Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 01-07-2014, 05:15 PM   #26
UBYSUBIE
Member#: 361447
2006 Impreza2.5iWgn
Well I am glad I read this post before I started messing around. New to AWD. did not know it was a bad thing in this type of drivetrain. Good to know!
UBYSUBIE is offline   Reply With Quote
Old 01-07-2014, 05:44 PM   #27
DannyCantShuffle
Member#: 377789
2002 Impreza outback
Same as above, I have an automatic impreza wagon and i love drifting in my civic that i now crashed. I was constantly using the E-brake a lot.
But now I know not to use it to...... drift or powerslide w/e.
DannyCantShuffle is offline   Reply With Quote
Old 01-07-2014, 08:27 PM   #28
CNY_Dave
Member#: 354655
Like I said, with an auto you could set it up to disconnect the AWD whenever the E-brake lever is up..
CNY_Dave is offline   Reply With Quote
Old 01-08-2014, 02:38 AM   #29
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
Originally Posted by rkramer View Post
Federal DOT specs would disagree with you. It is absolutely an E-brake, there are better ways to design a parking brake if it doesn't have to serve a dual purpose. (locking pawl design, not friction...)
(federal standards say that unless you have a completely redundant system, including 2 master cylinders, you need a secondary independent brake system that can stop the car.)
Anyway though, EMERGENCY brake... As in the ex-wife cut the brake lines and you need to use it to avoid driving off the cliff in front of you. Drifting doesn't count as an emergency!
All the reason to upgrade to ss lines. Unless your ex wife has a sawzall lol.
Scoobiesdoobies is offline   Reply With Quote
Old 01-08-2014, 12:08 PM   #30
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Doing this with a 5MT car is always bad. Doing it in a 6MT car is fine as it decouples the center diff, but I still wouldn't do it. Also fine to do it in an autox based on how the auto transfers power front to rear, still wouldn't do it though.
Tony
Old 01-08-2014, 01:17 PM   #31
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Tony
You should refine that to 6MT with DCCD, as I think the non DCCD 6MT cars like the Legacy/etc still have a center diff that doesn't decouple.
I know for sure that you can pull it on at least the 04 and 05 STi w/o things exploding... not sure the diff characteristics on anything newer than that.
I personally have popped the circlip off my 5MT center diff twice with NO e-brake pulls. Not sure how it's come off each time, but on each rebuild I've had the clip has been off (One rebuild because front input shaft bearing failed, taking 2nd gear with it, second rebuild because rear output shaft bearing failed).
-- Dave
AcquaCow is online now   Reply With Quote
Old 01-08-2014, 03:17 PM   #32
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
I have a vtd 4EAT 60 rear 40 front i believe is the % split.
Does my center diff decouple when the ebrake is blipped? Never tried nor wanted to try it lol. Sometimes i can get my car sideways with the ass out just using throttle and steering since mines essentially rear wheel drive bias.
Old 01-08-2014, 03:23 PM   #33
CNY_Dave
Member#: 354655
The VTD diff is a planetary gearset, all mechanical. If you do not have VDC I'm not sure if you have the lockup clutch (VDC has VTD plus a multi-plate clutch, similar to the non-VDC MPT but it has fewer plates).
If you have the clutch it is possible the computer would see the excessive front-rear speed difference and lockup the clutch.
The Gen 2 outback VTD has 45/55 front/rear, not sure about other years/models.
Old 01-08-2014, 03:30 PM   #34
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
Mines 06 wrx. I to find a jdm triptonic and drop it in real bad!!!!
Dont know if mine can be converted.
Should have bought a lgt 5EAT if i wanted some luxury huh....
I think mines 55/45 now that you say that....
Old 01-08-2014, 03:42 PM   #35
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
What the **** is this ****?
Psychoreo is online now   Reply With Quote
Old 01-09-2014, 01:00 AM   #36
HyG3nx
Member#: 355826
09 WRX hatch
Obv don't do what OP did re e brake, park brake whatever, it's just too bad not knowing a small amount of fun had to damage his ride. However with the snow everyone is having I too find my self turning off my vdc daily when going thro snow and most of the time it will be spinning tires, sliding about and every now and then when safe I give it a bit of kick out with the rear end cause it's fun. Nothing major at all, but how will that affect that center diff with spins and such bc of the snow?
