Old 07-17-2011, 08:16 PM   #1
monstor955
Member#: 288540
Default shaking car
anyone knows why my car shakes everytime i start it after i pump gas?
i recently replaced a loose gas cap but that's obviously not the problem. I already have a fuel pump and sensor coming in on order by the dealer because he says that might be the problem.
monstor955 is offline   Reply With Quote
Old 08-01-2011, 10:47 AM   #2
scrummie02
Member#: 290069
Is it moving or idle?
scrummie02 is offline   Reply With Quote
Old 08-01-2011, 10:49 AM   #3
scrummie02
Member#: 290069
duh...idle
do you overfill it. Sometimes the fuel pump mught choke the vehicle if there is too much gas.
Old 08-03-2011, 09:39 PM   #4
djmanyacal
Member#: 290236
Only happens when you put gas in?
djmanyacal is offline   Reply With Quote
Old 11-20-2013, 09:56 AM   #5
Kcvietsuba
Member#: 361232
07 wrx
blue
Thread revive .. I wonder if you found the solution bc i have the same problem. I have 07 wrx. Every time after i pump gas, it takes 2-3 tries to start the car and it would be shaking for about 3-5 mins. Then it drive normal. This only happen after i pumped gas. I tried pump full, half tank, $5 bucks. Still same problem. I also have the loose gas cap codes. Idk if they are related. I was thinking to change my fuel filter(in tank) and fuel pump while im at it. I hope it will fix it.
Kcvietsuba is offline   Reply With Quote
Shaking car - Need advice Declined7 North West Impreza Club Forum -- NWIC 18 01-04-2009 11:07 PM
Shaking car DsmWRX02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-30-2004 04:41 PM
Shake Shake Shake CFX27 Newbies & FAQs 16 05-22-2002 02:45 PM
whole car shakes!! Imprez Me Normally Aspirated Powertrain 8 02-23-2001 10:45 PM
