: 14580
2004 Forester XT
www.wrxhackers.com
1 bar of extra pressure seems like quite a bit. Is that something the standard 255lph Walbro pump can handle?
downpipe size for my application Suberman Factory 2.0L Turbo Powertrain 1 05-28-2007 07:06 AM
Injectors TOO big for my application???!!! saab-on-the-cobb Factory 2.0L Turbo Powertrain 2 06-02-2006 04:15 PM
Best Downpipe for my application? RobPA Factory 2.0L Turbo Powertrain 5 03-26-2002 02:57 AM
Which aftermarket turbo is best for my application? Mr.Freeze Factory 2.0L Turbo Powertrain 4 03-05-2002 08:27 PM
What's the best box for my application? CRAZY KEN Car Audio, Video & Security 1 02-15-2001 07:33 PM
Message Board Statistics All times are GMT -4. The time now is 03:58 PM.
