Old 11-13-2013, 04:03 AM   #1
wawacoffee
Member#: 369299
Default Installing OEM cruise control in 2012+ Impreza 2.0i base model
Forewords:
Many people choose a premium Impreza mainly for its cruise control. Some people who settled on base trims whine and ask if they can add one. Now you have a new reason to love you base-trim Impreza because it actually has a cruise control built-in, but you just need to activate it!
One day I ran into a Chinese XV Crosstrek forum and there were some interesting discussions and guides to install OEM cruise control keyboards taken from other Subaru models. This function just simply works on the base models. That tells us cruise control is already build in every single XV Crosstrek sold in China, but Subaru decides to lock it on the base trim for marketing purposes. Since XV and 2.0i NA Impreza are close relatives, and every Impreza sold in North America but base models in US has this function, I strongly believe this could be the same marketing strategy. I happened to find a used cruise control keyboard taken from a XV Crosstrek, so I decided to give it a try.
I highly recommend the following guides in Chinese, where I learn all the necessary information for this mod. If you don't read Chinese, you may still find the photos and video helpful.
http://club.autohome.com.cn/bbs/thre...0235057-1.html
The photos are very useful in locating the air bag clips
http://club.autohome.com.cn/bbs/thre...4303777-1.html
This is a detailed video guide in Chinese language. For those who have problem with Flash plug-in:
A video guide in replacing the steering wheel on WRX here (English). However the major difference is the air bag removal, but it is the most difficult step. You may find it useful for everything else.
Special thanks to the friends on http://club.autohome.com.cn/bbs/forum-c-2417-1.html for their discussions, and bignick on www.subaruxvforum.com for supplying the part at a low price
Tools you need:
A 10 mm wrench (to disconnect the battery)
A solid 17 mm lug wrench (to remove the main lug of steering wheel)
A flat screwdriver
A Phillips screwdriver
A bright flash light (you will need to see the components inside)
Parts you need:
From your dealer:
Cruise control keyboard for Impreza #4
or
Cruise control keyboard with audio satellite remote for Impreza #5
Actually, I am using a used part from XV and it works. However, the harness for paddle shift is different, but I don't care. Some people in that Chinese forum reported successful installation with parts for JDM XV, but the Eyesight button won't work of course. (http://price.52che.com/subaru_xv/news-17628262.html) Some even used the keys for Legacy sold on US eBay, but you need to modify the harness. (http://club.autohome.com.cn/bbs/thre...3119415-1.html) My point is, the cruise control system are very similar across late Subaru models, but the parts designed for Impreza or XV Crosstrek in North America will be the simplest choice.
Step-by-Step Procedure
1. Park your car with the parking break, align the wheels straight, and remove the key.
2. Disconnect the negative end of the battery and wait for more than one minute before work
This work involves the removal of the air bag on the steering wheel. This is the necessary step to prevent the accidental deployment of the air bags.
3. Disconnect the air bag clips
The mechanism to fasten the air bag module is very simple. There is a steel wire attached to a spring to hold the clips. All you need to do is use a flat screwdriver to push the wire and the clip will simply detach. I borrow a image from http://club.autohome.com.cn/bbs/thre...0235057-1.html to show their positions on the steering wheel. Behind each clip, there is a hole on the back cover where you can access the wire.
Close-ups on both sides
You should begin with the bottom one which is the easiest. The air bag module popped right out as soon as I stuck the screw driver into the hole.
Now you move on to the clips on the both sides. They have the same mechanism but the angle is very tricky. I got good luck on the right one within a minute. But the left one took me about an hour because my left hand is so awkward. I can only provide the photos and you have to figure out the the position of the clips, and the correct angle of attack. My advice is that you kind of follow the angle of the hole, but slide in the screwdriver along the wall in the hole closer to your side, like this:
And the wire will be moved accordingly:
Alternatively, while not recommended by the service manual, you can follow the suggestion in this video in Chinese language:
What he said between 3:00 and 4:00 is: Pry out the back cover of the steering wheel, though the gap you can see a square thing where his finger is pointing at. Use your screwdriver with force to lever the square toward the center of the steering wheel. I think this is the square thing he was mentioning and how the wire can be moved this way is shown below:
But I could never see it clearly with the air bag attached, so I did not use this method.
(to be continued due to limit of image numbers)
wawacoffee is offline   Reply With Quote
Old 11-13-2013, 04:16 AM   #2
wawacoffee
Member#: 369299
4. Disconnect the air bag harnesses
Depending on the region, there may be one or two harnesses, which are color-coded. You need to pry up the clip first then the body of the harness.
5. Disconnect the horn
There is a small hook and you need to press it before removing.
6. Disconnect the steering wheel control harnesses
The 12-pin harness is for horn, cruise control and satellite remote control. The small, 4-pin one on the right is for paddle shift. The XV Crosstrek keyboard I used here has different design for the right one so cannot be plugged in.
