Old 11-25-2013, 02:05 AM   #1
victork
Member#: 374526
Default trying to figure out which ej20 i have(please help)
I recently bought a 02 WRX which has a new motor because the last lost compression in a cylinder from what i was told. The new motor is from Jdm tech inc in florida but i only have the shipping receipt and it says used subaru engine. I called and wasnt able to get much info. Here are the things ive found that may help narrow it down. The timing cover sticker isnt there and i think it has the original oil cap as it says 02 under it.
-front left says ej20
-left side about the middle of the block theres a circle with a line through it like under the oil cap that says 03|7
-right side middle/front says B231231
-valve covers are smooth/dont say dohc or 16v from what i see
-coil packs screwed on at spark plug holes
This is what ive gathered
victork is offline   Reply With Quote
Old 11-25-2013, 11:10 PM   #2
victork
Member#: 374526
To the top
Old 11-26-2013, 07:59 AM   #3
rdieder
Member#: 257818
2007 STi
CGM
take some pics
rdieder is offline   Reply With Quote
Old 11-26-2013, 05:11 PM   #4
victork
Member#: 374526
**edit**
Old 11-26-2013, 05:15 PM   #5
victork
Member#: 374526
**edit** if more specific pics are needed let me know im very curious to know exactly which ej20 it is.
Old 11-26-2013, 08:32 PM   #6
victork
Member#: 374526
Old 11-26-2013, 08:35 PM   #7
victork
Member#: 374526
Old 11-26-2013, 08:36 PM   #8
victork
Member#: 374526
Old 11-26-2013, 08:37 PM   #9
victork
Member#: 374526
Old 11-27-2013, 04:12 PM   #10
victork
Member#: 374526
Does anyone atleast no what the number in the circle with a line going through it mean? It looks like the no smoking circle but the line inside isnt slanted, its a flat line through the circle(-). It days 03 on the top and 7 in the bottom.
Old 11-27-2013, 04:30 PM   #11
OldManRed04
Member#: 356635
2005 STI
WR Blue
I'm not sure anyone can gather much from those pictures . I can tell your coolant overflow does appear to be incorrectly hooked up. Why is the line below the radiator cap capped off? Not good. Other than that, looks like a regular wrx engine to me.
OldManRed04 is offline   Reply With Quote
Old 11-27-2013, 04:53 PM   #12
victork
Member#: 374526
Not sure but im gonna look in to it!
Old 11-27-2013, 06:30 PM   #13
alexandern05
Member#: 266954
04 wrx v7 sti swap
agile tuned 389hp 342ftlb
Looks like an ej205 from a 02-05 wrx
alexandern05 is offline   Reply With Quote
Old 11-27-2013, 07:12 PM   #14
victork
Member#: 374526
It says ej20 on the block
Old 11-27-2013, 07:17 PM   #15
victork
Member#: 374526
I only had this car a few weeks and im learning so dont be too critical lol i think a ej205 is a 2.5L?
Old 11-27-2013, 08:53 PM   #16
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
Nah, if it says ej25x it's a 2.5. Similarly, if it says ej20x it's a 2.0
BeastianSTI is offline   Reply With Quote
Old 11-28-2013, 01:15 PM   #17
OldManRed04
Member#: 356635
2005 STI
WR Blue
No. An ej205 is a 2.0. The block is labeled as ej20 and nothing more. A 2.5l is an ej25.
Old 11-28-2013, 06:51 PM   #18
victork
Member#: 374526
My 97 legacy had a ej25. Is that the same BLOCK as a 2.5 in later year wrx and sti?
Old 11-29-2013, 10:54 AM   #19
003rex
Member#: 372773
03 WRX
Looks like a jdm ej20 with us intake to me? If motor says ej20 its a ej20. You could probably search the engine vin @ auto parts store and see what vehicle it calls for and go from there. The circle with numbers could possibly be man. Date (ex 7th month/year 03) but never looked into that.
003rex is offline   Reply With Quote
Old 11-29-2013, 01:03 PM   #20
victork
Member#: 374526
From what i was told it is a jdm ej20 and they put the usdm 02 wrx intake on. The guy doesnt speak great english so its tough to talk to him plus his mechanic did the work. He said something about yhe sensors that came with the motor needing to be swapped for it to run right. Where is the avcs located on the motor?
Old 11-29-2013, 01:18 PM   #21
ToneWrx02
Member#: 239095
2002 Wrx
The intake manifold is usdm for sure. See the little valve with 3 lines coming on next to the stock turbo inlet in front. That only came in usdm form.
My jdm ej205 has that sealed with a screw.
Also another way to find out if it is jdm. The jdm came with single avcs. Check the heads for extra tubing.
If its not there then you got a stock usdm wrx engine.
ToneWrx02 is offline   Reply With Quote
Old 11-29-2013, 01:21 PM   #22
ToneWrx02
Member#: 239095
2002 Wrx
Actually i changed my mind about stock usdm. Look at the ac lines.. where are they leading to.. is it going under the intake mani? From the looks of it he got a older jdm ej205 not 01+ plus.
So pre my00 amd most likely swapped some tjings to make the engine work.
Old 11-29-2013, 02:37 PM   #23
003rex
Member#: 372773
03 WRX
I'm about to do one of these swaps... but haven't personally encountered the design or layout of the motor. Avcs is subarus valve timing and has to do with cams and lift, I know there are 2 plugs for avcs (cam sensors) and one reg cam sensor. The 2 avcs are in the back, and cam sensor in front. The jdm motors need a small bracket Installed to read the cam sensor correctly I've been told, but havent worked with one yet so don't quote me on that, talk to a local tuning shop and see what they have to say. Good luck
Old 11-29-2013, 04:37 PM   #24
ToneWrx02
Member#: 239095
2002 Wrx
false false false,
All I did when installing mine with non working AVCS, is disconnected the AVCS wire, installed engine, and bam worked.
No issues at all.
Old 11-29-2013, 06:02 PM   #25
victork
Member#: 374526
The ac lines both go to the right (driver side), and the large one goes on top and the small one runs under everything.
