Old 10-31-2013, 01:27 PM   #1
ultramario12
Member#: 306139
2007 evo
color of smoke
Default which sway bar did you chose?
if you have an '11Plus wrx which sway bar size and manufacturer did you chose?
not a fan of semi body roll and feel the handling is a little loose, i want to experiment with sway bars. Trying to get a general idea what most people were satisfied with for a DD
ultramario12 is offline   Reply With Quote
Old 10-31-2013, 02:10 PM   #2
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Whiteline 24mm front, 22mm rear. Plenty of 2011+ sway bar opinion threads out there already.
Mr Wrex is offline   Reply With Quote
Old 10-31-2013, 02:50 PM   #3
ultramario12
Member#: 306139
2007 evo
color of smoke
i looked in the sticky and didnt see any. and on the 2 pages of brakes../.../ suspension didnt see any either. I'll try the search next time though. and a lot of the sway bar opinions are dated and you have to scramble for the newer models
Old 10-31-2013, 03:01 PM   #4
SpaceJam23
Member#: 332637
2012 STi
I went with 22mm Front and 22mm Rear, whiteline adjustable. Medium setting in the rear, and hard up front. So I think that translates to 23mm front/22mm Rear technically.. I have a friend who has some if you're interested.
SpaceJam23 is offline   Reply With Quote
Old 10-31-2013, 04:23 PM   #5
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Same exact year as you:
http://forums.nasioc.com/forums/show....php?t=2078457
Excerpt from this:
4) 22mm front & rear 08+ or 24mm front & rear 02-07
This is my personal choice for the street and street tire autocross. The equal sized rear bar gives the car a more neutral feel. It really does a lot to counteract the car's tendency to understeer. I use this combination on my daily driver and with adjustable swaybars it can be set up to perform well on the street, track and autocross course.
5) 24mm front / 20mm rear 08+ or 27mm front / 22mm rear 02-07
The large front bar will provide a great turn in feel with this combo while the small rear bar will keep the car from oversteering much. If you want to keep all four wheels on the ground and have a solid turn in feel this may be a combo to consider. To me this isn't a very neutral feeling combo. When I drove a car with this combination it understeered quite a bit.
6) 24mm front / 22mm rear 08+ or 27mm front / 24mm rear 02-07
This is another popular combination... Probably just as popular as combination #4. The stiffer front bar will give the car an improved turn in feel over combination #4. I find that this combination doesn't feel as neutral on street tires as combination #4. To me it feels like it gives you a flatter, better turn in feel at the expense of over all grip. If you are on a smooth track with grippy tires this is a different story. This combo is perfect for someone who does track days or time attacks. It is also the preference of many for daily driving. It does give more noticeably better handling than combo #4 for daily driving. It just doesn't suite my personal driving style as well as #4 does. National autocross champions have also confirmed that a bar this large in street tire autocross tends to make the car understeer. The fastest street tire autocross STis in the country for the past few years have used very soft front bars in combination with very stiff coilovers.
Old 11-02-2013, 03:22 PM   #6
jaboyd
Member#: 247304
2011 STI
WR Blue
Swaybar choice is subjective and based on driver preference, use, other mods and enviornment. For a stock setup for DD in most climates a 22mm frt/rr is a good setup and will accommodate autox use. In general I prefer sway bars that the same dia or within 2mm along w/moderate spring rates. Since I live in the south with smooth roads, minimal winter conditions and have upgraded suspension, I run 24mm frt/rr. I run mine set soft in front (23.5) and rear (23) for DD, along with 500# springs frt/rr. If I lived in the north I'd probably get 22mm frt/rr.
jaboyd is offline   Reply With Quote
Old 11-03-2013, 03:24 AM   #7
laserwrx
Member#: 143437
2011 Wrx premium
WRBlue
I have the same on my 2011 .
I also have tein superstreet coilovers and a cusco tower brace.
This has given me more of a oversteer feel
laserwrx is offline   Reply With Quote
Old 11-03-2013, 12:31 PM   #8
SW21MR2
Member#: 60135
2005 Kona Stink-E
I went with the OEM STi rear sway bar. At about $75 shipped, it was rather a big improvement for the cost.
SW21MR2 is offline   Reply With Quote
Old 11-03-2013, 02:26 PM   #9
Dmochowski
Member#: 306478
2012 WRX limited
305whp/360tq TSM tuned
i have perrin and KB EL bc the perrin were cheaper. I dont drive a race car so paying 50 dollars for a bar that basically does the same job for my DD was silly to me. Other ppl have different priorities though.
Dmochowski is offline   Reply With Quote
Old 11-03-2013, 05:35 PM   #10
550_Cord
Member#: 362728
2012 wrx hatch
PBP
I have 22/24 superpro sway bars, superpro rear end links, whiteline front end links.
550_Cord is offline   Reply With Quote
Old 11-03-2013, 06:14 PM   #11
Sidewinderpb
Member#: 312048
2011 BMW e92 335i
BSM
Just installed the same setup. So awesome!
Sidewinderpb is offline   Reply With Quote
