Old 11-23-2013, 04:40 PM   #1
wrxboy04
Member#: 151653
2004 wrx
ej257 6266 10.3 at 133mph
Default 04 wrx ej207 e85 blouch1.5xtr tuning
hey i was wondering if anyone had some input on my datalog of my 3rd gear pull its a 04 wrx
ej207
e85
id1000's
blouch 1.5xtr
spt intake
full 3 inch tbe
3port ebcs
my virtual dyno came up around 370hp but i feel like theres alot more left in this turbo the only thing im still trying to learn is the timing if anyone has any input id appreciate it
https://drive.google.com/file/d/0B_F...it?usp=sharing
wrxboy04 is offline   Reply With Quote
Old 11-25-2013, 12:28 AM   #2
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Log looks good to me. Interesting looking at the afgs flatlining and the engine load being as low as it is. used to ej255 logs. Knowing nothing about your tuning process thus far, I'd try raising the timing or boost myself.
ProfessWRX is offline   Reply With Quote
Old 11-25-2013, 12:54 AM   #3
Airboy
Member#: 72829
2006 WRX
2015 WRX
MAF(g/s) and Load is low because of the "half MAF" mod to bypass the 300g/s limit in the 16bit ECUs.
Airboy is offline   Reply With Quote
Old 11-25-2013, 11:50 AM   #4
wrxboy04
Member#: 151653
2004 wrx
Yea I have the maf hack. I believe my timing was to low I raised it up a degree and started getting knock which I think on e85 is a little weird I've heard people running 28* on a 207 with e85 but looked at my idc and I was at 97% when I got the knock I think I maxed out my 255 I'm going to swap in my dw300 and see maybe I'll be able to drop my idc down a lot
Old 11-27-2013, 04:03 AM   #5
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Figure out the fueling. It's going pretty lean up top.
I have a very similar setup with a couple extra mods. Tuning with Carberry rather than the version 8 ROM. My timing is definitely quite a bit more advanced in the load cells you're seeing in your log. You should see noticeable gains for at least another 2-4 degrees if you can figure out what's giving you det. Very odd to see det on E85, I rarely see it before I stop seeing gains from timing advance.
I'm maxing out my ID1000s at 21psi on a similar turbo. VD is showing 400+ at that point. I'm running a DW300, but I'm not convinced that a Walbro is limiting ID1000s.
Concillian is offline   Reply With Quote
Old 12-05-2013, 12:17 AM   #6
wrxboy04
Member#: 151653
2004 wrx
so i got my dw300 in and i just saw your post on maxing out the id1000's @ 21psi. the pump definatly helped out big time i now believe im in the same boat as you maxing out the injector heres a quick log i got tonight with knock still up top its leaning out. do you guys think it would be smart to cap myself off at 18psi and just slowly add in timing?
Old 12-05-2013, 09:55 PM   #7
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Log doesn't show AFR.
You sure you don't have a boost leak?
In any case, yes, I'd taper boost so your IDCs are ~93-95% ish and AFRs are stable. You don't need to cap your peak boost. You can run 24psi at lower RPMs if you want, you just need to taper it where the fueling can't keep up.
You may eek a bit more out of the pump by running larger wires both to the fuel pump controller and to the pump itself, but that's a lot of work. I've done it, but I did it all at once, so I don't know if there's real benefit. Realistically, unless there's a major problem, a DW300 should have plenty of headroom for id1000s.
Old 12-06-2013, 05:51 PM   #8
wrxboy04
Member#: 151653
2004 wrx
yea my wideband serial to usb was acting up that night so i was going off my factory sensor since im on e85 anyway i figured it would be accurate targeting 11.5afr. but with the boost leak wouldnt i be having a problem with a rich condition open loop? im going to throw the tester on it tomorrow just to check it out since i did have everything apart to do the turbo plus weather by me the past few days has been 100% humidity and rainy
Old 12-07-2013, 02:19 AM   #9
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Factory sensor is before the turbo. The back pressure in the header messes up the readings big time. You can use the factory sensor to tune if you pull it out and mount it after the turbo. Pre turbo mounting, the O2 is only correct in vacuum to ~2-3psi.
Old 12-07-2013, 10:56 AM   #10
wrxboy04
Member#: 151653
2004 wrx
With the 207 it's actually in the downpipe from the factory, I forgot to mention that
Old 12-07-2013, 07:49 PM   #11
wrxboy04
Member#: 151653
2004 wrx
well i found a major issue, the factory inlet ripped i guess when i put the turbo in on the bottom side of the turbo
