Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 10-29-2013, 02:02 PM   #1
lukeslick
Member#: 314564
SRP
Default 8 psi of boost no bueno
alright so here it is had my car data logged with a tactrix cable, it was showing my peak boost was only about 8 psi. what all could be causing this?
i have been thinking that there is a boost leak some where due to the turbo builds the pressure. is there anything els that could be causing such low boost levels? i can get other info off the program if it helps. Yes the pill is in the vacuum line
lukeslick is offline   Reply With Quote
Old 10-29-2013, 02:09 PM   #2
m4r10
Member#: 41877
02 wrx
mods?
m4r10 is offline   Reply With Quote
Old 10-29-2013, 02:11 PM   #3
Tripperfx3
Member#: 242966
2005 WRX
Rally blue
What RPM are you hitting 8psi and do you have any mods? Isn't 8-10 psi stock on the 02-05 WRX's?
Tripperfx3 is offline   Reply With Quote
Old 10-29-2013, 02:15 PM   #4
lukeslick
Member#: 314564
SRP
Mods are pretty light, lighten flywheel, stage 2 clutch, headers to full turbo-back exhaust
and im hitting at about 6k rpm in 3rd, im flat out and only getting 8psi
Old 10-29-2013, 02:16 PM   #5
lukeslick
Member#: 314564
SRP
and this is a 2002 wrx wagon.
Old 10-29-2013, 02:22 PM   #6
Drowner
Member#: 49297
14 Focus ST3
are you tuned at all?
Drowner is offline   Reply With Quote
Old 10-29-2013, 02:31 PM   #7
lukeslick
Member#: 314564
SRP
not since i owned it, or the guy before me
Old 10-29-2013, 03:24 PM   #8
Cocoa Beach Bum
Member#: 17355
8 PSI max boost is what you would expect when the vacuum line between the turbo outlet and the wastegate controller is missing the restrictor (aka "pill"). I bet this car once had an aftermarket boost controller installed.
Cocoa Beach Bum is offline   Reply With Quote
Old 10-29-2013, 04:20 PM   #9
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
You're never going to get full boost at 6k rpm on that tiny turbo. 8 psi sounds about right at that rpm, you need to be closer to 3-4k in order to see peak boost, it tapers off pretty quickly above there.
Old 10-29-2013, 04:24 PM   #10
hudsonvalleybugeye
Member#: 295068
2001 forester
8psi is the wastegate spring pressure, something is wrong with your boost control system, check your control solenoid and for leaks in your vacuum lines. did this happen out of the blue or has it been like this?
hudsonvalleybugeye is offline   Reply With Quote
Old 10-29-2013, 05:40 PM   #11
lukeslick
Member#: 314564
SRP
this has happend since i owned the car, and i just now got the car data logged
Old 10-29-2013, 05:58 PM   #12
norazi-j
Member#: 300350
2016 WRX STI
+1 for this. When my 04 STI was running 8lbs, i found I was missing my restrictor pill and also needed a new boost control solenoid. Runs like a champ now.
norazi-j is offline   Reply With Quote
Old 10-29-2013, 06:26 PM   #13
marvzz
Member#: 328624
03 WRX
what is stock boost pressure supposed to be?
marvzz is offline   Reply With Quote
Old 10-29-2013, 07:26 PM   #14
lukeslick
Member#: 314564
SRP
thank you for that, if i don't have the restrictor pill, where can i buy one and how much would they be?
Old 10-30-2013, 02:57 AM   #15
J-mez
Member#: 292727
You can buy one of the pills at a dealership for like $0.40 i think, or maybe a few dollars, not expensive at all. I actually have an extra one, unfortunately you live on the opposite side of the country. I could probably mail but it'd be faster to get it from the dealership.
J-mez is offline   Reply With Quote
Old 10-30-2013, 09:47 AM   #16
lukeslick
Member#: 314564
SRP
alright well thank you J-mez for the offer, i will be going to the dealership this weekend foor sure then!
Old 11-02-2013, 02:39 PM   #17
lukeslick
Member#: 314564
SRP
Alright so I broke down and looked and I found that my car did have the restrictor pill installed.
Old 11-02-2013, 02:50 PM   #18
575rider
Member#: 112024
03 hybrid 6spd wgn
Santa Cruz Bronson-Carbon
~13psi
575rider is offline   Reply With Quote
Old 11-02-2013, 02:52 PM   #19
hudsonvalleybugeye
Member#: 295068
2001 forester
Like I stated before, very likely could be your boost control solenoid. Check all of the hoses from your boost control solenoid for leaks and or cracks. do you have a boost gauge?
Old 11-02-2013, 03:35 PM   #20
Member#: 51961
2005 STi
2012 WRX
Cracks and leaks in the boost control lines will raise the boost, not lower it.
Old 11-02-2013, 04:01 PM   #21
hudsonvalleybugeye
Member#: 295068
2001 forester
ahhhh yes (I have'nt worked on a subaru it too long ) I need to get back in the game, my money's on the solenoid itself!
Old 11-02-2013, 08:51 PM   #22
lukeslick
Member#: 314564
SRP
i replaced all of the vacuum lines when i checked for the restrictor pill so all the lines there are new.
as for a boost gauge i do not have one.
Should i like to get a new OEM Boost solenoid or go with an after market one?
Old 11-02-2013, 09:03 PM   #23
Member#: 51961
2005 STi
2012 WRX
i replaced all of the hoes when i checked for the pill
345
Old 11-03-2013, 12:09 AM   #24
Back Road Runner
Member#: 60082
2004 Forester STI
I had this problem when I had a bad coil. This put the ECU into a limp mode of some sort where it wouldn't attempt to make boost beyond what the turbo could passively do.
Are you getting any CEL codes at all? I will note that it may take a while for one to pop up, like a couple weeks long, or 15 minutes. It's kind of weird how Subaru generates codes sometimes based on whatever parameters it's trying to look for.
Old 11-03-2013, 02:13 PM   #25
lukeslick
Member#: 314564
SRP
Nope no codes what's so ever. I also just picked up a Cobb accessport today
