Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 12-03-2013, 04:33 PM   #1
danger1138
Member#: 279525
04 rex luger!
Default Removing stock BPV elbow
ANyone have any tips on removing the two screws securing the stock BPV to the elbow? Those two little devils are pretty hard to remove. Kinda reminds me of the two screws that sandwhiched the plate where the IACV gasket is.
danger1138 is offline   Reply With Quote
Old 12-03-2013, 04:41 PM   #2
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
make sure you have the right size phillips screw driver, use some pb blaster and/or some heat. Worse case get an impact screw driver. Those screws aren't nearly as soft as those on the IACV.
fastnoypi is offline   Reply With Quote
Old 12-03-2013, 08:58 PM   #3
02nismokiller
Member#: 322963
04 wrx
psm
Get the right size Philips and put lots if pressure and soak them in a lubricant lol
02nismokiller is offline   Reply With Quote
Old 12-04-2013, 12:20 AM   #4
danger1138
Member#: 279525
04 rex luger!
I had my tmic off the other day and decided to give it a go with the elbow. Sprayed pb blaster on it, let it sit for about 10 min, and went at the screws with a philips head screw driver, but the bigger of the two. I will try the smaller head size & if that dont work ill try a small flat head.
Old 12-08-2013, 03:00 PM   #5
danger1138
Member#: 279525
04 rex luger!
Alright, so i removed one screw with ease after spraying it with pb blaster. The other screw was stuck in there and wouldnt budge at all. I obviously ate the thread on top of the screw after many tries with different size drivers so what i did was take a flat head screw driver and place it directly over the screw and hammer that sucker. After a few hits i managed to make a grove across the diameter of the screw. I was then able to just unscrew it with a flathead screw driver. Problem solved , forge recirculating bpv installed.
