Old 11-25-2013, 10:05 AM   #1
xXBISHOPXx
Member#: 304575
2002 WREX 303awhp
Default Ej205 problem
I have a 2002 wrx, let me state that this is the first problem I have ever had with the car and it's been tuned with larger injectors a vf22 turbo exhaust since 30,000 miles, I just turned 130,000 a couple of days ago. I noticed I was getting some oil drip on my headers/up pipe recently and found my oil feed line was leaking not too bad I would check my oil every couple of days and over the course of about 2 weeks I only had to add about half a quart, now here is the real problem, I was driving down my road and pressed the clutch in as I was approaching my driveway, the car cut off and I didn't know why. So I turned the key over and it was having a hard time turning over, then when it started it squeaked really bad for a second like a dry start or something and it wouldn't stay running, so I shut the car off and pushed it down my driveway(it's a quarter mile long wanted to kill myself) once I got it to my garage I checked the oil and it was on the low side but not below the low tick mark, so I added about half a quart and and decided to start it again and it was running and idling perfectly fine, but now when I rev the motor to about 2300-3000 rpm there is a loud knocking sound but if I hold that rpm the sound dissipates and goes away???? I was really confused as I'm not an expert on Subaru motors yet lol. So I decided to change the oil (as it was approaching anyway) and I decided to add an oil additive to see if that helped clean it a little as it has been fluctuating on oil level and gunking could be a problem so I changed it and drive it around but I still experience that knocking sound when I'm cruising around only when I slightly accelerate, when I put under a little boost or when I'm cursing at say 60mph at 2500-3000 it's fine I don't really notice the noise. I'm not quite sure what it is but I'm fully prepared to pull the motor out and pull it apart, I have rebuilt motors before but not a Subaru so I'm interested in talking a look, I have researched and found out a lot about my motor already but most of you guys are more experienced with these as I'm a v-8 big block guy lol so any help would be appreciated thanks! Sorry for all the grammar problems I'm on my phone.
xXBISHOPXx is offline   Reply With Quote
Old 11-25-2013, 11:13 AM   #2
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
Maybe rod knock. A video or a sound clip will help.
jerbull88 is offline   Reply With Quote
Old 11-25-2013, 11:39 AM   #3
xXBISHOPXx
Member#: 304575
2002 WREX 303awhp
On my way home now I'll post one up in about an hour or so
Old 11-25-2013, 01:15 PM   #4
xXBISHOPXx
Member#: 304575
2002 WREX 303awhp
http://www.youtube.com/watch?v=1ELaO...ature=youtu.be
hope this helps out a little bit better. had to use my phone, my nikons is not charged at the moment
Old 11-25-2013, 01:50 PM   #5
rdieder
Member#: 257818
2007 STi
CGM
can you isolate the general location of the noise? Try narrowing it down by "listening" through the handle of a long screw driver or broom handle
rdieder is offline   Reply With Quote
Old 11-25-2013, 02:17 PM   #6
xXBISHOPXx
Member#: 304575
2002 WREX 303awhp
I have it seems to be back of the motor area
Old 11-26-2013, 06:46 AM   #7
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
Rod knock.
Old 11-26-2013, 09:48 AM   #8
xXBISHOPXx
Member#: 304575
2002 WREX 303awhp
Figured as much lol, now it gives me a reason to build my motor now
Old 11-26-2013, 09:51 AM   #9
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
+1 on rod knock
Old 11-26-2013, 10:33 AM   #10
xXBISHOPXx
Member#: 304575
2002 WREX 303awhp
I'm hoping I caught it in time to where the bearing is not welded to the crank lol really don't want that to have happened :/
Old 11-26-2013, 01:14 PM   #11
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
A new crank cost about the same as getting one redone so I'd replace it anyway.
Old 11-26-2013, 01:15 PM   #12
003rex
Member#: 372773
03 WRX
hope you caught it too, mine started knocking bad one day, next day spun the bearing. no fun.
003rex is offline   Reply With Quote
Old 11-26-2013, 07:12 PM   #13
xXBISHOPXx
Member#: 304575
2002 WREX 303awhp
Literally It cut off I started it heard it knock and shut it off and pushed it up my driveway. Only cut it on to make a video and diagnose it
Old 11-26-2013, 09:14 PM   #14
003rex
Member#: 372773
03 WRX
Well good plan.. it'll be much cheaper that way and the crank will most likely be much more savable. Have you drained your oil?
Old 11-27-2013, 09:10 AM   #15
xXBISHOPXx
Member#: 304575
2002 WREX 303awhp
Yes I drained it and checked my magnetic drain plug and there were no flaky pieces but more like normal wear fine metal particles......just a little more so I'm hoping it is save able
Old 11-30-2013, 07:03 AM   #16
003rex
Member#: 372773
03 WRX
You can take quite a bit off to save them, even if not a sti crank is only 300 bucks same for 04 ej20s. And get some stronger rods and better bearings while your there
Old 11-30-2013, 05:36 PM   #17
BuckwildWRX
Member#: 372900
Son what a terrible devilish sound
BuckwildWRX is offline   Reply With Quote
Old 12-04-2013, 08:44 AM   #18
xXBISHOPXx
Member#: 304575
2002 WREX 303awhp
Since I don't think it's a spun bearing I shouldn't have to have the crank turned will I? Also what else could possibly be affected by a rod knock in the boxer motor? Could it be a bent valve? Trying to throw out every possibility.
Old 12-08-2013, 09:33 PM   #19
superstar_05
Member#: 375651
Hmmmmmm. Interesting.
superstar_05 is offline   Reply With Quote
