Old 10-13-2002, 05:42 PM   #1
dark knight
Member#: 9927
06 Sti
Default gauge wiring clock wire ? help
arrgh, am frustrated, have wired my defi gauge controler and black out gauges into clock harness w/ vampire connectors as supplied, now gauges light up w/opening ceremony then go dim, if i turn light switch on gauges come on, i wired the defi controlers white light wire into the clocks light wire (pink w/blue stripe), what did i do wrong, how do i fix it , i dont care if the gauges dont dim i jsjut want them lighted all the time, i've been told to ground the white wire, why? or wire the white light wire into the clocks ignition wire also, so which should i do?
TIA
Dark Knight
dark knight is offline   Reply With Quote
Old 10-13-2002, 05:54 PM   #2
WhatleyWRX
Member#: 6634
2002 WRX Sedan, Dirt
with some Silver patches
If you want them on all the time, run switched power to the dimming circuit. Then anytime the ignition is on your guages will be lit up.
Whatley
WhatleyWRX is offline   Reply With Quote
Old 10-13-2002, 07:46 PM   #3
dark knight
Member#: 9927
06 Sti
so even if i have another tap on the ign wire already i can add the lightswitch to it too?
Old 10-13-2002, 11:13 PM   #4
Visceral
Member#: 16367
2006 Subaru WRX STi
Here's how I have mine wired:
DEFI->Clock
White -- Pink/Blue Stripe
Black -- Black
Orange -- Yellow/Green Stripe
Red -- Blue/Purple Stripe
Gauges are lit all the time and dim when lights are turned on.
Visceral is offline   Reply With Quote
Old 10-14-2002, 12:03 AM   #5
dark knight
Member#: 9927
06 Sti
thats exactly how i had mine wired, the gauges which are the defi BF series, and 2nd gen controller, stayed dark until the lights came on then they came on they did not dim, what have i done wrong?
Old 10-14-2002, 12:41 PM   #6
Visceral
Member#: 16367
2006 Subaru WRX STi
Hmm, I'm not sure. I have the same exact setup (BF gauge, Link V2).
On the control unit, do you have the gauges in the second meter socket (labelled "METER OUTPUT 2")? The first output is for the regular (non-BF) gauges.
-Mike
Old 10-14-2002, 06:55 PM   #7
WhatleyWRX
Member#: 6634
Well, as for the dimming issue.....do these guages have a two wire dimming connection? Otherwise, there is no way to simply wire them up and have them dim. Just live with the on/off lighting.
Most automobiles use a hot reference rather than a ground reference for dimming lights. They like to babble about it being easier to sink current than source it. Eh, its all sparky nonsense to me, but that's how they do it so you'd need a two wire connection to get it to work.
I'm sure that's old news....
Whatley
Old 10-14-2002, 07:26 PM   #8
dark knight
Member#: 9927
06 Sti
thanks thanks thanks to viscreal, that was the problem I was using the wrong defi meter output, i used output 1, now that hooked up output 2 the gauges work perfectly, thanks a milllion times over, man this I-club thing is great
Prosport gauges wiring clock pod kakarotoni Electrical & Lighting 4 08-25-2009 02:59 PM
Help w/ Boost Gauge Install using clock wiring astrange22 Electrical & Lighting 1 09-14-2008 12:38 PM
HELP: wiring gauge into clock blew fuse soukihei Electrical & Lighting 2 09-11-2005 04:36 PM
Omori gauges using clock wiring? quazimoto Electrical & Lighting 2 01-06-2005 11:01 PM
Can the clock wiring support 2 gauges cre Electrical & Lighting 11 10-21-2003 09:36 PM
