Old 10-14-2002, 02:57 AM   #1
N/A01RS
Member#: 22478
2002 WRX Sedan
Platinum Silver
Default UTEC Question (should be an easy one)
I was looking on TurboXS's website where it shows what they use for their 11 sec car and it lists both the UTEC and a manual boost controller. I was under the impression that the UTEC controlled boost. Is the boost controller neccessary? Is there any benefit to having the boost controller with the UTEC? Is the manual boost controller any better or worse than an elecronic one such as the blitz SBC-R?
N/A01RS is offline   Reply With Quote
Old 10-14-2002, 03:00 AM   #2
DiMensionX
Member#: 23517
Fine tuning, trust me you want it.
Shawn
DiMensionX is offline   Reply With Quote
Old 10-14-2002, 03:19 AM   #3
N/A01RS
Member#: 22478
2002 WRX Sedan
Platinum Silver
Ok, so is it worth it to spend the extra money for a electronic boost controller or just stick with the turboxs unit?
Old 10-14-2002, 03:37 AM   #4
DiMensionX
Member#: 23517
Stick with the TXS unit, as the SW progress's it will outperform anything you can buy. An EBC actually is not going to help you as it is interfering with one of the key features of the UTEC. I'm at 20PSI all day long, though I still get a little change based on air temp (drastic changes in air temp).
One mod at a time, keep it simple.
Shawn
Old 10-14-2002, 03:47 AM   #5
N/A01RS
Member#: 22478
2002 WRX Sedan
Platinum Silver
what is a SW? By the way I think the plan will be too go with a Stage 4 UTEC with top mount intercooler. Only exception will be the use of a maxim or generation plastics exhaust manifold/uppipe instead of the turboxs uppipe. Nothing to crazy.
Old 10-14-2002, 08:42 AM   #6
paul99se
Member#: 17822
SW=software
Yes, you will need the TXS ABC for fine tuning of max boost, but the software will take care of your boost curve nicely.
-Paul
paul99se is offline   Reply With Quote
STI: 31K miles on it and will be an easy fix cryptor3 South West Impreza Club Forum -- SWIC 3 03-31-2007 01:01 AM
Would tattooing the blind be an easy gig? Spheris Off-Topic 12 12-20-2006 09:37 PM
injector question. should be easy for suby guru. exwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-03-2006 11:53 AM
Another computer question..should be an easy one ToddZ199 Off-Topic 10 12-14-2005 11:36 AM
UNIX Gurus - might be an easy question - moving files. Jard Off-Topic 16 06-14-2005 01:25 PM
