Old 10-08-2002, 10:44 PM   #1
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
Question Could rich condition cause CEL (UTEC)?
Well I finally got my FJO wb02 hooked up tonight and did some data logging. Each WOT run showed 10.0:1 @17-18psi!!!!
Could this cause the engine to missfire and throw a CEL?? I replaced my plugs today and I'm still getting a CEL.
Any insight would be appreciated
ScoobieSnaX is offline   Reply With Quote
Old 10-08-2002, 10:55 PM   #2
davidm_sh
Member#: 5994
2004 Impreza WRX STi
Java Black
I think I will say YES!! If you are in the 9:1 range of rich (which is possible since FJO only goes to 10:1 max rich) then you will have the possibility to detonate/misfire from having too much static compression caused by too much fuel in the cylinder.
I would definitly lean things out a bit until you get to AT LEAST 10.5:1 range and go from there.
davidm_sh is offline   Reply With Quote
Old 10-08-2002, 11:00 PM   #3
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
Great. Thanks. I guess I'll lean it out. I've had a few specs of detonation here and there so I might have to take out some timing....which spawns another question....
The stock stage4 map has a max advance of ~26 degrees in the upper range. Where should I start? Should the timing have a nice "curve" to it or can you have spots of 24 degrees and spots of 26 here and there?
Thanks,
ScoobieSnaX
Old 10-09-2002, 10:09 AM   #4
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
curve.... up and down is going to be realllly herky jerky
ALSO.... before you screw with fueling.. give the car about 4-5 days of driving around for LFT to set... you'll find that day by day it's going to change. Trust me on that....
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Intake causing rich conditions? wrspssshhhh Engine Management & Tuning 5 08-05-2005 10:46 AM
Possible for road condition to cause CEL? ezatnova Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-19-2003 11:10 PM
Correction of MBC Rich Condition wigglesxjr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-08-2001 03:07 PM
WOT rich condition.... SilverSubie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-23-2001 09:20 PM
Rich run condition causing CE light RebelINS Normally Aspirated Powertrain 2 03-30-2001 07:25 AM
