Old 01-10-2014, 12:27 PM   #1
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Default Cam's 2006 WRX Wagon, EFR9180 Full Race, 746 WHP uncorrected at 5400'
Update at post 49, 772 uncorrected
Event: Dyno Tune
Ambient Temp: 60* inside
Elevation: ~5,400ft
Weather: Cold
Tires: Hoosier 245/45R17 on Stock BBS
Car: 2006 WRX Limited Wagon
Tuner: Cam
Tuning Software: AEM Series 1
Dyno Info: Dynojet
Transmission: 205 STI 6 Speed, rallispec long gear set
Gear: 3rd
Peak HP at RPM: 746 WHP @ 7,500 RPM
Peak Torque at RPM: 592 WTQ @ 6,200 RPM
Baseline hp/tq for a stock on same dyno: ~195WHP Stock STi
Target Boost: 33psi peak, tapering to 29psi
Target AFR: 11.4:1
Fuel: E70 Winter blend
Engine:
OEM 2005 STI 2.5L Case, Benson sleeves, O-ringed
OEM 2006 STI Heads
OEM STI Nitrided Crank
OEM STI 11mm Oil Pump
JE 100mm 8.5:1 Pistons
Manley Turbo Tuff I Beam Rods
Cosworth Rod and King Main Bearings
ARP 625+ Head Studs
GSC S3 Camshafts
GSC Beehive Springs w/Retainers
BC +1mm valves
Intake/Exhaust/Fuel:
Full-Race Twinscroll turbo kit
STM Aluminum cat back
Borg Warner EFR9180 1.05 AR turbo
Cosworth intake manifold
Treadstone FMIC, custom 2.75" piping, reverse manifold
ID2000's
Integrated Engineering surge tank, Dual 044 pumps
-8 Feed, -6 return
Drivetrain/Transmission
2005 STI 6MT, Rallispec long gears
OEM 2005 STI Driveshaft
South Bend 4 puck clutch
OEM STi flywheel
Everyone wants to know uncorrected numbers:
We live at high altitude, and our SAE correction is pretty big. Still cool to see the car make 870 SAE when the first time I dynoed it in 07 at stage 2 it made 247whp SAE on the same dyno.
06rexwagon is offline   Reply With Quote
Old 01-10-2014, 12:49 PM   #2
topfuelman
Member#: 140036
That's completely retarded. This has to be a record....
topfuelman is offline   Reply With Quote
Old 01-10-2014, 12:58 PM   #3
BoostInc
Member#: 176520
1994 Legacy SS
black and mud
It would be cool if it had a real turbo....
BoostInc is offline   Reply With Quote
Old 01-10-2014, 01:13 PM   #4
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
explain???
bmxhotsauce is online now   Reply With Quote
Old 01-10-2014, 01:20 PM   #5
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
nice work Cam!!
this is very cool, and the EFR9180 turbo is very real. Full-Race has these in stock in fact we can ship today - how many do ya want
Full-Race Geoff is offline   Reply With Quote
Old 01-10-2014, 01:58 PM   #6
06rexwagon
Member#: 114730
[email protected]
Originally Posted by bmxhotsauce View Post
explain???
Haha he's my friend and the guy in the video helping. Just giving me a hard time because he's a Garrett fan boy.
Old 01-10-2014, 02:39 PM   #7
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Looks awesome! Is this a new motor, same turbo? And it made some more power?
xluben is offline   Reply With Quote
Old 01-10-2014, 03:02 PM   #8
shomspeed
Member#: 166371
2007 WRX STI
Thumbs up
Originally Posted by 06rexwagon View Post
Event: Dyno Tune
Elevation: ~5,400ft
Weather: Cold
Tuner: Cam
Dyno Info: Dynojet
Gear: 3rd
Target AFR: 11.4:1
Engine:
OEM 2006 STI Heads
ARP 625+ Head Studs
GSC S3 Camshafts
BC +1mm valves
ID2000's
-8 Feed, -6 return
OEM STi flywheel
CAMTuning wagon makes 870 HP - YouTube
Cam's congrats on the build, it looks like you picked up about ~35whp at peak power and extended it out to ~7500rpm vs your previous setup with the S2 cams that peaked at ~6800rpm at same boost 33psi Impressive!
shomspeed is offline   Reply With Quote
Old 01-10-2014, 03:48 PM   #9
m.bryant
Member#: 310077
2007 Legacy GT SpecB
Killer results!! Very similar to what I'm working on so I love to see it all come together!!!
m.bryant is offline   Reply With Quote
Old 01-10-2014, 04:22 PM   #10
06rexwagon
Member#: 114730
[email protected]
New block, same heads. Here's the thread that goes into detail about the demise of the other block:
http://forums.nasioc.com/forums/show....php?t=2569724
Old 01-10-2014, 04:32 PM   #11
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Very nice! I'm impressed how much power this turbo makes at those boost levels.
