Old 12-16-2013, 06:27 PM   #1
subiefan7162
Member#: 204462
2006 Forester XT
RBP
Default Writing a new map, need some help
Ok so Im getting ready to write a new map for an APS 70mm CAI, Omni 4 bar map sensor, Grimmspeed TMIC, ID 1000cc injectors w/ AP fuel rails and Tomei FPR. Ive already tuned my car for the VF48 I have at 19.5psi, Grimmspeed BCS, Walbro Fuel Pump, and STI Top Mount. I need help with rescaling my MAF and MAP... any help would be greatly appreciated!
subiefan7162 is offline   Reply With Quote
Old 12-16-2013, 06:54 PM   #2
subiefan7162
Member#: 204462
2006 Forester XT
RBP
Oh I almost forgot, I will be installing TGV Deletes as well, and I know I have to make some changes for that as well which I also need help with, PLEASE PLEASE HELP!!!!!!!!!!!!!
Old 12-16-2013, 09:43 PM   #3
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Here's a thread all about it I found by searching. Seems to be pretty popular.
http://forums.nasioc.com/forums/show...ight=scale+maf
ProfessWRX is offline   Reply With Quote
Old 12-16-2013, 11:02 PM   #4
subiefan7162
Member#: 204462
2006 Forester XT
RBP
thanks I appreciate it, I just don't see the connect between the way he showed and the map itself, all the talk is in percentages and voltage values, where as the map is in g/s.... anyway I think I figured my MAF problem out, what about the changes needed for the Omni 4 bar MAP sensor, I've found the equation to rescale the MAP values but there is no manufacturer info on the sensor so the math is moot at that point. does anybody have the multiplier and offset values needed for the Omni 4 bar MAP sensor for subarus DBW? what about the fueling changes needed for TGV deletes?
Old 12-17-2013, 11:48 AM   #5
Drewswrx
Member#: 352498
2008 Wrx 2.5L
World Rally Blue
Fueling changes are made by tuning the car in real timing. you want to watch you af correction and af learning for your fueling and it's almost impossible to get good fueling maps without a wideband O2 sensor telling you exact AFR. I believe if you go to Cobbs web site under their support section for accesstuner they have a calibration worksheet where they have things for setting up aftermarket map sensor and I believe omni is one of the manufacures they list there too. You can also scale your MAF using AF correction and AF learning, the goal is to get them to equal as close to zero as possible +/-5%. I hope this helps a little and if I messed up with any of this please someone chime in and correct me but I think I covered it all.
Drewswrx is offline   Reply With Quote
Old 12-17-2013, 05:39 PM   #6
subiefan7162
Member#: 204462
2006 Forester XT
RBP
thanks man, I've got the MAP multiplier and offset I need and the MAF readings I have I got from my 07 STI map when I ran the same intake so I think those will work, if not I will correct them as needed. I have the Innovate XD16/ LC-1 wideband package so I have that covered as well. what do I need to do as far as the needed values for running TGV Deletes? CELs are already disabled in the map I'm building so check on that block, just need to make sure I get the right values calibrated for the tgv deletes and the rest I will be golden on.
Old 12-17-2013, 06:05 PM   #7
Drewswrx
Member#: 352498
2008 Wrx 2.5L
World Rally Blue
Ill be honest with you I don't think you have to make any adjustments there. I could be wrong but really all your doing is opening that up so air just moves nice and smooth and free with no restriction. So you get better air flow. If I'm wrong some one please chime in and correct me.
Old 12-17-2013, 06:27 PM   #8
subiefan7162
Member#: 204462
2006 Forester XT
RBP
I always thought the same, but I've been told as well that you have to richen your fuel mixture because TGV deletes cause a lean condition at cold start up, then again my setup runs rich at idle anyway so a little leaning out wouldn't hurt it.
Old 12-17-2013, 06:29 PM   #9
Drewswrx
Member#: 352498
2008 Wrx 2.5L
World Rally Blue
I would just keep an eye on it make sure it doesn't lean out too much.
Old 12-17-2013, 08:20 PM   #10
subiefan7162
Member#: 204462
2006 Forester XT
RBP
yeah I will be doing plenty of logs when I get everything installed and the map loaded. just wondering, is there a write up anywhere on how to change wastegate duty cycle and turbo dynamics maps for running an external wastegate with the grimmspeed bcs? that will be my next step as I move towards bigger turbo
Old 12-17-2013, 08:32 PM   #11
Drewswrx
Member#: 352498
2008 Wrx 2.5L
World Rally Blue
It's the same as with internal just the numbers will be lower. Set your boost target and I always start out with 10 for my low wgdc and 20 for high. From like 2000rpm down and adjust accordingly from there and your turbo dynamics I would go to Cobbs website they have some tuning write ups under Accesstuner support. Pm me if you need any help.
Old 12-17-2013, 09:37 PM   #12
subiefan7162
Member#: 204462
2006 Forester XT
RBP
thanks man you have been a lot of help and if I need anymore help I will be hitting you up! I will most likely re-ask the EWG question once I get the setup down the road again thanks man!
