Old 11-06-2013, 10:44 PM   #1
Jeremy02wrx
Member#: 372995
02 WRX
Default Best turbo upgrade for my 02 wrx
I'm looking to upgrade my turbo and injectors on my 02 wrx. Looking for some information on what would be the most cost efficient combo. Also the car has 130,000 miles on it. So I'm not looking for a really big turbo. Just wanna add some extra HP.
Jeremy02wrx is offline   Reply With Quote
Old 11-06-2013, 10:47 PM   #2
CarverSnell
Member#: 256218
2004 Impreza WRX
FP Black, 380whp
You're going to want to upgrade your fuel pump as well.
CarverSnell is offline   Reply With Quote
Old 11-06-2013, 10:50 PM   #3
manualmotive
Member#: 339206
RIP Totalled 13 WRX
White 14 BRZ
Um. Any other info...?
Go stage 2 with a pro-tune first. Plenty more power.
manualmotive is offline   Reply With Quote
Old 11-07-2013, 07:08 AM   #4
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
There is no "best" turbo. Without a budget and a horsepower goal, we can't really do much for you except tell you to consult a tuner.
Old 11-07-2013, 07:31 AM   #5
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
What work is done on the car already? If it's stock, why not start with a simple stage 2 set up? Downpipe and tune...
Loyale93 is offline   Reply With Quote
Old 11-07-2013, 07:47 AM   #6
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Read post 4. You need a budget and a WHP goal.
Old 11-07-2013, 08:58 AM   #7
Bak3rSkat3r
Member#: 328769
2005 WRB WRX
2007 UGM 2.5i
For a 2.0 I'd stick with a vf39/ vf34/ 16g
Bak3rSkat3r is offline   Reply With Quote
Old 11-07-2013, 06:22 PM   #8
Daniel Dudley
Member#: 307610
2004 WRX Wagon
Spend some time here reading the stickies at the tops of the various forums. You will learn a ton about your car.
You will not just be able to bolt on a turbo and injectors without getting a tune. Big bang, big bucks. On my 04 I picked up a solid 50 HP with an up pipe, a down pipe and a full exhaust. But it would not have worked without a tune.
Daniel Dudley is offline   Reply With Quote
Old 11-07-2013, 07:56 PM   #9
wrX-MEN
Member#: 330488
03 WRX
You need to know first if you want it for low end, mid or top end power.
wrX-MEN is offline   Reply With Quote
Old 11-07-2013, 08:04 PM   #10
Bugmanny
Member#: 331235
1999 2.5rs
You can make 'extra' power with the td04 you have now
Bugmanny is offline   Reply With Quote
Old 11-07-2013, 08:08 PM   #11
575rider
Member#: 112024
03 hybrid 6spd wgn
Santa Cruz Bronson-Carbon
While everything posted already is true, you need to understand you'll need more than a turbo and injectors. You'll need an aftermarket down pipe (ideally a full turbo back exhaust), fuel pump, larger intercooler (STI is sufficient based on what you seem to be looking for), turbo, injectors, and a tune.
There's tons of threads and info on all this, read the FAQ, and at least do a Google search or forum search. You'll find plenty of write ups.
Start with the dp and stage 2 tune, it's a BIG jump in power and might be all you'll want.
575rider is offline   Reply With Quote
Old 11-07-2013, 08:35 PM   #12
mephistomarius
Member#: 330895
2002 Impreza wrx
blaze yellow
Vf 39 or similar would prob be your best bet, with proper supporting mods obviously.
mephistomarius is offline   Reply With Quote
Old 11-07-2013, 11:34 PM   #13
eckman
Member#: 96100
'06 Impreza WRX/STi
I would suggest an E85 upgrade path if it's in your area!
eckman is online now   Reply With Quote
Old 11-07-2013, 11:51 PM   #14
cvananden
Member#: 326698
2006 WRX Ltd.
San Remo Red
This is clearly the best turbo for you based on the information you provided.
http://www.rallysportdirect.com/ATP-...ly-Gated-Turbo
cvananden is offline   Reply With Quote
Old 11-07-2013, 11:53 PM   #15
jdm_wrx95
Member#: 366509
2003 wrx
blue
A twin scroll setup like the vf37 wont disappoint!
jdm_wrx95 is offline   Reply With Quote
Old 11-08-2013, 01:11 AM   #16
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
VF8 hands down.
i_c_the_light is offline   Reply With Quote
Old 11-08-2013, 06:23 AM   #17
rexblake
Member#: 178426
2010 S4
Gray
VF39 is going to be the most cost effective. Also pretty fun on the 2.0. With supporting mods of course.
rexblake is offline   Reply With Quote
Old 11-08-2013, 11:49 AM   #18
jdm_wrx95
Member#: 366509
2003 wrx
blue
I agree I am currently running the vf39 on the 2.0 jdm block its quite fun but gets boring when you get used to it
Old 11-08-2013, 02:25 PM   #19
Jack
Add Lightness
Member#: 13699
2004 45k mile Outbac
(From General)
I'd like to turn your response upside down a bit......
The OP has not said what mods his car already has nor what his budget is. With an 02, he can run a catless downpipe without a tune. So I am going to have to assume that he does not yet have a catless downpipe. That'll run you fifty bucks used. While you're screwing around down there, pull off the up pipe (if stock) that has a cat in it and buy yourself a catless up pipe for safety sake for yet another $50 used. That'll save you from having your turbo ruined when the cat starts breaking up. Now the good part. You can get $200 for the OEM up and OEM down pipes, making the up/down pipe upgrade not only free....you just made yourself 100 bucks. This is the best upgrade anyone will suggest. You get more power plus you get money.
Old 12-21-2013, 09:48 PM   #20
Jeremy02wrx
Member#: 372995
02 WRX
Sorry guys it took me so long to respond. I have a stage 2 set up already. But I have a bigger problem, I slung a rod threw the top of my block. So now I'm look into getting a EJ207 version7. It is what my tuner recommended.
Old 12-21-2013, 11:58 PM   #21
quoiasdaddy
Member#: 147711
2002 WRX/Stg 2
I have a Walbro fuel pump for sale..75.00 and its yours!
quoiasdaddy is offline   Reply With Quote
Old 12-22-2013, 12:30 AM   #22
05ScoobyRumble
Member#: 372522
Haha GTX35R... 500WHP TIME!
05ScoobyRumble is offline   Reply With Quote