HyG3nx is offline   Reply With Quote
Old 01-09-2014, 12:24 PM   #37
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
Its called a forum post.
Your guru powers should have picked that up though......
Go back under your bridge now since your trollness is not needed here
Old 01-09-2014, 12:33 PM   #38
Psychoreo
Member#: 79643
2015 WRX STI
It's not even in engrish. Deciphering that garbage is near impossible.
Old 01-09-2014, 12:58 PM   #39
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
I forgot the word "want" at the beginning of my post.
Keep walkin troll
Old 01-09-2014, 12:59 PM   #40
Psychoreo
Member#: 79643
2015 WRX STI
Keep walkin troll
There's also no such thing as a subaru JDM "triptonic."
Keep trying n00btits.
Old 01-09-2014, 02:05 PM   #41
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
Its a sport shift 4eat with paddle shifters and available in the JDM.
Sorry for the misprint again.....asshat
Old 01-09-2014, 04:01 PM   #42
evilspoons
Member#: 321311
2012 STi 5-door
World Rally Blue
Originally Posted by HinshawWRX View Post
What happens when you pull an "emergency brake" at highway speeds? You loose control, hence why no one teaches that it is anything aside from a parking brake.
Well, you don't @#$%ing yank on it. You press your service brakes, car doesn't stop because they've failed. You then grab the emergency brake and pull it enough to begin slowing the car but not enough to lock up the rear wheels... remember, your e-brake doesn't have ABS...
If you actually read the user's manual that comes with your very expensive, potentially-dangerous machine, one of the warnings you will see is:
CAUTION: Pulling the parking brake lever too forcefully may cause the rear wheels to lock. To avoid this, be certain to pull the lever up slowly and gently.
evilspoons is offline   Reply With Quote
Old 01-09-2014, 11:23 PM   #43
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
You realize you made my point right. The manual says "Pulling the PARKING BRAKE LEVER."
Not an "e-brake."
Anyways, people aren't smart enough to read the manual. Or understand to shift an automatic car into a lower gear/neutral if the accelerator sticks on your Toyota. You honestly think they'll be smart enough to SLOWLY pull the PARKING BRAKE lever?
Old 01-09-2014, 11:47 PM   #44
subergoo
Member#: 141237
2003 Impreza WRX
cant we all get along?
OMG!!!!
E brake , hand brake, parking brake, lets lock up the rear brake, gymkhana power hour brake!!!!! Who the F really cares we all know what we are talking about here!!!!
It's like the " high capacity clip/magazine bit" (it's a magazine BTW)
And FTR , just call it the hand brake
subergoo is offline   Reply With Quote
Old 01-10-2014, 12:00 AM   #45
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
Originally Posted by subergoo View Post
OMG!!!!
Yup. People say clips from the stripper clips and bolt action clips. Very different than a magazine. Same concept initially. Feed the firearm!
Old 01-10-2014, 12:36 AM   #46
subergoo
Member#: 141237
2003 Impreza WRX
Totally an off topic discussion but DAMN!!!! I can relate!
It's a FREAKING MAGAZINE !!!! Not a CLIP!!!!
So on topic, it's actually nothing like the clip/magazine difference , because there actually is a difference between a clip and and a magazine ! Where as there is no difference between an E brake and a hand brake or a parking brake ! its just different names for the same thing!!!!
Ok sorry
I'm done
Old 01-10-2014, 01:02 AM   #47
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
Does the tesla model s have real emergency breaks? I dont know if those are charging mechanisms or secondary calipers i keep seeing on the road.
Old 01-10-2014, 11:48 AM   #48
DisrupTer911
Member#: 352071
2013 Impreza WRX
Dark Grey Pearl
next time just just turn VDC off and mash teh gas!
or for more fun, pull the ABS fuse or wire in a switch
DisrupTer911 is offline   Reply With Quote
Old 01-10-2014, 01:32 PM   #49
CNY_Dave
Member#: 354655
I had no idea the Pedants Society met here...
Old 01-10-2014, 03:08 PM   #50
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
I think everyone who drives a subaru becomes a pedant sooner or later. I didnt give a **** about maintenance or anything before i drove a subaru and found out if you blow a tire you likely blow $700 for a set of 4 new ones.....
Btw dont go by tread depth or youll "shoot ur eye out" when u find two alike tires differ in tread depth and are the same OD.......
