Old 11-02-2013, 04:34 AM   #1
Subbie n00b
Member#: 324558
2004 Impreza WRX
Default Strange noise when letting go of gas petal
Hey guys as anyone ever experience a noise when they let go of the gas while still in gear? My vacuum would hit like 24 mm Hg and then I would hear a "kur kur kur kur kur" sound. I used to do this like when I'm doing 60 mph and down shifting to 3rd gear to slow down. I then let go of the petal and the sound would starting going
It just doesn't sound right so I stopped Downshifting and just go to neutral and use my brakes :/
anyone ideas?
PS: I did have an engine swap before (stock 2.0 ej205)
Subbie n00b is offline   Reply With Quote
Old 11-02-2013, 07:49 AM   #2
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
Kur Kur Kur Kur Kur Kur
Loyale93 is online now   Reply With Quote
Old 11-02-2013, 07:55 AM   #3
Jacobs11
Member#: 268948
04 WRX
PSM Sold :(
Sounds like some afterfire? I could be totally wrong though, so don't take my word for it. If it is, you're running a little rich and the sound is unburnt fuel igniting in your exhaust.
This may have some answers
http://forums.nasioc.com/forums/showthread.php?t=943086
Jacobs11 is offline   Reply With Quote
Old 11-02-2013, 03:47 PM   #4
Subbie n00b
Member#: 324558
2004 Impreza WRX
No, its definitely not the exhaust. I cant hear it when I have music playing at a normal volume. I feel like its coming from my tranny somewhere.
Old 11-02-2013, 08:46 PM   #5
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
maybe one of the mounts is failing and it's letting stuff bang around.
inspect the pitch stop mount (top of engine to firewall) and the other mounts as well.
could be something was misaligned a little to begin with and now it's moving around more and banging into ****.
aerosaaber is offline   Reply With Quote
Old 11-06-2013, 06:31 AM   #6
Subbie n00b
Member#: 324558
2004 Impreza WRX
So I wet to Subaru to get it checked out. Turna out my alternator pulley was about to snap any minute so had to get that replaced.
The mechanic there said its either the catalytic converter is loose or I have shaft play in my td04
Old 11-06-2013, 08:19 AM   #7
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
Originally Posted by Subbie n00b View Post
So I wet to Subaru to get it checked out. Turna out my alternator pulley was about to snap any minute so had to get that replaced. The mechanic there said its either the catalytic converter is loose or I have shaft play in my td04
the mechanic said the noise your hearing is either the catalytic converter or shaft play? Where is the noise coming from, does it sound like it's coming from under the shifter or under the hood?
booSTin-scoobs is offline   Reply With Quote
Old 11-06-2013, 08:28 AM   #8
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
my bad didn't see this where you said tranny. Sounds like it could be a few different things...
1. Pilot bearing could be bad, I say this bc the sound on comes while the clutch is disengaged and not when engaged.
2. It could be clutch chatter but I dount that's the case.
3. Could be your gearbox going bad, how many miles are on the tranny anyway? And which tranny do you have?
4. Could be something as simple as tranny fluid, have you checked your levels? Start with the cheapest fixes until you figure out the problem. If
I were you I would drain all the tranny fluid and replace it with a good cocktail. Grimmspeed offers a complete cocktail and it's only like $40 or $50 bucks. This of course is assuming you haven't already changed the tranny fluid or done it recently.
Old 11-06-2013, 07:59 PM   #9
Subbie n00b
Member#: 324558
2004 Impreza WRX
I feel like its coming from under my gas petal. And the noise comes up when the clutch is still engaged but no acceleration.
And no I have not checked tranny fluid
Old 11-06-2013, 08:28 PM   #10
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
You need to take a video of this. At this point we're all just guessing random noises that could happen.
The word is "pedal". Petals are on flowers. Pedals are underfoot.
Silly subbie.
PS - "subbie" still makes me laugh.
