Old 11-29-2013, 06:01 PM   #1
WWC
Member#: 374436
Default Timing Belt Snaps-Valve Contact-Are pistons still good? (Pics inside)
This the the passenger side head, so cylinders 1 & 3 as far as I recall. USDM EJ205. This is where the valves tapped the two pistons, exhaust side. I know some motors can accept small nicks without a negative reaction, but not sure about the ej205. I cannot budget a rebuild or replacement, but I do have everything I need to refresh the heads. Just curious if these pistons are going to affect compression negatively or not.
Off the top of my head, I'd say they'll be fine, because it's not much of a difference at all. But again, I figure it's best to ask.
Thanks in advance
WWC is offline   Reply With Quote
Old 11-30-2013, 06:59 AM   #2
003rex
Member#: 372773
03 WRX
I've done it many times with a detroit diesel, that is.. unless the valves have made way father than the combustion chamber.
003rex is offline   Reply With Quote
Old 11-30-2013, 11:50 AM   #3
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
They are fine run them.
Old 11-30-2013, 11:59 AM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
They are fine. If you are really anal, smooth down the sharp edges where it hit to prevent a hot spot and detonation.
Old 11-30-2013, 12:19 PM   #5
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
For a basically stock car I would run them.
If this was a built engine, high boost etc..... I would replace them.
Old 11-30-2013, 01:47 PM   #6
WWC
Member#: 374436
Awesome, that's what I was thinking too. This car is completely stock and will stay that way as long as I own it.
Thanks again.
Old 12-02-2013, 06:08 PM   #7
aperson
Member#: 273649
2002 WRX Wagon
You're likely fine, got any pics?
aperson is offline   Reply With Quote
Old 12-02-2013, 06:56 PM   #8
WWC
Member#: 374436
They were hosted, idk what happened.
Old 12-02-2013, 07:45 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
dont the intake valves hit the exhaust valves??
Old 12-02-2013, 07:54 PM   #10
WWC
Member#: 374436
Old 12-02-2013, 07:55 PM   #11
WWC
Member#: 374436
Valves didn't hit. Dropped the heads off at the machine shop today. Waiting on a list of parts.
Old 12-03-2013, 09:55 AM   #12
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
How many miles did the belt have, when it snapped?
Old 12-03-2013, 01:01 PM   #13
WWC
Member#: 374436
Around 500 or so. The cooling fans plowed through the timing covers and hit the belt.
