Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 10-13-2002, 08:43 AM   #1
Gravel-Fun
Member#: 18751
2000 Impreza RS
Default What is white stripe for on top of Sparco steering wheels?
I assume:
to center wheel more quickly when you are watching the gravel.
or to make the driver aware of suspension damage from last stage, because the stripe is now 3" to the right on the straights
Gravel-Fun is offline   Reply With Quote
Old 10-13-2002, 09:22 AM   #2
Tats
Member#: 5692
WTF? YES! I am
better than you!
Give that man a cigar!
Yep, I believe it's so you csn more easily tell when to wheels are facing straight ahead while driving.
Tats.
Tats is offline   Reply With Quote
Old 10-13-2002, 09:23 AM   #3
Tats
Member#: 5692
WTF? YES! I am
better than you!
Tats.
Old 10-17-2002, 12:21 PM   #4
jprowland
Member#: 7298
2008 STI Black
2002 WRX Wagon White
I put yellow tape on my steering wheel for rally-x. I find that it's really helpful in getting lots of "what's the tape for?" questions, and is worth absolutely nothing else with the stock steering ratio.
If I were running 1:1 steering lock, maybe it would be a huge benefit. At the rallyxes, though, all I see is this yellow blip fly through my field of vision several times on a turn.
jprowland is offline   Reply With Quote
Old 10-17-2002, 08:45 PM   #5
psoper
Member#: 7703
2002 WRX wagon
It isn't black, its blue!
Originally posted by jprowland
.......If I were running 1:1 steering lock, maybe it would be a huge benefit. At the rallyxes, though, all I see is this yellow blip fly through my field of vision several times on a turn.
Even 2 turns lock to lock would only have the tape at top either centered or at full lock, but consider the other use- " to tell that the suspension is damaged when your going straight and the tape is over 3" from where it was before the hit"
psoper is offline   Reply With Quote
Old 10-18-2002, 10:06 AM   #6
jprowland
Member#: 7298
2008 STI Black
I think most racing-spec Subarus are running 2.5 turns lock-to-lock. The stripe would still be useful then...
I do like the "alignment-meter" theory!
Old 10-18-2002, 10:50 PM   #7
aspera
Member#: 7879
This is worth doing if you drive in the snow. Sometimes you can't feel where the wheels are pointing, but you don't want to take your eyes off the road.
I lost my clock to the Defi pod. I might strap a wristwatch with a bright strap to the top of the steering wheel to try it out. Maybe I'll just use a leather strap, that way I can see AND feel the thing. Or maybe I could just slow my azz down.
aspera is offline   Reply With Quote
Old 10-18-2002, 11:31 PM   #8
SubaruWRC
Member#: 11063
2001 Impreza 2.5 RS
and bye bye Turtle :(
I get whats the tape for alot to
I rock my tape 24/7. it also adds to my yellow accents on my car inside and out.
It really helps when driving. and you can just see where the wheel is when turning.
Actually this was my first mod. ( if you can call it that)
Jiffy
SubaruWRC is offline   Reply With Quote
Old 10-18-2002, 11:42 PM   #9
BOFslime
Member#: 23845
2015 FLAT SIX
Jiffy
Must add 10 hp too.. Everyone know's yellow makes you go faster
BOFslime is offline   Reply With Quote
Old 10-19-2002, 12:05 AM   #10
aspera
Member#: 7879
Yeah, gotta punch speed holes in the tape for 5 more hp.
Old 10-19-2002, 05:38 PM   #11
Gravel-Fun
Member#: 18751
2000 Impreza RS
Yellow???? I thought they were white. Quick, someone find subiegal. She should know about this color.
Gravel
Old 10-20-2002, 11:25 PM   #12
jprowland
Member#: 7298
2008 STI Black
Gravel
Sparco makes some steering wheels with white stripes and some with yellow.
http://www.demon-tweeks.co.uk/drill....&whichway=DOWN
I used yellow electrical tape on my stock WRX steering wheel, matches the yellow trim.
What is the hose for on the blower motor assembly? wrxon Newbies & FAQs 2 08-05-2009 12:31 PM
what is the black box on back of engine? johnkaldar Pre-2002 Factory Turbo Powertrain 9 05-29-2007 11:55 PM
05 STI - need steering wheel hub for OMP/Momo/Sparco steering wheel AnorexicSTI Brakes, Steering & Suspension 0 10-12-2006 08:05 PM
What is the website for satellite photos of property? Sharkbait Off-Topic 11 07-21-2004 07:38 PM
Newbie question, what is that switch on top of the steering colum? anant369 Newbies & FAQs 6 05-10-2002 09:01 PM