7. Mark the position of the steering wheel with tapes
Makes it easier when re-installing.
8. Remove the main lug
You need a good lug wrench to do so. I found the ratchet wrench in my tool set was too shallow and flimsy for this job. I used a wheel lug wrench. Its tightening torque is 39 N-m or 29 lbf-ft.
9. Take off the steering wheel
Wiggle around the wheel from different location to loosen it, and use good strength to pull it out.
10. Remove the back cover and the (empty) keyboards
Flip over the steering wheel, and remove the back cover. Each keyboard is hold by a Phillips screw, which can be easily removed.
11. Install the new keyboards, put everything back in reverse order, and enjoy the cruise control (and satellite remote)!
The computer will detect the new component and adapt automatically in starting up. Watch the upper right corner of LED display.
Cruise control turned on:
The illumination color of the keys fits perfectly:
It is absolutely unnecessary to use an aftermarket cruise control kit. Go buy a keyboard and enjoy the function your car already has!
Old 11-13-2013, 04:34 AM   #3
wawacoffee
Member#: 369299
Update: The steering satellite switch is actually wired into the 12 pin main harness. It is not working now because I have an after market head unit. I will install an AWSC-1 soon to see how it goes: http://forums.nasioc.com/forums/show....php?t=2430330
The following are the relevant wiring diagrams from the service manual. This manual is the best investment for my car so far.
The right small 4-pin harness is for paddle shift. Impreza and XV have different design but I don't plan to put it. However someone can experiment installing steering wheel control and paddle shift altogether.....
For those who are still dubious about this easy cruise control installation, here are the words for you from the service manual:
Well the dealers say....
Old 11-24-2013, 07:42 PM   #4
bunchofcod
Member#: 374502
2013 Impreza 2.0i
Red
Default thanks for the cc explanation
It should help me to rectify my mistake when I bought an Impreza in May. I love the car; my wife really LOVES it, but I assumed all models came with cc. Duh! After a couple long range trips I know we need it, the only question is to do it myself, or asking the dealer to install it. Again, thank you for the clips and letting us know this is possible.
bunchofcod is offline   Reply With Quote
Old 11-24-2013, 07:57 PM   #5
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
I didn't bother to read through all the posts, but watched part of the vid. I wrote up a how to on changing my steering wheel to the leather one. In the FWIW department, it is not necessary to pry the trim apart to get to the spring clips. there are holes in the back for that purpose. Furthermore, it is very advisable to disconnect the battery before you begin disassembly of the steering wheel. IIRC, there was mention of waiting 1 minute to allow any possible stored voltage to bleed off after the battery has been disconnected. Otherwise, you run the risk of having the air bag discharge. Probably would not be a pretty sight.
Here was my write up:
http://forums.nasioc.com/forums/show....php?t=2435531
Note that this was for changing the plastic wheel for leather, but the disassembly process is the same.
John
Guzzi 1 is offline   Reply With Quote
Old 11-24-2013, 08:35 PM   #6
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
We still need pictures of it! I'm inching closer and closer to doing this, because I think it would be awesome. Is it the same leather steering wheel that comes in the limited model? I thought about looking in one to make sure it's a type of leather wheel I would like.
Pics please! Final finished product would be awesome, I'm just curious what the leather wheel looks like.
Xafen is offline   Reply With Quote
Old 11-25-2013, 11:17 AM   #7
wawacoffee
Member#: 369299
John
I totally agree with you on the recommendation to disconnect the battery and use the holes behind the steering wheels for disassembling. Here is the official guides from the repair manual:
And the tightening torque for steering wheel is 39 N-m or 29 lbf-ft.
Old 11-25-2013, 02:38 PM   #8
bunchofcod
Member#: 374502
2013 Impreza 2.0i
Red
Anyone know what a Subaru dealer would charge for the cc pad and installation?
Old 11-25-2013, 05:51 PM   #9
wawacoffee
Member#: 369299
I think an hour of labor is a fair price. It would take me half an hour to perform the installation again.
Old 12-22-2013, 02:43 PM   #10
GJ7_Tim
Member#: 363260
it took me 45 min to install the cc with audio. the only hard part of the whole installment was to find the lock that holds the airbag assembly in place. everything else is easy.
GJ7_Tim is offline   Reply With Quote
Old 02-25-2014, 09:00 AM   #11
dmccown
Member#: 382814
2014 Impreza 2.0i MT
Can anyone verify that this works on the '14 model year? Also on a manual?
This sounds awesome and I want it so bad!
UPDATE: Got the part in, and will try to install it tonight.
