Old 01-06-2014, 01:54 PM   #1
9won4
Member#: 377935
Hey Guys, Been Lurking this forum for quite a while done as much homework without asking "noob questions". I installed a V3 Access port on my "14" WRX. Car has 1000 miles of proper break in, less a spirited dash or 2 to seat the rings. 1) I was wondering if you guys would be kind enough to take a look at my datalogs and give me your feedback. (hoping I linked them correctly) 2) I was also wondering what key parameters you guys would be monitoring on the guages of your access port (it seems like a great tool past the re flash apect I'd like to fully utilize it) 3) I was wondering if there was a way to run my "Bone stock tune" without unmarrying my device (Just curious) Thank you for the time guys!! *Yes I will be getting a protune after getting a couple what I will reluctantly call "stage 2" upgrades............Just want to make sure the car is running safe
Stage 1 93- (1st run) https://docs.google.com/spreadsheet/...4WDBEYVE#gid=0
Stage 1 93 HW map https://docs.google.com/spreadsheet/...VE&usp=sharing
Stage 1 93 2nd Run https://docs.google.com/spreadsheet/...VE&usp=sharing
Stage 1 93 3rd Run https://docs.google.com/spreadsheet/...VE&usp=sharing
9won4 is offline   Reply With Quote
Old 01-06-2014, 04:45 PM   #2
9won4
Member#: 377935
**Sorry mods please move under accessport section. thanks
Old 01-06-2014, 08:13 PM   #3
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Logs look good. No glaring issues at all. Looks like you are hitting target boost on both wastegate maps by 2900rpm.
I don't have an accessport, but for gauges it really depends on what YOU want. At this stage there's no need for anything beyond boost.
I would assume you can switch to the stock map without "unmarrying." But again I don't own one. But the stock map is built into the software so you should be able to throw it onto the AP with your AP manager software so you can switch to it as you want. But why?
ProfessWRX is offline   Reply With Quote
Old 01-06-2014, 11:51 PM   #4
9won4
Member#: 377935
I solely wanted to apply rhe stock map for
the purpose of Dataloggjng it. I want to Learn as much as possible and attempting to gain an understanding of subaru's parameters and why?may be helpful
Old 01-07-2014, 09:58 AM   #5
9won4
Member#: 377935
Which map looks more appropriate (or like a better fit for my specific car?)
Old 01-07-2014, 02:02 PM   #6
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Which gear were the pulls made in? So far i'd go with the low wastegate one.
Old 01-07-2014, 02:28 PM   #7
9won4
Member#: 377935
3rd gear pulls.
What makes you say low wastegate? (just curious as to what I should be looking at)
Thank you!
Old 01-07-2014, 02:41 PM   #8
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Originally Posted by 9won4 View Post
3rd gear pulls.
Thank you!
You want the lowest wastegate duty cycle that gets you full boost as soon as possible. According to these logs both get you identical spool. Higher wgdc will potentially cause overboosting in 4th or 5th. So stick with the lower one.
I didn't look at the boost levels in higher rpm. There is a possibility of the hw map helping you hold boost longer in the revband than the lw map depending.
I looked at your boost vs rpm vs target boost columns to make my choice.
Old 01-07-2014, 03:03 PM   #9
9won4
Member#: 377935
Ok I see what you are referring to
Old 01-07-2014, 03:12 PM   #10
snoopy_sti
Member#: 164942
2015 Porsche Cayman
Yeah stick with the NWG or LWG map.
snoopy_sti is offline   Reply With Quote
Old 01-07-2014, 03:39 PM   #11
9won4
Member#: 377935
When I get a second I'll load the LWG map and log it.......If you wouldn't mind taking a look at that
Old 01-07-2014, 06:29 PM   #12
snoopy_sti
Member#: 164942
2015 Porsche Cayman
My bad....
I just did another quick look at your logs.... I think they are all the same log even though you indicated they were different pulls and one was the HWG map.
What Map were you using?
You are showing a TD error of -1.32 at 3187 RPM in all the logs. So you are 1.32 lbs above your target boost. So if you need to go down a map, i.e. if they were in the HWG map go to NWG, if it were NWG, go to LWG map.
Old 01-07-2014, 06:35 PM   #13
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
That's sad that I didn't notice. But I was on my phone so I have a pretty good excuse.
Old 01-07-2014, 11:21 PM   #14
snoopy_sti
Member#: 164942
2015 Porsche Cayman
it happens.
Old 01-10-2014, 01:38 PM   #15
9won4
Member#: 377935
My bad....
it happens.
It's quite possible, as this was the first day I had loaded up my software, attempted to import files over to "google docs" etc.
Now that I'm familiar with the unit. and how to post logs onto this site, I'll redo them and make sure I get all the maps laid out correctly.
For now I'll run the LWG map to be safe. Thanks for your help guys.
