Old 01-04-2014, 09:47 PM   #1
fatman13
Member#: 368465
Default ewg before tune
Ok so heres the deal im installing an ewg at home and was wondering how i should set everything up mainly the vacuum lines so i can drive to the tuner (45 min drive). Can i install the iwg bracket as long as i dont get into boost? Also have a grimmspeed ebcs but i heard i should just install that when i get there.
fatman13 is offline   Reply With Quote
Old 01-05-2014, 10:40 AM   #2
quazimoto
Member#: 70395
Just run wastegate pressure. Takes about 10 minutes to install a EBCS. Just do it there.
quazimoto is offline   Reply With Quote
Old 01-05-2014, 10:57 AM   #3
mikeydrives1
Member#: 262117
2001 Forester
STi II type M
You can install everything as long as you drive the car conservatively from now until its in the tuners hands. The setup will want to hit boost quicker but as long as you drive it slowly, under 3500rpm and don't do any wot pulls , there should not be an issue.
mikeydrives1 is offline   Reply With Quote
Old 01-05-2014, 12:15 PM   #4
fatman13
Member#: 368465
Thanks guy to run the ewg on spring pressure would I just put a vacuum line straight to the side port on the ewg from the turbo housing nipple? And then block off the remaining stock vacuum lines?
Old 01-05-2014, 02:25 PM   #5
quazimoto
Member#: 70395
Yup. Then just install the EBCS once you get there and get it tuned.
