Old 01-14-2014, 06:41 PM   #1
chriss_07
Member#: 373386
2007 wrx sti
UGM
Default Anyone running a 280 cam?
Hey guys is there anyone out there running a 280 kelford cam on there ej25 heads? If so, what kind of head work did you get?
chriss_07 is offline   Reply With Quote
Old 01-14-2014, 06:47 PM   #2
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
Im running bc 280 with stock valves and stage 1 springs on 205 heads. Only port work is intake gasket match.
fastblueufo is offline   Reply With Quote
Old 01-14-2014, 06:55 PM   #3
chriss_07
Member#: 373386
2007 wrx sti
UGM
Have you had any problems? Im planning on running a 280 kelford. But not sure what kind of head work i need.
Old 01-14-2014, 06:57 PM   #4
chriss_07
Member#: 373386
2007 wrx sti
UGM
Old 01-14-2014, 07:26 PM   #5
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Head clearancing and some good springs along with all the other typical stuff.
Crystal_Imprezav is offline   Reply With Quote
Old 01-14-2014, 08:26 PM   #6
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
LOL though they have been proven to make power those are not really 280s...
rexworx is offline   Reply With Quote
Old 01-14-2014, 08:28 PM   #7
rexworx
Member#: 103232
If you running real cams most likely clearance do to lift of cams, and a valve spring kit minimum depending on lift. Which 280 kelfords are you talking about? how much lift do they have?
Old 01-14-2014, 09:20 PM   #8
fastblueufo
Member#: 212154
02 billet crank
They spec out to 280 on the cam spec although the grind is smaller than some other 280's. I went with bc because they have less overlap than the others. The grind is just better suited to a forced induction cam for street use.
the cosworth 280 is actually 282 and 240* @.50. The bc is spec'd at 280 and 236* @.50. So I dont see how you say a 280 grind cam isnt really a 280 cam. There are alot of different grinds at a certain *. Its still a 280 * cam grind.
Old 01-15-2014, 10:05 AM   #9
chriss_07
Member#: 373386
2007 wrx sti
UGM
I was recommended a 272 instead of a 280. Any advice?
Old 01-15-2014, 12:44 PM   #10
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
What turbo? And you'll have to clearance around the bucket area for the lobe to clear.
Most machine shops can do that. 280 @ what lift? you're going to need to be pushing some air for those to be efficient. I have S3's from GSC and that's for a FP3794R (94lb per min) those are 282 @ 11.3
-Phil
Flat 4 Motorsport is offline   Reply With Quote
Old 01-15-2014, 08:39 PM   #11
chriss_07
Member#: 373386
2007 wrx sti
UGM
-Phil
fp3794r or a BW s300. How do you like your 282? Would you recommend a 280 with an fp37?
Old 01-15-2014, 11:38 PM   #12
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
Haven't run it yet, Im still gathering parts to swap my GC.
Have to build the motor yet, UPS fubar'd my pistons when they came back from coating. So its on hold right now till I get some replacements.
have to do some special machining on the heads.
Spec out a trans, axles, drive shaft.
I have a lot of work a head of me. It's definitely a project that's going to be a while.
I have a 400WHP GD too that I drive everyday, so this one I'm taking my time with.
The car has to be stripped caged and re painted. harness swap ect. to get it prepped for the big boy setup.
As for cam recommendation, on the FP3794R the 280 or 282 would be my choice, I have GSC beehives and their one piece valves, but I may switch out the exhaust valves for the new Supertech sodium filled inconel valves, haven't decided yet but I'm steering in that direction. I'm going to see high EGTs so I need an exhaust valve that will take the abuse. I'm going to either anti lag the turbo to spool it or spray it. You're going to need some cams with some lift and duration to keep you in your powerband on that turbo.
If I can get the car ready for Autumn drags I'll be happy but I'm busy with customer stuff and I have another business I'm consulting on so my time is limited.
Old 01-16-2014, 06:26 PM   #13
chriss_07
Member#: 373386
2007 wrx sti
UGM
Let me know how you like the GSC beehive. I was planning on running some supertech or ferrea valves- 5-angle job. Dont know how agressive i should do the porting,etc.
Old 01-20-2014, 11:49 PM   #14
lee586
Member#: 212926
97 Wrx
man there are so much wrong here, first of all to the morons saying that the bc 280cams are not a true 280 are just talking crap and obviously have no idea on cam specs and how to read them.
BC measure there advised duration @.010
Kelford measure theres @ 0.250mm (.010)
the BC duration measured is @0.50 - 1.28mm
and the kelford duration is measured at @.039 - 1.00mm lift
so basicly you cant even measure these duration the same the less lift you measure from the higher or bigger the duration number will be
if kelford measured there duration from .050 lift the number on there cam card would be even smaller then the bc duration on some spec
so 234@.50thou
then go measure kelford 240@.39 then measure this cam from .50thou and this nuber of 240deg would be decresed higher in the ramp
advised duration will affect where the power in the band will be shifting the power higher for a bigger advised
duration@.50 lift is more of a indication on the hp potential the cam will make and lift well never sacrifice lift for duration imho lift is over rated and so are kelford cams
so for the guys saying that bcs are not a true 280 or 272 to what they spec there cams at you guys need to go learn some more
lee586 is offline   Reply With Quote
Old 01-21-2014, 02:50 AM   #15
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Advertised duration means nothing. It is just that, advertising. If you really want cam spec info Australian Lee is spot on. You need to know what the manufacturers checking height is and base your decision on that. Cam profile makes a difference too.
Cosworth first advertised my cams as 275s because their advertised duration was from initial opening to fully closed. Its a 272 cam @ .01" with 232 duration @ 1mm.
