Old 01-09-2014, 01:20 AM   #1
legspecb08
Member#: 301932
Default Legacy Spec B, HMS EFR TS build
I figured its time to start a build thread as my car is nearing completion. The car is a 08 Spec B. I originally was waiting for the 7670 EFR turbo that didn't come after a year so I was able to get a 8374. The build is currently in the hands of Horizontal Motorsports in Tualatin, OR.
Build:
Block:
EJ257 case halves
AWD Darton Sleeved
Cosworth Pistons w/ Thermal barrier coating on top, Dry Teflon on side and oil shedding on bottom
Carrilo Rods w/ oil shedding coating
STI Nitrated Crank w/ oil shedding coating
ACL Race bearings w/ Dry Teflon coating
Killer B oil pan w/ Thermal dispersion coating
Killer B Windage tray w/ oil shedding coating
Killer B Pickup w/ oil shedding coating
Heads:
D25 stock heads
ARP 625+ Head Studs
MPS Signature porting and multi angle valve job
Exhaust Ports coated w/ Thermal barrier coating
Combustion Chamber coated w/ Thermal barrier coating
Ferrea Valves +1 Intake w/ Thermal barrier coating on face
Ferrea Valves Exhaust w/ Thermal barrier coating on face
GSC S2 Cams w/ Dry Teflon coating
GSC Beehive Springs w/ Dry Teflon coating
GSC Titanium Retainers
HMS Air Pump Delete
Intake:
Motive Autoworks TGV Deletes (Plastic)
Stock Intake manifold
ETS FMIC w/ Thermal Dispersion coating
ETS Custom Titanium piping
ETS Custom 4in Intake
Exhaust:
EFR 8374 1.05ar TS External Gated
Full Race Twin Scroll header, up-pipe w/ Thermal Barrier coating and DEI Titanium wrap
Full Race 3in Down Pipe w/ Thermal Barrier coating and DEI Titanium wrap
2 Tial MVS 38mm Wastegates
ETS Custom Dump Tubes w/ Thermal Barrier coating
AVO mid and y pipe with resonator w/ Thermal Barrier coating
AVO mufflers w/ Thermal Barrier coating
Fuel:
HMS Custom Fuel System
ID 2000 Injectors
Aeromotive Fuel Rails w/ Black Anodizing
HMS Custom Fuel lines -8 Feed/ -6 Return
AEM Fuel Pressure Regulator
HMS Custom Surge Tank w/ Black Anodizing
2 Bosch 044 Inline Fuel Pumps
DW 65c Lift Pump
Aquamist HFS-4 Water/Meth Injections system
Howerton Engineering 2 Gallon Twin Tank Enclosure w/ cooling fan
Transmission:
Stock 08 Spec B Tranny
Competition Twin Disc Clutch
Cobb Short Shifter and Bushings
DCCD (Uninstalled currently)
Electronics:
Hydra Nemesis 2.7 Standalone
3.5 Bar Sensor
Speed Density
AEM Air/Fuel, PSI
Aquamist DDS3
AVO Turbo Timer
Wheels:
04 Sti BBS Painted Midnight Black
Suspension:
Bilstein Shocks w/ Tein S Type Springs
Fab:
ABS Valve Body relocation By Rhom Innovations
Battery Relocation to Trunk By Rhom Innovations
HMS Custom Trunk Setup
Misc:
Grimmspeed Brake Master Cylinder Brace
Aluminum Battery Box Anodized Black
Torque Solutions Engine and Trans Mounts
I'm sure i am missing things but I'll updated as I go. Pics soon to come
legspecb08 is offline   Reply With Quote
Old 01-09-2014, 01:20 AM   #2
legspecb08
Member#: 301932
saved for pics
Old 01-09-2014, 06:39 AM   #3
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
I see you're going with a budget build
This ought to be good. What is the nature of thermal coating?
