Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 01-02-2014, 03:09 PM   #1
subeast559
Member#: 377560
2006 STi
Question stage 2 xpt map question...
Sorry if this was covered somewhere but i never came across my question during my research into OS...
Basically i just put my catless downpipe on, also has cat back, k&n drop in, snorkus removed and a tomei turbo inlet.
I think for now I'm going to purchase the $150 stage 2 xpt map and flash it onto my car with ecuflash and do some logging in romraider.
My main question is if there is a way to add the launch control patch to these xpt maps? I couldn't find any sources to get the launch control.
Edit- this is the map i will be purchasing
http://www.xpttuning.com/index.php?m...products_id=26
subeast559 is offline   Reply With Quote
Old 01-02-2014, 05:28 PM   #2
quazimoto
Member#: 70395
Why don't you email XPT and ask them?
quazimoto is online now   Reply With Quote
Old 01-02-2014, 05:52 PM   #3
Dillinja666
Member#: 332644
07 STI
It's white
Also go ahead and get a electronic boost control solenoid now and map for it. Helps build boost faster then the stock one. I only suggest since you are asking about launch control and it sounds like you want the off the line powa
Dillinja666 is offline   Reply With Quote
Old 01-03-2014, 11:05 PM   #4
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Xpt maps are garbage. Experince is why i know. 1 map does not work on all cars. Every car is different though it may look the same.
Get a local well known tuner or a well known etuner.
I use Cory at Mayhem Tuning.
cosseywrx is offline   Reply With Quote
Old 01-03-2014, 11:14 PM   #5
bjohnson_55
Member#: 216580
+1 for Cory. Good guy and great tuner
bjohnson_55 is offline   Reply With Quote
Old 01-04-2014, 03:43 PM   #6
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Why not get a free stage 2 tune and do some data logging and fine tune it? Sounds like you're planning on paying to do the same thing...
I used merps software to patch ffs, lc, sd to mine for free.
ProfessWRX is offline   Reply With Quote