UPDATE 2: It works perfectly! Couple of thoughts about the instillation:
1. The airbag clips will own your soul, that is where a lot of my time went!
2. The second harness that is 1,2,3,4 above which is for the paddle shifters just dangles if you have a manual (kind of obvious but was really disconcerting when I was installing)
3. From a purely rant perspective, Subaru really? that part costs them maybe 20 bucks to make....
Enjoy!
dmccown is offline   Reply With Quote
Old 02-25-2014, 05:57 PM   #12
VegasSubie
Member#: 365638
2013 Impreza 2.0i
1991 Galant VR4
I called the local Subaru dealership here about this and they told me that the ECM isn't wired for cruise control to work. They said there's no real way to get cruise control installed on a base model. Is this just something they're trying to hide or will it really work on any base model impreza?
VegasSubie is offline   Reply With Quote
Old 02-26-2014, 08:55 AM   #13
dmccown
Member#: 382814
Told me the same thing, but I am trying it. I just bought the part yesterday on Ebay and will update once I have tried it. My thought is actually that they legitimately do not know.
Old 02-26-2014, 10:13 AM   #14
VegasSubie
Member#: 365638
2013 Impreza 2.0i
1991 Galant VR4
If it works out let me know. If the dealership says it won't work but it does, I'll just do it on my own. Just wanted to get them to do it so I don't have to mess with the airbag.
If anyone is looking for the part, it's $125.16 here;
http://subaruonlineparts.com/oemparts/83154FJ160
Old 02-26-2014, 10:27 AM   #15
emiliobadillio
Member#: 376596
2009 WRX Base Hatch
I'm hoping to pickup just the cruise controls (right side) for my base model rather than the full satellite controls from the dealership today. It comes out to $75 from http://www.buysubarupartsnow.com/oem...tch/83154fj030
emiliobadillio is offline   Reply With Quote
Old 02-26-2014, 12:39 PM   #16
VegasSubie
Member#: 365638
2013 Impreza 2.0i
1991 Galant VR4
Not totally sure about it but if you look at the parts in the picture, they have the same connectors. Seems like if you do the cheaper part with just the cruise control you won't get the audio and hands free controls. I think in some of the pictures above it shows the steering wheel without them (the first link at least).
Old 02-26-2014, 12:54 PM   #17
G2Spfld
Member#: 354284
2013 Imp Sport CVT
Seems like I heard someone say they replaced the steering wheel with premium wheel and the connectors were all there to hook up. I'm sure you will need to buy another unit that plugs into comp or engine bay somewhere. Doubt the wheel controls alone will make it work. My niece had an aftermarket kit installed and it works great. Just not as easy to use as the stalk is hidden from view from wheel on left side column. But from what I've heard you can use oem parts to add cruise, just not sure what else besides wheel controls you need.
G2Spfld is offline   Reply With Quote
Old 03-04-2014, 08:33 PM   #18
dmccown
Member#: 382814
Enjoy!
Note my edit from above. Cheers to wawacoffee for a great and through how-to. Enjoy your cruise control!
Old 03-04-2014, 10:36 PM   #19
dmccown
Member#: 382814
What VegasSubie says is true. Depending on how ambitious you are you could just use the hands free part you already have and add it to the harness from the cruise control only pad. Does not seem like it would be too hard, but the wires are all pretty little and possibly soldered into the harness.
Old 03-11-2014, 05:09 PM   #20
VegasSubie
Member#: 365638
2013 Impreza 2.0i
1991 Galant VR4
Did you install just the cruise control pad or did you buy the part that came with the hands free and cruise control? Since you confirmed this works I'll definitely be doing it soon.
Old 03-11-2014, 09:57 PM   #21
RKNewell
Member#: 381864
Smile Yes, it does work!
Dealers told me "Naaaaah, you can't add cruise control to your 2014 base Impreza." Still, I had to try, and luckily, part # 83154FJ160 works like a charm! My thanks to all of you who contributed the info I needed.
RKNewell is offline   Reply With Quote
Old 03-12-2014, 01:19 PM   #22
dalt1225
Member#: 383594
That's good news indeed. That's really the 1 feature I missed compared to the cost of the premium upgrade. I didn't want to spend all the extra $ just to get the Cruise Control. Did you get the part on Ebay? Or from a local dealer?
dalt1225 is offline   Reply With Quote
Old 03-12-2014, 01:33 PM   #23
emiliobadillio
Member#: 376596
2009 WRX Base Hatch
So I ordered the part (83154fj030) for just cruise control but the actual part number is 83154FJ040. The part that came had that number, but the description was "SW AY SATELLITE". It was the left side of just audio controls.
The weird part is the description is swapped. One is called "CRUISE SWITCH" and the other is called "SW AY SATELLITE". I am exchanging the audio controls for the cruise keyboard now, and will update when I get it in.
Old 03-16-2014, 10:28 PM   #24
dmccown
Member#: 382814
I got mine on ebay, but the dealership is about the same price. I just did not feel like driving over there to get it.
Old 03-16-2014, 10:30 PM   #25
dmccown
Member#: 382814
I got the part that had both.
