Old 12-09-2013, 01:01 PM   #26
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Yup sounded like a leak to me, good thing you found it...nice job.
Doubtful it was tuned with that boost leak. If it was his afr would probably not be 10.7:1 now, would probably be 6-7 points higher.
Keep us up to date.
wgr73 is offline   Reply With Quote
Old 12-11-2013, 08:24 AM   #27
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
I'm not familiar with that particular tuner's style, but some tune low 11s - 10.8 or .9. Always a possibility
BeastianSTI is offline   Reply With Quote
Old 12-11-2013, 04:22 PM   #28
lookylookitzadam
Member#: 348254
2013 WRX
Issues still remain. The car feels good while out of boost. Drives around nicely and feels responsive. Once I get into boost though (mainly just in 3rd gear) it just feels like it is falling flat. Did some 4th gear pulls from 65-80 and whatnot due to passing and that feels alright but not what I would have expected. Trans is definitely not slipping.
Think I should spend the time to pull the plugs and do a compression test?
lookylookitzadam is offline   Reply With Quote
Old 12-15-2013, 10:51 AM   #29
BeastianSTI
Member#: 310506
2005 WRX STi
Wouldn't hurt to do one at this point.
Old 12-26-2013, 12:15 AM   #30
lookylookitzadam
Member#: 348254
2013 WRX
So I did a compression test today. Took a bit longer than I thought but I am super happy with the results. All within spec and not more than 2psi difference across the cylinders. Also swapped out the bpv gasket as well as some new iridium plugs. Then I proceeded to clean the MAF sensor. Haven't had a chance to do a pull yet, but the car is idling better and fired up quicker. Updates soon, hoping my issues are going to be a thing of the past.
Old 01-08-2014, 08:06 PM   #31
lookylookitzadam
Member#: 348254
2013 WRX
Update:
https://docs.google.com/spreadsheet/...Wc&usp=sharing
Here is the most recent log. Spark plugs are changed, new throttle body hose, good compression and its still slow. Any advice?
Thinking it might be a boost leak somewhere and the turbo is overworking to hit target boost levels, but dont really have evidence to suspect that since the numbers seem good to me and my tuner. Just looking for another opinion.
Old 01-10-2014, 08:55 PM   #32
lookylookitzadam
Member#: 348254
2013 WRX
$0.16 BPV Mod seems to have done it for me, at least from what I can tell so far. Hopefully that was all it was and was venting off when building boost making the turbo work out of its efficiency range and causing high temps
Old 02-13-2014, 02:34 AM   #33
lookylookitzadam
Member#: 348254
2013 WRX
Lowered the boost levels and upped the timing, still slow =[
https://docs.google.com/spreadsheet/...0E&usp=sharing
