Old 12-04-2013, 09:47 AM   #1
tommy c
Member#: 342732
Default oil light goes on when I brake
when I come to a stop my oil light has been coming on..
I just bought another quart of oil that I'm planning on topping off.
I just got a bunch of maintenance done to my 02 wrx and I don't see any oil spot anywhere
Thanks for any help
tommy c is offline   Reply With Quote
Old 12-04-2013, 10:56 AM   #2
Duser
Member#: 313824
2004 STi
Black Java Pearl
Have you checked your oil? Not trying to sound harsh, but that would be the first place to start. I've heard some horror stories from having "quick stop" oil places not doing a great job of filling up after the change.
Duser is offline   Reply With Quote
Old 12-04-2013, 11:19 AM   #3
tommy c
Member#: 342732
I always forget to check or am parked on a slant :/
I still have 2000 miles to go till my next scheduled oil change
Old 12-04-2013, 11:36 AM   #4
guroove
Member#: 129833
2005 Forester XT
Obsidian Black Pearl
You are seeing the oil light in an '02 wrx? This is very bad. The oil light comes on when there is low pressure, which happens far after it being at a low level.
guroove is offline   Reply With Quote
Old 12-04-2013, 11:43 AM   #5
tommy c
Member#: 342732
Any reason why I'm not seeing oil spot anywhere?
Old 12-04-2013, 11:55 AM   #6
bugeyesubie117
Member#: 293656
Your oil light does not mean you have an oil leak. Your oil pressure is probably very low and damaging. ^^ like he said in the post above you.
bugeyesubie117 is offline   Reply With Quote
Old 12-04-2013, 11:56 AM   #7
Duser
Member#: 313824
2004 STi
Black Java Pearl
Might not be leaking, but "using" rather. (Burning, Blow-by ect....)
Old 12-04-2013, 11:56 AM   #8
Duser
Member#: 313824
2004 STi
Black Java Pearl
Either way,...checking the current level of oil would be a great place to start.
Old 12-04-2013, 12:19 PM   #9
tommy c
Member#: 342732
I guess I'm not expecting anything to go wrong with the car
Just did the a whole lot of maintenance and the guy said it would be good for another 100k
The maintenance was a whole bunch of gaskets and everything too
Old 12-04-2013, 01:15 PM   #10
rkramer
Member#: 118209
2015 WRX Limitec
That has nothing to do with your car burning oil or not... Not to mention, one gasket installed incorrectly (easy to do) will instantly cause an oil leak where there was none before.
Obvious question... have you checked your oil? It isn't worth posting any more until you do that.
Old 12-04-2013, 01:56 PM   #11
tommy c
Member#: 342732
I've checked
Its low
Old 12-04-2013, 01:59 PM   #12
bugeyesubie117
Member#: 293656
I've checked
Its low
You should get in the habit of checking your oil level at least once a week.
Old 12-04-2013, 02:45 PM   #13
moody1
Member#: 369421
2009 WRX Sti
Best advice ever. I have only 3k on my engine and check it at least once a week. Read to many horror stories.
moody1 is offline   Reply With Quote
Old 12-04-2013, 03:11 PM   #14
tommy c
Member#: 342732
I'm pretty good at checking it
Just thought my car was in better shape aftee putting over 2k into it less than 5000 miles ago
Old 12-04-2013, 03:14 PM   #15
Duser
Member#: 313824
2004 STi
Black Java Pearl
I've checked
Its low
How low? I'd imagine all-the-way low to show a light. I've ended up with the '03 running very low before, and the light never showed it's face.
Old 12-04-2013, 03:24 PM   #16
tommy c
Member#: 342732
Its pretty low
Old 12-04-2013, 04:25 PM   #17
rocketperson7
Member#: 283968
2003 WRX
MBP
if the light does not immediately go away after topping off the oil, that means it's a cracked pick up, so TURN OFF THE ENGINE IMMEDIATELY AND DO NOT RUN IT until you drop the oil pan and replace the pick up
rocketperson7 is offline   Reply With Quote
Old 12-04-2013, 04:35 PM   #18
snake32
Member#: 167338
02 Silver dollar
i would start by checking the pick up tube like other say, after that i would change the oil pump, and oil pressure sender sensor. if still get the oil light then i would start worrying for internal wear, bearings going and such....
my guess is the oil pump going bad, since this happens at stop and just idling, so once you start revving then the pump is kind of forced to build pressure, but on low rpms is weak and not spinning happily. in that case the timing belt would have some wear marks printed by the resistance of the pump.
snake32 is offline   Reply With Quote
Old 12-04-2013, 05:24 PM   #19
DentMagnet
Member#: 352689
2004 Impreza
dark green but looks blak
Does it also come on when you park on a steep hill facing downhill?
DentMagnet is offline   Reply With Quote
Old 12-04-2013, 07:35 PM   #20
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Invest in an oil pressure gauge.
Old 12-04-2013, 08:13 PM   #21
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ THIS X 1,000!
The OEM oil pressure light turns on at 2.1psi, which is essentially nothing. VERY VERY bad! Oil light flicker or coming on at idle can be symptom for a cracked oil pickup...
See MANY more pics HERE.
Verify your pressure with a cheap mechanical gauge, then start troubleshooting. Do not drive the car until you figure out what's going on. Google it, research, and let us know if you have any questions.
KillerBMotorsport is offline   Reply With Quote
Old 12-04-2013, 08:15 PM   #22
paulpat
Member#: 237145
02 WRX
12 FXT
I saw this thread and went to check my oil. I'm low..... thank God... just need to drive home on low rpms
paulpat is offline   Reply With Quote
Old 12-04-2013, 09:11 PM   #23
sultanofsubguns
Member#: 351404
02 WRX Wagon
ProbablySomethingMundane
I check my oil 3 or more times a week, Call me paranoid or not but I drive a modded car I'm going to do the best I can to protect my investment.
sultanofsubguns is offline   Reply With Quote
Old 12-04-2013, 09:34 PM   #24
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It would have to be extremely low, as it you'd need to have to add at least 2+ quarts to bring it to the full line. Then, the oil light wouldn't come on at low RPMs it would come out at high RPMs when the pump is sucking out the most oil.
Old 12-04-2013, 10:17 PM   #25
paulpat
Member#: 237145
02 WRX
12 FXT
I was a little over a quart low. Life has been busy in the last couple of months so I have not been on my car's maintenance lately. It has been 3 months since my mom spilled 2 gallon of drinks in my back seats; rug doctored them clean them the next day. Just haven't had time, so when people ask why I have no back seats I say, "because racecar!"
Thank you for the info about how low is too low and bad. That would have been my next question. I will be sure to give you guys a call when I am doing a 2.1 stroker/ 207/ or 257 swap.
