Old 10-13-2002, 11:20 AM   #1
Veck
Member#: 15661
Default UTEC Problem
I've been running fine now with my UTEC for a few days. Yesterday while driving to the store my car just flat died. After pushing it to the side of the road and waiting a few minutes the car finnaly restarted but had a persistant CEL. I got it home and pulled the code, its a P0103 Mass Air Flow Sensor circut high input.
If I remove the UTEC the car runs fine with no CEL. I put the UTEC back in either set on the stage 1 map or the stock map and I get the CEL and the car will die after about 1 minute of running.
I've made no modifications to the map at all. Anyone have any ideas what might be causing this ?
Veck is offline   Reply With Quote
Old 10-13-2002, 11:38 AM   #2
paul99se
Member#: 17822
Did you try switching the UTEC switch to "0" for stock mode and seeing if it will start?
-Paul
paul99se is offline   Reply With Quote
Old 10-13-2002, 11:50 AM   #3
Veck
Member#: 15661
Yes, it generates the same problem with the switch in position zero and position 1. In both cases it will start with the CEL on and throw the P0103 code then die after about 1 minute.
Old 10-13-2002, 12:06 PM   #4
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Make sure your dipswitches are U,D,D,D,D,U,U,U from 1-8
ORRRRRRR..... it sounds like you have a 550CC map and are running stock injectors, and your trimming out a LOT!
What mods did you tell them you had?
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 10-13-2002, 03:19 PM   #5
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
I had the same trouble code in my car too the other day (but my car didn't die)....along with three missfire codes from cyl 1,2,4. I had them reset it and managed to get a new map from Phil which seems to work really well now....
Are you SURE you have'nt changed anything?
ScoobieSnaX is offline   Reply With Quote
Old 10-13-2002, 03:32 PM   #6
Veck
Member#: 15661
Only engine related mods i've got currently installed are a BPM topmount IC, and the silencer hack.
The map thats loaded in position one is the standard stage 1 map 92 octane.
I currently have my switches as described on page 2 of the manual, from 1 to 8 UUUDDDDU.
If im reading everything correctly thats:
1 - Flash program - Normal
2- FCD Bypass - Safety On
3 - Spare
4 - O2 Select - Front O2
5 - O2 Select - Front O2
6 - Crank Out - Stock Crank
7 - MAF Out - Modified MAF
8 - MIL Out - Modified MIL
The switch settings you described are slightly different, you have FCD Bypass set to safety off, Crank Out set to Modified Crank, and MAF set to Stock MAF. For the stage 1 map do i really want Modified crank and FCD off ? I can understand changing to stock MAF might have an impact on the problem. Wish the manual had some info on when to select which signal output for the crank, maf and MIL.
Old 10-13-2002, 03:33 PM   #7
Veck
Member#: 15661
Yep im positive i've changed nothing. The only thing i've done at all in the way of programming is to make a backup copy of the map that was in position 1. I just did a copy map to position 2.
Drove the car to work and home on friday with no problems, went to drive it on saturday and then it died.
Old 10-13-2002, 03:39 PM   #8
Fickle
Member#: 24681
Good luck Veck. I hope you resolve this.
I'm glad I waited on the UTEC. I wanted to let all the bugs work out first. I would be extremely pissed if I spent 1k and my car had issues like this.
Fickle is offline   Reply With Quote
Old 10-13-2002, 04:07 PM   #9
jimb
Member#: 9923
2005 Legacy GT
RIP MBP WRX
Speaking of misfires, how does the UTEC fool the stock ECU into thinking it is really controlling timing? If it is a dedicated driver, with the stock ECU controlling timing as well, wouldn't the stock ecu think it was missing (radically different timing)?
jb
jimb is offline   Reply With Quote
Old 10-13-2002, 05:45 PM   #10
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Your right.. I'm on crack... You know you have a stage 1 map if your zero column position does NOT have negative values. That would insinuate larger injectors. Start with that.
Also, your MAP intercept and gradiant calibration could be off. Are they at the default 204/244?
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 10-13-2002, 05:46 PM   #11
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
jb
Not if it's seeing what it thinks it's asking for
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 10-14-2002, 12:23 AM   #12
Veck
Member#: 15661
Yep the MAP intercept and gradiant are at 204/244.
Old 10-14-2002, 09:35 AM   #13
nmyeti
Member#: 4980
Call us today, we'll get a new one out to you overnight... although from the CEL i wonder if you have a bum MAF sensor.
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
Old 10-14-2002, 01:14 PM   #14
Veck
Member#: 15661
Called in this morning. New unit on the way.
I reverted the car back to stock running directly off the factory computer and drove to work this morning with no problems.
Old 10-14-2002, 09:50 PM   #15
Fickle
Member#: 24681
Veck, what other mods do you have?
I'm sure Nathan will take great care of you man. TurboXS gets two thumbs up.
CEL with UTEC... problem sneeky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 05-25-2004 05:53 PM
Hypterterm/utec problem Shamr0ck Engine Management & Tuning 1 01-02-2004 11:18 AM
Major Utec Problems, Please Help! rexmobbin' Engine Management & Tuning 9 12-16-2003 10:39 PM
Utec problem- car won't start V REX Engine Management & Tuning 0 09-06-2003 09:44 PM
Attn: Phil @ TXS major Utec problems/knocking someone please help Jay04WRX Engine Management & Tuning 66 08-02-2003 02:22 PM
