Old 10-14-2002, 12:28 PM   #1
Drivingchallenge
Member#: 12979
Default Vishnu Pug In Harness questions
I have a Vishnu Harness to install, the plug in one thats saves factory wires. Does anyone have pics of their install, or any suggestiongs on where to put it? I seems to sit great on top of the ECU, but then the sheilding won't fit. Any ideas. Thanks.
Drivingchallenge is offline   Reply With Quote
Old 10-14-2002, 12:31 PM   #2
phillywrx
Member#: 19876
2014 Audi SQ5
that is correct. the shielding will not fit with all bolts in place. you can only replace the one on the very top in the center and the lower right one.
phillywrx is offline   Reply With Quote
Old 10-14-2002, 12:34 PM   #3
Drivingchallenge
Member#: 12979
OK. But doesn't that mean the sheild will rest on the Harness still? With people getting in and out of the car putting their feet on the sheild, then pushing on the harness, is that OK?
I was thinking about getting longer bolts and using some washers and/or spacers to raise the sheild above the harness and sitting the harness on top of the ECU. Any thougths on that?
Old 10-14-2002, 12:40 PM   #4
phillywrx
Member#: 19876
2014 Audi SQ5
yes, the shield will rest directly on top of the unichip. you are OK as long as no one does a tap dance on it. i did not try to fix the problem, i just tell everyone not to put their feet up on the shield and to keep'em on the floor board. if the spacer thing works, be sure to post details. i have not heard of this before.
Old 10-14-2002, 12:51 PM   #5
Drivingchallenge
Member#: 12979
my idea is to get longer bolts, and measure how much higher the shield needs to sit and use a spacer/nut set up to space it high enough off the ECU, where I can have it fully secured and then have no worry about people's feet causing any damage.
Old 10-14-2002, 01:56 PM   #6
dunk
Member#: 15359
I took this approach and it worked great. A little lump in the carpet, but with the floor mats in you can't tell at all. I will try and take some pictures tonight. Allowed me a lot more room for my pass thru harness, unichip, and my avc-r wiring.
Duncan
dunk is offline   Reply With Quote
Old 10-14-2002, 02:11 PM   #7
2000vfr800
Member#: 15599
When did you get your Stage 0? Didn't you get the metal stand-offs that you use to keep the shield off the unichip?
2000vfr800 is offline   Reply With Quote
Old 10-14-2002, 02:27 PM   #8
Drivingchallenge
Member#: 12979
I only have the harness, not a full stage.
Dunk- Glad to hear. I am going to try and hit up Homedepo for the hardware tonight. Would love to see those pics.
Old 10-16-2002, 09:25 PM   #9
pharm180
Member#: 8948
02 srp wrx
stage1 310hp
i just installed the stage zero chip and harness. everything fit perfectly under it. i used the spacers and bolts provided in the kit and squeezed it all under it the sheild sits 1 inch higher but the spacers provide excellent strength .
pharm180 is offline   Reply With Quote
CA: Vishnu Unichip, EMI, Harness - VStage 1 crowbar Private 'For Sale' Classifieds 9 01-17-2004 05:52 AM
Vishnu Unichip, PNP harness and EMI adapter WhiteWRXBoy Private 'For Sale' Classifieds 4 10-04-2003 09:28 PM
Vishnu Unichip w/harness for sale & more rossscarbro Private 'For Sale' Classifieds 19 09-27-2003 09:51 PM
FS: Vishnu unichip/wiring harness/EMI brinkn8r Bay Area Impreza Club Forum -- BAIC 0 01-29-2003 03:28 PM
Vishnu Plug-in Harness update Vishnu Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 48 06-17-2002 07:50 PM