I'm curious why you went to a standalone ECU. Does it have features you wanted (such drag anti-lag) or did you run into limitations trying to tune with the stock ECU?
WRXt4cy is offline   Reply With Quote
Old 01-10-2014, 04:37 PM   #12
06rexwagon
Member#: 114730
[email protected]
When I went to the AEM, Cobb had not yet released speed density on the AP. Even if they had, I wanted true drag antilag with ignition cut, and like the added features the AEM has like being able to trigger the 2nd Bosch under load, or have my CEL be my shift light.
Old 01-10-2014, 04:45 PM   #13
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Great numbers. good job Cam
waynoSTI is offline   Reply With Quote
Old 01-10-2014, 05:00 PM   #14
russian777
Member#: 300971
Rally blue
good job
russian777 is offline   Reply With Quote
Old 01-10-2014, 05:28 PM   #15
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
It always gets better and better!! Nice work Cam! Can't wait for your first pass on this setup, 9s
wgr73 is offline   Reply With Quote
Old 01-10-2014, 05:38 PM   #16
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Cool - that's what I was wondering. I've worked with AEMs on some non-Subaru platforms and I do get really spoiled by the features but with SD being available for stock ECUs now, I'm wondering what power level dictates a switch over to a standalone because the stock ECU simply can't keep up.
Old 01-10-2014, 05:41 PM   #17
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Does AVCS work with the V1?
Zee Biker is offline   Reply With Quote
Old 01-10-2014, 05:57 PM   #18
06rexwagon
Member#: 114730
[email protected]
Yes it does
Old 01-11-2014, 01:50 AM   #19
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Very cool! Glad to see you didn't skip a beat and got this beast right back up and stomping.
I always imagine Cam giving unsuspecting V8's straight whoopin's on command. Riding along would be priceless.
TDagen is offline   Reply With Quote
Old 01-11-2014, 10:42 AM   #20
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
Been following your build. Kick ass man. Congrats. Hope to see it run at the all out call out. Plan on being there again with the twin turbo vega in let it eat.
Any concern revving the stock crank that high? What oil you run?
cnstman is offline   Reply With Quote
Old 01-11-2014, 11:05 AM   #21
06rexwagon
Member#: 114730
[email protected]
Since it's a mostly stock looking wagon, I rarely get a second look on the street. Seems like the guys that want to mess with me are the stock Mazda speed kids or SRT4's.
Crank is balanced, and I've rev'd to 9k without issue. Right now I'm running 15w40 conventional Valvoline diesel oil. I usually run Rotella T6 but I only have about 900 miles on the motor
Old 01-11-2014, 01:06 PM   #22
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Very nice! We're getting close with a very similar build and excited to see what it'll do at sea level. I'm hoping to see a bit better spool down here.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 01-11-2014, 01:59 PM   #23
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
Yes it does
I was going to ask the same thing. After extensive research of other peoples situations with the v1 controlling avcs. We sold 2 out of 3 of ours. Both for sti. Rons drag wrx might still run it
Id be careful with it. Unless you have a bunch of sensors/ gauges & fail safes, it's pretty risky on the motor otherwise if anything like what happened to others happens here, bad cam or crank signals
Irv Weissmanhowerton is online now   Reply With Quote
Old 01-11-2014, 03:22 PM   #24
06rexwagon
Member#: 114730
[email protected]
-- Ed
Altitude hurts spool so bad, but it isn't as laggy as the dyno chart shows. As you probably know the dynojet doesn't apply load so all the cars we tune on it spool about 400-500 rpm later on the dyno.
Old 01-11-2014, 05:28 PM   #25
CatfaceType-R
Member#: 81102
Looks good, you've been through some motors, you deserve a long lasting one! All the best of luck.
C
CatfaceType-R is offline   Reply With Quote
