Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 02-17-2014, 08:46 PM   #51
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
Any news on that turbo
Old 02-18-2014, 02:21 PM   #52
nitsuj
Member#: 87081
05 PSM STi
05 AW FXT
Originally Posted by jnorth85 View Post
looking good!!
Thanks!
Originally Posted by spoolinsti05 View Post
Your builder went over kill marked the t for tops when the dots face forward, must have been his fist set without arrows ;-) Why not run O rings?
haha I noticed it was marked 7 ways to sunday
Well...on the o-rings...unless I go with bigger studs, I'm 'safe' on the gaskets alone, since I'm not going to push it til they lift...If I get bored with the power, I'll pull it have it machined for bigger studs, o-ring it and shoot for the moon
If I honestly thought I was going to get to this point I probably would have done all that, but again, things change as time goes on, opportunities arise and big got bigger...
nitsuj is offline   Reply With Quote
Old 02-18-2014, 02:22 PM   #53
nitsuj
Member#: 87081
05 PSM STi
05 AW FXT
Not yet...waiting on the turbo to show, and then meeting up to grab it...and maybe a few other 'things'
Old 02-24-2014, 10:01 AM   #54
nitsuj
Member#: 87081
05 PSM STi
05 AW FXT
Update:
Made some progress this weekend, still short some parts i spaced out on...so slow going I guess
Manifold is ready to go on now
Heads were already on, tq'd down, rechecked them and put the cams in and buttoned the heads up, got the water pump on and all that, would be timed too but I forgot to order idler pulleys (dumbass move on my part)
We only got ~4hrs in on Saturday, shop doesn't close til 3, I had somewhere to be that night, he was busy Sunday, this coming weekend he's not around so I might grab the car and get more of the fuel stuff done at home pending weather, then we should be pretty close to ready to pull it...
Old 04-22-2014, 09:48 PM   #55
nitsuj
Member#: 87081
05 PSM STi
05 AW FXT
I'm going to leave this here for now...and make a real update later with whole bunches of pictures
Old 04-22-2014, 11:28 PM   #56
raggedoutsti
Member#: 255714
2005 STi
psm
I'll be waiting
raggedoutsti is offline   Reply With Quote
Old 04-23-2014, 08:45 AM   #57
Abgrooms
Member#: 298640
'14 WW Evo X GSR
Nitrous Rhodes
Looking forward to a ride in this!
Abgrooms is offline   Reply With Quote
Old 04-23-2014, 08:54 AM   #58
nitsuj
Member#: 87081
05 PSM STi
05 AW FXT
I've been slacking badly on the updates here, everythings been crazy busy, fitting in week nights from 6pm-2am (and getting up for work at 5) when I can and my buddy is available (since the car is at his shop) and regular life stuff, but anywho...the car runs
here was the motor a few weeks ago all together and timed
We ran an -8 feed, -6 return, as shown below, under the tray, hung it every few feet or less depending on how it sat, as well as a 4ga to the battery for the fuel, pressure tested all the lines to 150psi (and held at 150psi for a few minutes) and cleaned em out good.
Old 04-23-2014, 08:54 AM   #59
nitsuj
Member#: 87081
05 PSM STi
05 AW FXT
Electrical setup before it was all finished and neatened up and now nicely concealed where the IC sprayer tank used to be
radium surge and bosch 044's, i thought i had a final picture, but the feed and return for the hanger go out bulk heads and under the car and over the tank, they even clear the cover for the fuel pump and the ENTIRE fuel setup sits in the wheel well so im going to make an aluminum hatch so that its completely separated from the car, I'll get an updated pic of all this
gotta run to a meeting but ill update more later this morning
Old 04-23-2014, 10:06 AM   #60
nitsuj
Member#: 87081
05 PSM STi
05 AW FXT
meeting over, conference call time, which means more update time...
In the middle of all this, I decided my DD needed to go (2009 disposable camry) and went out and bought this...which will be a toy once my forester/sti conversion is done, until then, 18mpg on diesel it is.
motor out...start to a long saturday night
after the new motor was in and all that was about when I figured out that the 2.5i manifold puts the throttle body ~3.5" further back...so siliconeintakes.com intercooler piping assortment + AMS core = new FMIC setup...just waiting for a friend that does fabrication for a living to weld the piping together for me, my aluminum welding skills are sub-par, so this is the new setup...dont mind my blurry pictures...it was a long night...
The PTE turbo is going to sit differently, so that very last piece will need to be redone when I swap turbos after the motor is broken in, and it will likely be powdercoated the same color as the IM when its all done
Also, once the turbo is swapped out the upper coolant reservoir is going, so the 5 minute bracket will go as well lol
Old 05-09-2014, 12:48 AM   #61
nitsuj
Member#: 87081
05 PSM STi
05 AW FXT
well, the car is running for the most part and home...I'm having a problem with it breaking up and hitting fuel cut going into boost...
I've replaced everything but the MAF and Coilpacks at this point, either from just putting new sensors in (from the dealer) when I put the motor together or just replacing them cause I said 'hey i have a spare brand new sensor, lets try that'
Tomorrow I'm likely going to buy new coilpacks and replace them and see what happens, MAF shouldn't matter since I believe I'm SD, but just wait for JR to get back to me to be sure.
At this point i've checked the brand new plugs, regapped them to .028 just to be sure the .030 wasn't too much, tested for boost leaks and verified none, verified that I'm maintaining fuel pressure and its increasing 1:1 with boost, I may get a second gauge for an opinion if the coils don't fix it. Logging my AFR is solid at 11.1 as i go into boost and it does occasionally drop below 11 right when I feel fuel cut, so only thing I can logically think of is that the coil packs have seen better days and are firing off as well as they used to.
