Old 12-19-2013, 11:53 AM   #1
MattBrown0761
Member#: 150611
Default HELP: Part number for IAC Gasket 2006/2007 Impreza 2.5i
I can't seem to find the part number for JUSt the gasket for the IAC. I was told when I clean it I should have a new gasket in hand to put in. Is this true? If so does anyone have the part number. Car is a 2006/2007 Impreza N/A 2.5i. Thanks if you can pm me the part # it would be hugely appreciated...also do you clean it with the same spray you use to clean the MAF sensor?
MattBrown0761 is offline   Reply With Quote
Old 12-19-2013, 12:07 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Didn't they go to drive-by-wire in 2005, in which case there is no separate IACV?
Old 12-19-2013, 12:57 PM   #3
MattBrown0761
Member#: 150611
I don't know?? haha. What would cause my idle problem then if not the IACV?
Old 12-19-2013, 02:24 PM   #4
JohnM10
Member#: 244231
2006 Impreza 2.5i 5M
Crystal Grey Metallic
You can clean the throttle plate in the throttle body. If it gets gunked up it can't close completely and can cause idle issues.
If you remove it to clean it, you should replace the gasket. I used a Felpro gasket #61500 from Advance Auto Parts.
JohnM10 is offline   Reply With Quote
Old 12-19-2013, 08:35 PM   #5
MattBrown0761
Member#: 150611
haha i did that actually upon reading here on the forums. i sprayed it good, wiped around the edges of the plate...it said spray it then lightly rev the engine which i did. and i repeated that a couple of times till black stuff stopped coming off on the rag. maybe i will give it another shot.
in the morning when it's cold i can hear the engine surging like every 10-15 seconds. and i don't know if this is related but the heater in the car surges as well. i just replaced the battery too but that didn't change anything.
Old 12-20-2013, 08:43 AM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
haha Blind troubleshooting is a good way to throw away money. haha There are a variety of things that affect the idle. Without any explanation of what symptoms you're seeing it's awfully hard to offer you any advice.
Hopefully you didn't replace the battery hoping that was going to cure an idle surge. haha
You said this is happening when you start the car on a cold morning. haha Do you have the defrost on when this surging is happening? Defrost uses the A/C, so that 10-15sec surging could be the A/C compressor cycling.