A-man07 is offline   Reply With Quote
Old 01-09-2014, 10:04 AM   #4
legspecb08
Member#: 301932
The thermal barrier will help keep the heat where it is is supposed to be and out of the rest of the motor
Old 01-09-2014, 10:09 AM   #5
Wolfie_OBXT
Member#: 364484
2006 OBXT
Very nice build and very similar to what I am doing with My Obxt. I am still having a hard time deciding on whether or not to run a surge tank or not.
Wolfie_OBXT is offline   Reply With Quote
Old 01-09-2014, 10:17 AM   #6
A-man07
Member#: 271525
07 STi
Yes I know its purpose, but what type of coating is it supposed to be and where did you have it done? Seeing as you have coated the piston tops and combustion chambers it better be exceptionally durable. For example, my piston domes were done by Swain Tech (TBC coating).
Old 01-09-2014, 11:00 AM   #7
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
In for pics, too.
LatentWagen is offline   Reply With Quote
Old 01-09-2014, 12:17 PM   #8
m.bryant
Member#: 310077
2007 Legacy GT SpecB
Subscribed for another big legacy build.
m.bryant is offline   Reply With Quote
Old 01-09-2014, 12:25 PM   #9
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
this should be interesting to see!
jnorth85 is offline   Reply With Quote
Old 01-09-2014, 07:28 PM   #10
sultanofsubguns
Member#: 351404
02 WRX Wagon
ProbablySomethingMundane
Saw this car there when I stopped by to talk about building me a new motor since mine popped, Can't wait to see the final results. Do you plan on dynoing it after the build or are you just going for a street tune?
sultanofsubguns is offline   Reply With Quote
Old 01-10-2014, 12:12 PM   #11
legspecb08
Member#: 301932
The coatings were done by finish line coatings. I can't recall the manufacturer of the coating tho
Old 01-10-2014, 01:12 PM   #12
legspecb08
Member#: 301932
Dyno results are coming to. Probably gonna run it on English's dyno
Old 01-10-2014, 01:39 PM   #13
danny_d19
Member#: 180748
2013 Scion FRS
Whiteout
This sounds ridiculous (in a good way ) Can't wait to see it
danny_d19 is offline   Reply With Quote
Old 01-18-2014, 12:46 PM   #14
legspecb08
Member#: 301932
found a similar build the other day. car put down 675awhp. cant wait to get this thing finished and out on the road
Old 01-18-2014, 11:18 PM   #15
thisisthenewsic
Member#: 156829
05 legacygt,00 OBS
red 95 supercharged nsx
PICSSSSS!!! where are the pics!
thisisthenewsic is offline   Reply With Quote
Old 01-27-2014, 11:16 PM   #16
legspecb08
Member#: 301932
Haven't been down to take them yet. Hopefully should have some this friday. Having issues with clutch fitment.
Old 02-03-2014, 07:20 PM   #17
legspecb08
Member#: 301932
How do u post pics on here
Old 02-03-2014, 07:40 PM   #18
jaymmmbee
Member#: 296967
2006 spec.B
Ti Silver Metallic
Just host the pictures on a site like Photobucket or similar, then put the share URL in IMG tags.
i.e. [IMG]pictureURL[/IMG]
jaymmmbee is offline   Reply With Quote
Old 02-03-2014, 07:49 PM   #19
Layvon
Member#: 195711
STi 04/05/06/07
Use imageshack.us so much better than photobucket.
Upload and copy the forum code. Done.
Layvon is offline   Reply With Quote
Old 02-03-2014, 09:09 PM   #20
atomicfire
Member#: 136296
2005 STi
Use Imgur so much better than Imageshack
atomicfire is offline   Reply With Quote
Old 02-10-2014, 02:02 PM   #21
legspecb08
Member#: 301932
Old 02-10-2014, 02:02 PM   #22
legspecb08
Member#: 301932
Old 02-10-2014, 02:03 PM   #23
legspecb08
Member#: 301932
Old 02-10-2014, 02:07 PM   #24
legspecb08
Member#: 301932
The pics are of the fuel system. Car is close to being finished but ran into a problem with the competition twin disk as the fly wheel didnt clear the back of the block.
Old 02-10-2014, 02:27 PM   #25
legspecb08
Member#: 301932
