Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 10-22-2000, 08:18 PM   #1
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Question POLL: What tires will you be running this winter? Brand & Size...
Just curious, and also include why you chose the tire you chose.
I will be running on my half used up RE92's which did well in the Colorado Springs snow between Feb-May of this year. I suspect they might suck now, since most of the factory siping was burned up in autocrossing this summer before I switched to RE730's
The BFG R1's and RE730's will stay in the garage...
Larry www.ImprezaRS.com
ImprezaRS dot com is offline   Reply With Quote
Old 10-22-2000, 10:31 PM   #2
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
The yoko A520s in 205/50/16s
Then again, Utah has a LOT less persistent snow than CO down in the valley.
DLC is offline   Reply With Quote
Old 10-22-2000, 10:37 PM   #3
ImprezaRS dot com
over boosted again
Member#: 1458
Post
Hmmmm...
Eric Gagnon of http://reperformance.8m.com (also in egroups SPCR) once told me that his A520's "sucked" in the snow. He is up in Bozeman Montana. Good thing you don't get much snow.
Next?
Larry
Old 10-23-2000, 04:55 AM   #4
uktena
Member#: 1267
Exclamation
Larry,
Last winter I ran Hakkapolita Q's on the OBS; I really don't think you can get a grippier tyre. The only problem is they will "cup" from the heat.
uktena is offline   Reply With Quote
Old 10-24-2000, 01:05 AM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
I will be running my mostly used up RE92's. We shall see how they fair(sp?) in the snow after 6 autocrosses.
Old 10-24-2000, 01:23 AM   #6
Eric Gagnon
Member#: 46
2001 Jetta 1.8T
Smile
I am running 185-65-15 Hancook Studded snow tires. We get a fair amount of snow up here so i like the narrow tread design and the studs for extra traction. I have drivin both studded and studdless on the RS and i still like the traction on the studded tires. Then again we usually have about 2-3 months when we don't see pavement, Just snow and ice covered roads.
On a side note: If you spend alot of time on the highway or paved roads stay away from studded tires. They are loud and handle poorly. Look at the Blizzack and Pirrelli. Both are very nice and handle well.
Eric
e_gagnon@altavista.com
Eric Gagnon is offline   Reply With Quote
Old 10-24-2000, 01:24 AM   #7
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
copec says his 215/50/16 a520s are better in the snow than the RE92s that came with it.
Go figure!
In Bozeman, the snow falls and usually doesn't melt the whole year. If we have snow on the streets for more than 2 says its unusual.
Tis the Summer what sunglasses will you be sporting! KillerKongFu Off-Topic 45 03-17-2005 06:01 PM
STI folks, what type of wheels/tires will you use for the winter? 516_WRX_V2 Tri-State Area Forum 6 10-13-2003 09:31 PM
what tires are you guys running here in vancouver?? superhero Vancouver Impreza Club Forum -- VIC 35 05-29-2003 03:31 PM
Poll: what tires did you replace your re92s with? Langit Brakes, Steering & Suspension 113 03-30-2002 10:52 AM
For those with 17" rims, what tires are you guys running in snows? malelee21 Brakes, Steering & Suspension 15 10-24-2001 07:33 PM
