Old 10-08-2002, 06:38 PM   #1
scrmnsmn
Member#: 8299
Midnight Swirl
Thumbs up Stage 2 Utec
I received my Utec today. It's set up for the Stage 2. Got it all hooked up and took a spin. It's nice to have some more boost again. It feels smoother than my Unichip and smoother than my stock ECU. It's running really rich though. After 15 minutes of "spirited" driving, there was quite a bit of soot at the tip of the exhaust. Unfortunately my s***box laptop has a bad battery so I can't do any tuning yet. It's probably just as well because I have no idea what I'm doing. Are there any other Stage 2 people out there?
Chris
scrmnsmn is offline   Reply With Quote
Old 10-08-2002, 06:41 PM   #2
scrmnsmn
Member#: 8299
Midnight Swirl
Nice black box.
Old 10-08-2002, 06:45 PM   #3
scrmnsmn
Member#: 8299
Midnight Swirl
I ran the serial cable up through the ash tray. I dremeled a slot in the bottom of it and fed it through.
Old 10-08-2002, 06:49 PM   #4
xfactor834
Member#: 12506
Very innovative ashtray trick.
Some people fed it through the glovebox, but I dunno how tight of a fit that'd be, especially after repeated opening/closing of the glovebox.
xfactor834 is offline   Reply With Quote
Old 10-08-2002, 07:05 PM   #5
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
Default Re: Stage 2 Utec
Chris
Nice...
where did you ground your UTEC to?
ScoobieSnaX is offline   Reply With Quote
Old 10-08-2002, 08:16 PM   #6
scrmnsmn
Member#: 8299
Midnight Swirl
Default Ground wire
I don't know if this is a good idea, but it seems to be working.
Old 10-08-2002, 08:18 PM   #7
scrmnsmn
Member#: 8299
Midnight Swirl
It's hard to see, but it's attached to the door hinge.
Old 10-08-2002, 08:22 PM   #8
nekard
Member#: 12927
2002 Impreza WRX
I ran the serial cable underneathe the passenger seat where there is a slit in the carpet and I grounded it to the factory ground under the carpet by the door. What exactly is the accessory connection for and is that battery thing for if i want to hook it up to my home PC? You just use HyperTerminal to program and log right? No cool graphs or software, correct? I might need your Stage2 map because I think they sent mine with stage 1.
nekard is offline   Reply With Quote
Old 10-08-2002, 08:34 PM   #9
scrmnsmn
Member#: 8299
Midnight Swirl
I'm not sure what the accessory connection is for. Maybe some future upgrades? With the battery hooked up you can use your home PC to download maps. I haven't finished reading the instructions yet. My Stage 2 is map 1. Before I put it in my car, I hooked it up to my PC to be sure that Stage 2 was on it. The maps are supposed to be available on the TXS web site any time now. They also have dyno plots up for the Utec Stage 1 and Stage 2.
Chris
txs stage 2 utec question! Electronsmurf Engine Management & Tuning 4 03-01-2003 12:13 PM
TurboXS Stage 2 UTEC Sublime5260 Engine Management & Tuning 2 02-14-2003 02:56 PM
Stage 2 UTEC boost question SubiDo Engine Management & Tuning 2 10-28-2002 04:07 PM
Stage 2 Utec datalogging scrmnsmn Engine Management & Tuning 4 10-23-2002 06:53 PM
Need a stage 2 UTec Map crazyhorse Engine Management & Tuning 7 10-07-2002 01:27 PM
Message Board Statistics All times are GMT -4. The time now is 03:50 AM.