Old 05-09-2014, 12:55 AM   #62
raggedoutsti
Member#: 255714
2005 STi
psm
is jr e-tuning you? I would love to get tuned by him, just skeptical on getting an e tune
Old 05-09-2014, 01:20 AM   #63
2000subie
Member#: 207638
2004 stage 3 wrx
Jr does awesome e-tunes and your in Texas correct? If so once I have some miles on my car for break in. Jr assured me it's no big deal for him to fly out and do a final tune on the dyno. Being that I'm also in Tx I'm sure he could do both cars at the same time.
2000subie is offline   Reply With Quote
Old 05-09-2014, 01:27 AM   #64
raggedoutsti
Member#: 255714
2005 STi
psm
DONT PLAY WITH MY EMOTIONS!, I'm in houston, id be willing to drive to Dallas, Austin, San Antonio.
Way easier than trying to go to TIC in Ohio
Old 05-09-2014, 01:32 AM   #65
2000subie
Member#: 207638
2004 stage 3 wrx
DONT PLAY WITH MY EMOTIONS!, I'm in houston, id be willing to drive to Dallas, Austin, San Antonio. Way easier than trying to go to TIC in Ohio
Last we had talked about it he had mention boost logics in Austin. I know he does a lot of tuning there. So that's what I've been planing. I believe I've finally figured out the issue I've been having with my car. So hopefully I can get Jr down this way before to long, as long as all goes well with break in.
Old 05-09-2014, 06:55 AM   #66
nitsuj
Member#: 87081
05 PSM STi
05 AW FXT
I'm getting tuned by jr somewhere, I can promise it's not going to be at BL though lol he tunes at prime motoring, p&l, shift fast, I think tmw still, maybe somewhere else as well...only e part of my tune is my base map to get the car running and broken in...I know he's busy as hell so I try not to bug him too often (unless I have good reason to lol)
Old 05-10-2014, 04:24 AM   #67
raggedoutsti
Member#: 255714
2005 STi
psm
Yeah all those shops are quite a ways away
Old 05-15-2014, 09:37 AM   #68
nitsuj
Member#: 87081
05 PSM STi
05 AW FXT
Update:
All my little issues are gone, I replaced both o2 sensors and the coil packs (planned on doing it anyways) put some fresh gas in it and things are going much better...about 100 miles on it, things are looking up...now just need to swap out the turbo kit, put a few more miles on it and then tune time!
Old 05-15-2014, 09:48 AM   #69
Justin V
Member#: 98747
07 WRX
What's going on with the tranny? Wasn't the 07 going in it and then you changed your mind?
Sticking with the 05 or is something else in the works?
Justin V is online now   Reply With Quote
Old 05-17-2014, 10:42 PM   #70
nitsuj
Member#: 87081
05 PSM STi
05 AW FXT
So I have a brand spanking new 07 tranny sitting in my basement, I decided that's going in the forester, and I found something else I want in the STI thats even more indestructible...and I own it...I just have to go get it...and its going to be sitting behind a triple carbon clutch, and behind it will be a DSS CF drive shaft, and some level 5 rear axles
Old 06-14-2014, 05:02 PM   #71
nitsuj
Member#: 87081
05 PSM STi
05 AW FXT
let the cat out of the bag on a few things...updated the first post with turbo and driveline details...go big or go home i guess lol
Old 06-14-2014, 09:34 PM   #72
raggedoutsti
Member#: 255714
2005 STi
psm
Dang it now I really want 6266
Old 06-16-2014, 07:18 PM   #73
nitsuj
Member#: 87081
05 PSM STi
05 AW FXT
do it! heres a vf43 next to the 6266 lol
oh and some of my other new goodies...
awd spec d2 drag coilovers they should help a little over the stock suspension
DSS Carbon Driveshaft
DSS Pro-Level Axles and my uppipe (i heart vband)
Downpipe
tranny and r180 are down my buddy's shop...clutch is, somewhere, i cant remember where lol
Old 07-07-2014, 01:24 PM   #74
nitsuj
Member#: 87081
05 PSM STi
05 AW FXT
Default finally...
I FINALLY got a chance to make some progress on the car this weekend.
I got the front coilovers installed and adjusted, ride height where I want it, the rears are coming soon, the bolts just refuse to budge and the bottom bolt is right next to the axle boot so no O/A torch to heat it up while its on the car...I have to take it apart to press the hubs on anyways, so I'll just do it all at once...not like the car is going very far until then.
Manifold/Turbo is all on, IC piping and Intake made, I'm waiting on a vband clamp to come to attach the downpipe to the turbo, somehow i managed to get 2 3" clamps instead of a 3" and a 3 5/8"so as you can see in the pictures, the downpipe is hanging by zipties right now. I still have to remove the rest of the intake from the UR kit, but that wont take long at all.
All thats left at this point is the drivetrain really...finish up the rear coilovers, install axles and swap out the r180, swap the driveshaft, tranny and clutch
Here's the 6266 next to the 3076r
Oh, and some traction came in the mail
One sey header...
Turbo pre-intake/ic piping
With intake and IC piping
My wife asked me the other day if I had any idea how much money I've spent on the car during this build...I told her even I don't want to know LOL
Old 07-07-2014, 01:38 PM   #75
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
I say the same exact thing
Looking sexy under the skirt of that engine too