Old 11-06-2013, 08:47 PM   #11
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
I feel like its coming from under my gas petal. And the noise comes up when the clutch is still engaged but no acceleration. And no I have not checked tranny fluid
check the fluid. So your saying you hear the noise when your holding the clutch in (engaged)?
Old 11-06-2013, 08:48 PM   #12
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
Originally Posted by Loyale93 View Post
You need to take a video of this. At this point we're all just guessing random noises that could happen. The word is "pedal". Petals are on flowers. Pedals are underfoot. Silly subbie. PS - "subbie" still makes me laugh.
im glad you said something so I didn't have to lol
Old 11-07-2013, 04:10 AM   #13
Subbie n00b
Member#: 324558
2004 Impreza WRX
You know if I could change my username I would. Clearly correcting my spelling is a lot more important than helping a fellow "Subie" owner. So you know what cheers to you man for making this forum about spell check.
On the other note, I'll try to record the sound and somehow filter wind noise out.
Old 11-07-2013, 06:53 AM   #14
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
You know if I could change my username I would. Clearly correcting my spelling is a lot more important than helping a fellow "Subie" owner. So you know what cheers to you man for making this forum about spell check. On the other note, I'll try to record the sound and somehow filter wind noise out.
what're you mad at me for? I didn't say anything. The only thing I did was give you the possible problems going on with the sound you're describing and saying coming from the tranny. No one else in this thread before me gave you any kind of help that made any sense at all. So I'm not sure what your problem with me is.
Old 11-07-2013, 06:56 AM   #15
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
also, it's not a bad tranny mount, wanna know what happens when you have a bad tranny mount? You hit the gas hard or hit the gas normally while starting off on a upwards hill...that tranny smacks off the car making a loud ass noise. It won't be repetitive though, it will be loud and scare the **** out of you and make you pull over. Also your vac going to -24 is completely normal
Old 11-07-2013, 01:00 PM   #16
Subbie n00b
Member#: 324558
2004 Impreza WRX
Oops, I think I should have quoted loyale93 for getting mad. Any how I'll try to get it recorded today. Kinda hard to get a good sound and drive efficiently. Only happens at higher speeds
Old 11-07-2013, 01:17 PM   #17
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
do you mean high speeds or high rpms
Old 11-07-2013, 02:06 PM   #18
Subbie n00b
Member#: 324558
2004 Impreza WRX
Over 30mph lol, if that's high
Old 11-07-2013, 02:41 PM   #19
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
Spell check wouldn't have helped you, since petal is a word as well. Just trying to help. If you do a search for "noise behind petal", you'll get this thread and some stuff about bees, most likely. But if you search for "noise behind pedal" you might actually get information you are looking for.
Spelling counts.
And I was helping out a fellow Subie owner. I told you to take a video so that we can actually hear what it sounds like and where it's coming from. If you notice all the gueses above, they range from a deer getting caught in the radiator piping, all the way up to
The video will help. Do that.
Old 11-07-2013, 05:54 PM   #20
Subbie n00b
Member#: 324558
2004 Impreza WRX
Old 11-07-2013, 07:51 PM   #21
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
theres no sound to the video?
Old 11-07-2013, 08:34 PM   #22
Subbie n00b
Member#: 324558
2004 Impreza WRX
There is in mine, maybe update your flash player?
Old 11-07-2013, 08:44 PM   #23
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
im on my phone
Old 11-07-2013, 08:46 PM   #24
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
nvm I fixed it, that sounds like a lawn mower. It's really hard for me to say what I think it is without hearing it in person but I don't think that's the tranny
Old 11-08-2013, 02:08 AM   #25
Subbie n00b
Member#: 324558
2004 Impreza WRX
Yeah, I wouldn't be posting this if I knew the problem lol.
It's defiantly not the tranny but the mechanic at Subaru said either loose cat (my downpipe is not aftermarket, only exhaust is after market) or a shaft play on my turbo sounds really lucid at this point
