Old 05-25-2014, 01:32 PM   #26
TheNewThatGuy
Member#: 148041
2000 Rally Impreza
Blue and Gold, baby
Well, after reinstalling the harness, it started right up. I also cleaned up all the pins on the big connectors one the harness. It's worth stating that it wouldn't start right before I pulled it, and now I haven't had an issue in about a week or so. We'll see what happens when it gets wet! I'm thinking and hoping that was coincidence.
TheNewThatGuy is offline   Reply With Quote
Old 03-29-2015, 11:48 AM   #27
fundikali
Member#: 362507
Great you got that sorted out. I am having an almost similar problem on a 2006 JDM Outback. About one in ten times it refuses to start. Just cranks. When it does that I usually let the car sit for about 30 minutes and then I try again. Usually works. I will pull out the sensors and measure/clean them and see how it goes.
fundikali is offline   Reply With Quote
Old 03-30-2015, 11:56 AM   #28
TheNewThatGuy
Member#: 148041
2000 Rally Impreza
Blue and Gold, baby
Resetting the pins by unplugging and replugging the connectors and cleaning /wirebrushing any dirty/corroded pins is what I think ultimately solved it.
Old 08-28-2015, 07:48 PM   #29
5fifty6
Member#: 429035
I have the exact same problem with my '00 OBS a/t. Went to leave for work this morning and out of no where it just doesnt start up. Battery is good, starter is working, it just doesnt start running. And i only get 1 code, p0335. Never had this happen before. I replaced the crank position sensor and cleaned the battery, but still does the same thing...along with the code. But here's another piece of the puzzle. If i remove just 1 spark plug wire, doesnt matter which, from the ignition coil it starts right up like normal and just idles with the misfire. I'm totally lost on this one and it's driving me nuts. And i need to figure this out by monday to get to work.
5fifty6 is offline   Reply With Quote
