Old 11-05-2013, 02:23 PM   #1
bmini_615
Member#: 372867
Default Turbo Questions.
Hello, I am new to the subie game. I just bought a 2002 bugeye. The block is out of a 2005 sti, but it has stock heads, etc. Im trying to figure out what turbo would be best for me. But I still want the car to be reliable, but quick. the mods I have currently are a cold air intake, full 3 inch cob exhaust, bigger tmic, cobb tuner, upgraded 2005 wrx tranny, stage 2 exedy clutch, sti pink injectors, perrin hoses and turbo inlet, go fast bits bov, kartboy short throw shifter, and that's about it. Like I said, I am just trying to find a slightly bigger turbo that I can make alittle more power with. Thanks!!!
bmini_615 is offline   Reply With Quote
Old 11-05-2013, 02:27 PM   #2
Turd Nugget
Member#: 346017
2013 STi Wagon
Satin White Pearl
a Holset HX35 would be slighly larger, you should probably get one of those.
Turd Nugget is offline   Reply With Quote
Old 11-05-2013, 02:31 PM   #3
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
What turbo do u have now?
jerbull88 is offline   Reply With Quote
Old 11-05-2013, 03:42 PM   #4
bmini_615
Member#: 372867
I believe I have a stock Wrx turbo. Some of my subby friends say buy a vf39, how does that compare to the holset?
Old 11-05-2013, 03:55 PM   #5
bmini_615
Member#: 372867
Also, do I have all the supporting mods for that turbo? If not, what all do I need?
Old 11-05-2013, 04:38 PM   #6
iconone
Member#: 174883
135i 05 CGM WRX
2006 Yamaha R1
Don't listen to him he is an idiot. That is a huge turbo! Go with a vf or big 16g.
iconone is offline   Reply With Quote
Old 11-05-2013, 05:01 PM   #7
kilfarsnar
Member#: 106116
2016 VW Golf R
Limestone Grey
Google is your friend. I believe Mr. Nugget is messing with you.
"Designed primarily for 6 cylinder engines of 5.0 to 6.5 liter capacity, the Holset HX35 turbocharger has high flow aerodynamics capable of providing up to 0.46 kg/s at 3.0:1 pressure ratio."
That turbo is too big. As for what turbo you should get, it depends on your budget and goals. Since you are looking for a bump in power, but want to maintain reliability, a VF39 or VF43 would be a decent choice. You already have the supporting mods. Since you have a 2.5 liter engine, you could go 18G for more power. But you'll need bigger injectors to realize the potential. And it will put more strain on your drivetrain, so there's that.
kilfarsnar is offline   Reply With Quote
Old 11-05-2013, 05:01 PM   #8
chaneod
Member#: 251858
2005 Bugeye STi
Weird, you have an 05 STi engine but the wrx turbo. Have you tried to see if you don't already have a VF?
chaneod is offline   Reply With Quote
Old 11-05-2013, 05:02 PM   #9
kilfarsnar
Member#: 106116
2016 VW Golf R
Limestone Grey
I thought the same thing.
Old 11-05-2013, 05:52 PM   #10
bmini_615
Member#: 372867
Honestly, like I said I am just getting into the subbies, how can I tell what I have on it now. But I think that the only my block came from a sti, I think everything else is from a wrx. Does that sound right?
Old 11-05-2013, 06:13 PM   #11
bmini_615
Member#: 372867
Td04 is what it says.
Old 11-05-2013, 06:34 PM   #12
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
A vf39 or a small 16g would be a great upgrade then. You could use the sti injectors and an sti intercooler if you don't already have them. You will see a huge power gain with a tune of course. Td04 is a stock wrx turbo BTW.
Old 11-05-2013, 07:57 PM   #13
bmini_615
Member#: 372867
Will the vf39 bolt right on? I already have the pink sti injectors, I believe they are 650cc. Do you think that's large enough or should I go bigger?
Old 11-05-2013, 08:13 PM   #14
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
It will bolt right on. Your injectors are 565cc and are fine. You MUST get a tune if you go this route.
Old 11-05-2013, 08:57 PM   #15
tuzzio
Member#: 292532
05 STI
Waiting for Unabomber to come in and say this car is a ticking time bomb.
You really bought a car you have no idea what's done to it?
Why do you think it's an STI block?
tuzzio is offline   Reply With Quote
Old 11-05-2013, 09:35 PM   #16
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
I was thinking the same thing.
Old 11-05-2013, 10:15 PM   #17
bmini_615
Member#: 372867
I bought the car because it was cheap in my opinion. The guy was having some personal problems and needed some money. But he said it has a sti block, honestly I'm just going by what the previous owner has told me.
Old 11-05-2013, 10:19 PM   #18
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
If I were you, I'd get a Garrett GT6041 as that's a really great turbo. It might be a little slow to spool, so I'd follow it up with a 200 shot of NOS to spool it.
1. Read the sticky threads....we have one titled Turbo FAQ and you need to read it about 32 times as you have no idea if you are afoot or horseback on this issue.
2. Where the hell in Maryland do you live? I can refer you to your closest Subaru-centric shop so they can screw your head on straight.
Old 11-05-2013, 10:22 PM   #19
Wrxvelocity
Member#: 372887
Can i put a blow off on my 2014 wrx
Wrxvelocity is offline   Reply With Quote
Old 11-05-2013, 10:26 PM   #20
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You can kindly bugger off is what you can do. Spamming your question in other people's threads is a violation of our forum rules AND that is covered in a sticky thread at the top of this and four other forums.
Old 11-06-2013, 03:31 PM   #21
Andrewxxcarlson
Member#: 316415
2006 WRX
Check the stamp on the block to see if it's the sti block? Ej205 is 2.0l wrx ej257 is sti correct? Coulda just swapped sti block onto the rest of the wrx motor and kept td04. If it's says td04, you shouldn't be confused. That's what it is.
Andrewxxcarlson is offline   Reply With Quote
Old 11-06-2013, 04:55 PM   #22
bmini_615
Member#: 372867
Originally Posted by Andrewxxcarlson View Post
Check the stamp on the block to see if it's the sti block? Ej255 is wrx ej257 is sti correct? Coulda just swapped sti block onto the rest of the wrx motor and kept td04. If it's says td04, you shouldn't be confused. That's what it is.
Ok thank you for the help!I greatly appreciate it!!
Old 11-06-2013, 05:57 PM   #23
bmini_615
Member#: 372867
Ej 20 is what it says
Old 11-06-2013, 06:09 PM   #24
Andrewxxcarlson
Member#: 316415
2006 WRX
2.0 liter wrx block.
Old 11-06-2013, 06:11 PM   #25
superdonkey23
Member#: 350000
2013 WRX
Crystal Black Silica
Sounds like you were lied to.
superdonkey23 is offline   Reply With Quote
