Old 12-03-2013, 11:37 AM   #1
spoogevac
Member#: 361068
Default Tuner wanted, fuel consumption GDA WRX
My car is a GDA 2001 JDM WRX bug eye 4eat auto.
The fuel economy is not as it should be (around 12.55 litres per 100km)
I was getting 150km to the 1/4 mark before easy, now its more like 120km.
On recent MOT its failing emissions as its running rich and I can smell fuel when I park it and get out the car.
Its got 600cc injectors, K&N typhoon CAI, Bigger TMI, Silicone intake, up pipe, down pipe, extractors which where all fitted after a rebuild 5000km ago.
It has a HSK SSQV which was on the car when it was getting good fuel economy.
Its been tuned before but not finished up 100% (long story). Its running open source and I have wideband.
Can anybody take a look at my logs and see if they can spot anything obvious. It idles perfect and starts first pop every time.
I will include a capture of learning and codes (rear O2 is out because cat is ruined from running too rich before)
http://www.filedropper.com/romraiderlog20131203164648
http://www.filedropper.com/learningv...13-12-03163519
Sorry I cant seem to see where to attach files on this thing so I hosted them there.
If any tuners out there with references see something obvious and can help I can pay.
Thanks
spoogevac is offline   Reply With Quote
Old 12-03-2013, 11:41 AM   #2
spoogevac
Member#: 361068
Forgot to mention.
It has new plugs gapped to .028, new coil packs.
It was backfiring on liftoff after WOT before I did this.
I will change MAF if somebody thinks its a likely problem but as stated it idles super smooth and has no real hesitation anywhere.
It seems to hold boost fine and I can't find any vacuum leak but that does not mean it has not got one.
Thanks again.
Old 12-03-2013, 12:05 PM   #3
ToneWrx02
Member#: 239095
2002 Wrx
Check for leaks. Vacuum and pressure leaks
ToneWrx02 is offline   Reply With Quote
Old 12-03-2013, 11:24 PM   #4
spoogevac
Member#: 361068
Might seem a silly question but.....
Where are the most common Vaccum/Pressure leaks?
If there is no leaks in any place a hose is fitted with a clamp would that take care of everything or are there other places such as the intake manifold having a hole in the gasket?
I will check where the SSQV is bolted to the TMI but other than that is there a place thats easy to miss?
